Celcus talktalk code - Televison & Video
Hi I have a celcus tv and I am having trouble connecting my talktalk remote to it I have tried two of the codes 1146 and 0004 and it blinks twice as it says which means it's connected but it isn't
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://homenol.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Sep 04, 2017 | Celcus Televison & Video
What is the code for the BT YouView remote to a Celcus flat screen TV?
The codes are here. Doesn't matter if it is Virgin or BT, the code is to the television not to the remote.
http://celcustv.co.uk/faq
Jun 17, 2016 | Celcus Televison & Video
What is the universal pairing code for a celcus sound bar
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts.
http://electro-medical.blogspot.com/
Jan 09, 2016 | Celcus Televison & Video
Toshiba codes
Hi Ian,
The number or code that corresponds with your tv remote is "0".
Kindly click the link below to help you configure the remote control on talktalk.
Hope this one helps you.
Can use my TalkTalk TV remote control with my TV TalkTalk Help
Feb 06, 2014 | Televison & Video
Celcus tv remote code
Check these codes: 241 115 275
Aug 05, 2012 | RCA Televison & Video
Celcus bt vision code?
The remote comes standard with the code 0000. with my celcus TV this controls the volume and mute but not the on and off. Better than nothing...
Apr 16, 2012 | Televison & Video
What is the 'One4All' remote code for Celcus TVs?
Try these codes. If it do not help you, Try code search method.
0147 0135 0250 0257 0310 0394
Code Search Method
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Apr 05, 2012 | Harley Davidson XL 1200 C Sportster Custom...
I need a pin code for my sky remote for the CELCUS tv
try 9999 it wiorks for most CELCUS tv's especially remote no.8
Jan 23, 2012 | Televison & Video
Open Questions:
Televison & Video Logo
Top Televison & Video Experts
