Question about Proform 315 Csx Recumbent Bike
Resistance stops after a few seconds - Proform 315 Csx Recumbent Bike
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 163 Answers
Always check the sensor alignment first. If its properly aligned, check the sensor magnet. If thats ok, replace sensor
Posted on Jan 03, 2014
The gt5250 power back generator has stop producing
If it has sat, it may have lost it's rotor residual magnetism. Disconnect the rotor field wires at the AVR or on the exciter/brushes. Note they are polaroty sensitive. Connect a 12V battery to F+ and F- (note polarity) and momentarilly power from the battery for a few seconds. DO NOT forget to disconnect the rotor/exciter field wires first or the voltage regulator will be damaged. If it hasn't sat check voltage regulator, rotor resistance, and stator resistance, and for shorts to ground.
Oct 18, 2014 | Electrical Supplies
Brushless generator has stopped producing power ,
Hello , I have a kenmore refrigerator that stopped
here is a problem in the internal resistance, you must quickly replaced
Sep 25, 2013 | managemylife.com
I have a maytag Neptune NDE3000AYW and the dryer turns on, runs for a few seconds and stops. took it apart and cleaned all the lint and dust. after a while it will run again for a few seconds and stop. ...
Check the door switch. It may be at fault here. Open the door and hold the switch by hand and start the dryer. The switch should have a firm resistance to it when you push it. If you should find this bad, here is the replacement switch. If the switch is ok, then the motor is bad. Here is the motor to order.
Keep me posted!
Nov 05, 2012 | Maytag MDE2600 Electric Dryer
Unit stopped cooling. Measured circuit resistance L1 to L2, approx 10 ohms. Plugged unit in, heard a click in a few seconds. Unplugged and measured circuit resistance which indicated circuit open. ...
You'll need a 3-1 start kit. The clicking is those starting components. We shipped one out yesterday for 35.00 and that included overnight Sat. delivery the part alones was 20.00 with instructions. Very easy and the replacement kit is better than the original parts and available at most any appliance parts store. Good luck.
Aug 20, 2011 | Magic Chef MCBR445S1 Stainless Steel...
Fridge nor freezer doesn't work.Amana model#ARB2217CSR. I tested a few things and saw 120V is present to the compressor via the relay.The voltage is there every couple of minutes for about 10 seconds and...
how old is the unit ? it sounds like your clixon breaker is kicking in and stopping the current flow to the compressor. is a self resetting breaker. I would check the start capacitor before I did anything else. If it is good , check the resistance of the compressor itself . There are three terminals marked C. S. and R. the resistance between the C. and S. terminal should be around 2-4 ohms. The resistance between the C. and R. terminal should be between 10-20 ohms. depending on the unit. the main thing is you should not read zero or infinity when you check the resistance.If you do , the compressor is bad .
Mar 14, 2010 | Amana ARB2217CSR Bottom Freezer...
MY TREADMILL STOPS JUST A MINUTE AFTER STARTING.
Try Lubricating the belt with silicone spray.
Probably the resistence from the belt scraping over the ground board is too high, forcing the machine to switch off in order to prevent damage.
Jul 24, 2009 | Kettler Exercise & Fitness
2003 Dodge Neon SXT Clutch Problem Less Resistance
check clutch resevoir for brake fluid if none theres a leak if not clutch in need of repair!!! :)
Jul 06, 2009 | 2003 Dodge Neon
1985 c10 305 engine .stops running after a few miles .starts back after it cools down over night.
sounds like either the coil or ignition module is getting hot and creating a high resistance condition in which voltage cannot push through the resistance. Once cools down, normal resistance is obtained and they will work properly. Temperature and resistance are linked... Temp. increases so does resistance.
Jun 26, 2009 | 1985 Chevrolet Chevy
TIMEX IRONMAN TRIATHALON DIGITAL WRISTWATCH
ANALOG TIME
Pull CROWN and turn to set HOUR and MINUTE hands. TIME AND DATE A. Press and hold SET. SECONDS digits will flash. B. Press SPLIT/RESET to set SECONDS to zero. C. Press MODE to select HOURS. D. Press SPLIT/RESET to advance hours digits. Go through 12 hours for AM or PM. E. Press MODE to select MINUTES, press SPLIT/RESET to advance. F. Repeat to set MONTH, DATE, DAY, 12- or 24-hour time display. G. Press SET when done. BASIC OPERATIONS Press MODE to cycle through CHRONO, TIMER, and ALARM modes. Press INDIGLO to illuminate watch face. In any mode, press MODE to view time display. Press any button to stop alarm or timer beeps. INDIGLO INDIGLO CHRONOGRAPH A. Press MODE until CHRONO appears. B. Press START/STOP to start. C. Press SPLIT/RESET to record lap time. Display pauses. D. Press MODE to resume display of lap and split time (automatic after 10 seconds). E. Press START/STOP to pause chrono. F. Press START/STOP to resume. G. Press START/STOP to stop. H. When timing is stopped, press SPLIT/RESET repeatedly to recall last eight lap and split times. I. Press and hold SPLIT/RESET to reset chrono. MODE MODE START/ STOP START/ STOP SPLIT/ RESET SPLIT/ RESET SET SET CROWN COUNTDOWN TIMER A. Press MODE until TIMER appears. B. Press SPLIT/RESET to select timer operation (Countdown and Stop; Countdown and Repeat; Countdown and Start chrono). C. Press SET. HOURS digits will flash. Press SPLIT/RESET to advance digits. D. Press MODE to select TENS of MINUTES. Press SPLIT/RESET to advance. E. Repeat to set MINUTES, TENS of SECONDS, and SECONDS. F. Press SET when done. G. Press START/STOP to start timer. H. Press START/STOP to pause, press again to resume. I. When timer is stopped, press SPLIT/RESET to reset timer. Watch will beep when countdown reaches zero. ALARM AND CHIME A. Press MODE until ALARM appears. B. Press SET to select HOURS. Digits will flash. C. Press SPLIT/RESET to advance digits. Go through 12 hours for AM or PM. D. Press MODE to select TENS of MINUTES. E. Press SPLIT/RESET to advance. Repeat for MINUTES. F. Press SET when done. G. Press START/STOP to turn alarm on or off. H. Press SPLIT/RESET to turn chime on or off. When alarm time is reached, watch will beep for 20 seconds, or until any button is pushed. Alarm will repeat every 24 hours until deactivated. INDIGLO® NIGHT-LIGHT WITH NIGHT-MODE® FEATURE A. Press INDIGLO to activate light. Patented (U.S. Patent Numbers 4,527,096 and 4,775,964) electroluminescent technology used in the INDIGLO® night-light illuminates watch face at night and in low light conditions. B. Press and hold INDIGLO for three seconds (beep will sound) to activate or de-activate NIGHT-MODE® feature. C. While in NIGHT-MODE® feature, press any button to illuminate watch face for 3 seconds. Chime on Alarm on If your watch is water-resistant, meter marking or ( ) is indicated. Water-Resistance Depth p.s.i.a.* Water Pressure Below Surface 30m/98ft 60 50m/164ft 86 100m/328ft 160 *pounds per square inch absolute WATER AND SHOCK RESISTANCE WARNING: TO MAINTAIN WATER-RESISTANCE, DO NOT PRESS ANY BUTTONS UNDER WATER. 1. Watch is water-resistant only as long as lens, push buttons and case remain intact. 2. Watch is not a diver watch and should not be used for diving. 3. Rinse watch with fresh water after exposure to salt water. 4. Shock resistance will be indicated on the watch face or caseback. Watches are designed to pass ISO test for shock resistance. However, care whould be taken to avoid damaging crystal.
Oct 27, 2008 | Timex Watches
Proform 315 Csx Recumbent Bike Logo
322 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
