Question about Maytag MER6772 Gemini Electric Kitchen Range
Maytag Gemni Stove
I have a Maytag Gemni Stove - drop in with a double oven. My top oven is not heating properly. the tempature says 350 but the elements are not hot. do you think the elements could be going out?
  • 473 Answers
The problem is either in the oven control or the element (in some cases could be both). You will need a meter to check the resistance on the elements as well as power to the element. Remember this is 240 volts and very dangerous. If your not comfortable with it call a professional.
Posted on Oct 08, 2007
Maytag gemni double gas oven burner is on and control knob will not turn to shut it off what can I do?
Call your local fire department quickly before you have a house/apartment fire.
They should be able to turn the gas off until you have the stove fixed.
God bless your efforts.
Aug 28, 2017 | Maytag Kitchen Ranges
This touch 850 series double oven is only heating up to 170 when dial is on 350 do I have a bad element?
Elements usually either work or they don't, if it comes on the but does not give enough heat the thermostat is bad. If it was cleaned inside recently, check the routing of the stat lead perhaps its kinked etc.
Mar 16, 2015 | Maytag Ovens
Lower element does not heat
most likely the element needs replacing, check for arcing holes,melted spots. check fuses, normaly under cover at top of stove. element is easy to replace(a few screws), unplug stove when doing so.
Jun 17, 2010 | Maytag Gemini 30" Self-Cleaning...
Electric Oven is not heating up (BAKE)
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} It could be that your lower element is burnt out or ready to burn out. They last 3-5 years depending how much you use your stove.
Disconnect POWER to the stove, remove the screws holding the lower element to the back of the inside of the stove, pull out carefully and remove the 2 screws holding the wires on. Check the element with an ohm meter, it should read 0 (zero or very close) resistance on an ohm meter. You may also take it to a store that sells replacements ($25) and they may check it for you.
Nov 13, 2009 | Ovens
Maytag Gemini Double Oven-bottom temp problem
after power outage clock on oven will not set unless the oven itaelf is on unable to set clock
Jan 16, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Preheat taking long time
If your oven has the hidden bake element then it is probably working properly. A standard oven with an exposed bake element will usually take about 12-15 minutes to preheat. The hidden element models take a little longer but they usually heat a little more evenly.
Post back if you have any more questions.
Oct 29, 2007 | Kenmore 96212 / 96214 / 96219 Electric...
Maytag MER6772 Gemini Electric Kitchen Range Logo
169 people viewed this question
Top Maytag Kitchen Ranges Experts
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
