Question about Electrolux E30DF74PS Dual Fuel (Electric and Gas) Kitchen Range
Electrolux oven f10 error code
Goes off when plugged in but not turned on.
  • Official Brand Answer
  • 4,342 Answers
Hello Mary, thank you for allowing me to assist you!
Typically error code F10 indicates your range has detected an issue with the runaway temperature (overheating). Let's try reprogramming your appliance by either unplugging it or flipping the household circuit breaker off. It is important to wait roughly ten minutes and then turn your range on. Usually this will clear most false error codes. If issue persists, at this moment I would suggest contacting a professional to proceed further. Most likely the RTD Probe (Resistance Temperature Detector) or the EOC (electronic oven control) will need replacing. Hope this helps!
Posted on Nov 22, 2013
My oven keeps giving the f10 code even though I have replaced the temp sensor and the oven relay panel. What's the next step? It's an electrolux #ew30es6cgw2. Tia
F10 - Runaway temperature. If these error codes shown while the oven is in day time mode, the EOC (electronic oven control) would need to be replaced. Otherwise check the oven temperature sensor (RTD sensor) as described earlier and replace if necessary.
Most of the EOCs incorporated power relays among all other components while some of ovens use a separate power relay board to simplify design and lower cost of production. You can determine it by visual EOC inspection and/or by the wiring diagram for your oven (if it is available). If there are some relays on it, replace the EOC. If there are no relays on the EOC, check the parts list (Search by the Model number) for the relay or power board. If there is a such part, replace it. I'll be glad to help you if any problems with the diagnostic. Just leave a comment on the bottom of the page. In such situation I'll need the complete model number of the oven.
Mar 03, 2017 | Electrolux Ovens
Code f10 and f29 came up while On self cleaning what does this mean ?
Washer Error Codes Below is a list of... - Elite Appliance ...
https://www.facebook.com/permalink.php?story_fbid...id...
Right now you will find error codes for Asko, Fisher & Paykel, Frigidaire, GE, Kenmore, LG, Maytag, Samsung, ... Check pump trap and clean. ... Musical series of beeps every 5 seconds and Wash cycle light flashing-Washer is overloaded. ... E47--Board thinks the door PTC circuit is open in spin .... F29--Door unlock error
Range Error Code F10: Troubleshooting Runaway Oven ...
? 2:20
https://www.youtube.com/watch?v=z6tcnpDKDns
Oct 1, 2015 - Uploaded by searspartsdirect
If you see F10 on your range, it means that your electroni. ... exceeds the temperature you set it at in either .
Nov 07, 2015 | Electrolux E30EW85EPS Electric Kitchen...
Electrolux range error code f10
Hello - Typically error code F10 indicates a variety of issues. The range could possibly have a runaway temp (higher than normal temps), shorted keypad, faulty EOC (Electronic Oven Control) or, display wire harness missing/not connected. Usually, these codes mean to replace the EOC. You may be able to reset the range by disconnecting the power to the unit for up to 30 seconds. This will clear most false error codes. You can disconnect power by either unplugging the unit or flipping the circuit breaker off and back on. If resetting the unit proves to be ineffective, I would recommend contacting a professional to move forward accurately.
Oct 02, 2012 | Electrolux EW30DF65GS Dual Fuel (Electric...
When the oven is turned on about 10 minutes later a f10 code comes on with a beeping. I've tried upluging from the outlet waiting 1 min. before reappling the power cord. I still get a f10 code
The F10 error code indicates a runaway temperature condition. If your oven is overheating, unplug the power cord for a few minutes. When plugged back in if the oven is still overheating, you will need to have the temp sensor & control checked.
Jan 22, 2011 | Frigidaire Gallery GLEFZ384GC Kitchen...
F11 error on electrolux icon oven
The F10 F11 F12 F13 F14 Error Codes indicate that the electronic oven control board senses a runaway temperature condition in the oven through the oven sensor circuit.
This can be caused by a faulty oven temperature sensor probe or a failed electronic control board.
Oven temperature is detected by the control board as it monitors the resistance through the oven temperature sensor circuit.
You could have a failed oven temperature sensor, a wiring harness failure, an open thermal switch or a failed electronic oven control board that would cause this problem.
The first component to check would normally be the oven temperature sensor probe.
If you have a volt/ohm meter, you can shut off the breaker for the range and remove the screws that mount this sensor to the back wall of the oven.
Carefully pull the wire harness into the oven cavity until you get to the wire harness disconnect plug.
You should have enough slack to pull it this far into the oven.
Disconnect the sensor but do not let the wire harness retract back through the back wall of the oven or it will be hard to reconnect.
Measure the resistance of the oven temperature sensor with your volt/ohm meter. At room temperature, the resistance should measure around 1100 ohms.
The resistance chart is shown in the image below.
If the resistance is above 2200 ohms at room temperature, then the sensor probe is causing the F10 error code and will need to be replaced.
You can order a new sensor probe from the Sears PartsDirect website. The part number for the sensor is 316217002.
If the resistance is normal, then one of the other causes mentioned above is producing your F10 code.
You would need to access the electronic oven control board (Timer) in the console and check the resistance at the sensor circuit connection to the control board as the next step in troubleshooting this problem.
http://media.fotki.com/1_p,wbqdsfkrfqtswfqxgtqsskgwtqkq,vi/krdbrtqkgxkrbbqbrwb/1/1303472/5961857/image37801img-or.jpg
Thanks for using FixYa
Nov 27, 2010 | Electrolux ICON Designer E30SO75ESS Oven
Was cleaning oven and error code F10 appeared what is a error code F10?
hello there"
The "F10" error code caused by the runaway temperature.
The first thing I would check is the resistance across the oven temperature probe (aka oven temperature sensor) terminals at the EOC (electronic oven control) plug.
It suppose to be about 1100 Ohms at the room temperature.
If the resistance at the EOC plug is wrong, then measure the oven temperature probe resistance at the probe plug.
If it's wrong - replace the oven temperature probe. It's better to hardwire it, using a high temperature ceramic wire nuts.
If the readings at the EOC and at the oven temperature probe plug are different - check the wire harness between the oven temperature probe and the EOC.
If there is nothing wrong with the oven temperature probe resistance - replace the EOC.
- The part number for the oven temperature probe is AP3704441
- The part number for the EOC is AP3776874
- The part number for the EOC overlay is AP3778486
Read more: http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/4431-f10-error-code.html#ixzz156CO7RjB
Nov 12, 2010 | Frigidaire Ovens
I have an Electrolux range , while baking it want's to overheat an a F10 error will appear. I just notice that the Broiler heating element comes on while I am baking. What to do to repair? I had a...
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 14, 2010 | Electrolux EI30EF55GW Electric Range
Error: F 10
That model number does not seem correct but error code F10 on the Electrolux ovens relates to a faulty power board.If that Serial is correct then it is still covered in the 12 months full warranty.
Hope that helps.
May 11, 2010 | Electrolux ICON Designer E30SO75ESS Oven
Electrolux Wall oven E30EW75ESS
Same F23. Resetting the beaker seems to fixed it. Thanks to all
May 27, 2007 | Electrolux ICON Designer E30SO75ESS Oven
Electrolux E30DF74PS Dual Fuel (Electric and Gas) Kitchen Range Logo
280 people viewed this question
Top Electrolux Kitchen Ranges Experts
Rommel Balcita
Mike Henne
Level 1 Expert
Are you an Electrolux Kitchen Range Expert? Answer questions, earn points and help others
