Question about Rule Livewell Pumps
New rule livewell pump runs but will not pick up water the outflow has a tee leading to two wells.
Could the tee be the problem?
    Sergeant:
  • 456 Answers
Is it wired correctly,brown is positive
Posted on Nov 30, 2013
Live well pump Key Largo boat what switch turns it on& off
On some boats there is a manual handle to direct water to either wash down or livewell. If you hear a pump running, but no water in livewell, look for that manual handle in the hose plumbing.
Sep 10, 2017 | Boating
Car stillruns very rough changed all plugs and wires and timming is on new gas filter it back fires and doesnt pick up speed
Check your exhaust system...
Once the muffler (even those Walker products) start coming apart inside... they can block the outflow...
No outflow = no intake (engine strangling).
Same possibility for the catalytic converter (if you have one)
Easy way... get it to the muffler shop ... get them to read
you hand-full of DTCs (trouble codes (some times free))...
or
Get that penetrating oil... soak up those header bolts
(really well)...
Open the system... if it runs you now know what has to be fixed BEFORE YOU CAN SAFELY OPERATE the VEHICLE.
Hope this helps
Dec 11, 2016 | Cars & Trucks
How do I prime my flotec 4022 pump
A number of Flotec pump manuals are available here: http://www.flotecpump.com/ResidentialResourcePage_resourcepage_ownersmanuals.aspx . The site lists a FP4022-10 pump with the direct link to the manual here: http://www.flotecpump.com/resources/images/514.pdf .
For this type of pump, there should be a priming plug or priming tee. Remove the plug (or tee) and pour water into the pump. Keep adding water until the pump and all of the piping to the well is full of water. If a priming plug or tee was also added on the suction side of the pump, open that section and fill all of the piping on the suction side with water. Replace the plugs/tees then open a faucet in the house. Start the pump. After 2-3 minutes, turn off the pump if no water has come through the unit. Add more water through the priming plug or tee (or multiple plugs and tees). Then repeat closing the priming ports and start the pump after opening a faucet. Once the pump is actually pumping water, turn off the open faucet. Wait for the pump to shut off once it reaches full pressure. Open one or two faucets to check that the pump is properly sensing the pressure changes and maintaining system water pressure.
If the unit didn't pull water from the well, check the piping for air leaks. See the full trouble-shooting guide in the manual. Page 9 has the priming information and page 10 has the trouble-shooting guide.
I hope this helps.
Aug 27, 2016 | Flotec Plumbing
Well water pump won't stop running
if it is a submersible well pump it could be crack in your line leading to the bottom of your commercial welcome and called it to leak water and still feel pressured
if it is a submersible well pump it could have a crack in the line leading to the summer double well pump in the ground it will cause it to leak but the tank will still be build up pressure
Jan 10, 2015 | Pentair Water 123324 1hp Submersible Well...
My 2 livewell pumps on my boat run but dont pump water to the livewells
have you tried reversing the wires. if wrong they run backkward and will never pump water .
Aug 18, 2014 | Boating
1998 Champion 181 bass boat in California...It appears that livewell is leaking into bilge,...and the aeration pump is not working? Could it be the pump? or a fitting at the base of the live well...by the...
try "duct tape" the fittings and drain to seal those areas, refill and see if water is still leaking, if so it's your live-well is cracked somewhere, and can be repaired on the inside with fiberglass resin..... if not then most likely the fittings/pump/hoses/etc....yes its a pain .Champions don't have alot of room to access any of that...got a Ranger myself....hope this helps and see you on the water....GL
Jul 06, 2009 | RTO Oar Sockets
Rule Livewell Pumps Logo
50 people viewed this question
Top Rule Boating Experts
Jeff Turcotte
Jeff Turcotte
Phil Walker
Phil Walker
Mike
Are you a Rule Boating Expert? Answer questions, earn points and help others
