How do you "ungolue" something that was glued with superglue?
    Sergeant:
  • 302 Answers
Try nail polish remover
Posted on Jan 06, 2014
The hose pulled off the canister. Is it just glued on?
depends what make of vacuum
how old is the pipe ..you may need a new pipe
for now push it back on firm
if it comes off try zip tie or gaffer tape
Nov 13, 2016 | Vacuums
How do you get the drive platter off to lube bearings
Normally there will be a horseshoe clip under the record spindle. This might be covered up with a plastic or chrome thing. It might be glued on, so you might need to lift it off with a screwdriver or sharp tool. You can always glue it back on with Bostick type glue after. Not Superglue.
Jun 17, 2015 | Drive Audio Players & Recorders
I have a lawn ornament that expands with forced air. The item uses 120 V, 60Hz, 40W, Ins. CLA Therm Proc
Because it was superglued, there may still be some cracks the air is seeping through. You need to use a glue like GOOP to seal the cracks in the housing. GOOP can be bought at Lowes or Home Depot or possibly any hardware
Dec 19, 2014 | Cars & Trucks
How can i fix a ceramic vase that has the bottom part glued on crooked
Use rubbing alcohol to loosen the superglue and gently pry the pieces apart and re-glue the piece on correctly.
Oct 19, 2012 | Samsung HL-S6187W 61 in. HDTV
The paddle on my water dispenser broke off. Can this be glued and if so what type of glue should I use?
Hello, Thank You for using FixYa. I will be helping you today.No it can not be glued it would have to be replaced.
Thank You and please rate my answer if it was helpful..
Jun 23, 2011 | Frigidaire Gallery Series GLHS269ZDB 36"...
Our two lower slide-in baskets will not stay on track. Even when the load has been reduced, the baskets fall off the track. I have tried to bend the sides to better reach the track, but it doesn't work. ...
No, very rarely internal shelves can be moved between generations. Unfortunately all you can do is an improvisation to keep them in place: you need to make the channel walls higher by gluing some small pieces of thick plastic on them using a powerful adhesive - not superglue, something like Loctite Sumo Glue.
Sep 10, 2010 | Kenmore Freezers
The bottm of the flash a portion of the connection is broken. Can it be repaired?
I presume you refer to the hotshoe foot?
Well you can try superglue bit it may not last the distance! It is surprising how much pressure is applied to these to just fit them and keep them on the camera I have tried gluing one and it lasted a day each time Got too annoying so i bought a replacemenet
Aug 31, 2009 | Quantaray QTB-9500A TTL Flash
The numbered outer ring on my seamaster fell off in the bath how
If your numbered ring was friction fitted then you will need the help of watchmaker. Very often those rings are glued. If yours was glued, get the good quality glue and just glue it back. Do not use Superglue. The best would be any good epoxy containing glue.
Rate, please.
Mar 28, 2009 | Omega Seamaster 300M GMT 2538.20.00 Wrist...
Cover of the drawing surface come off
The drawing surfce is not glued down and should never be glued down. It is replaceable...
It is basically held on the tablet by an adhesive strip (Double Sided Tape) along it's top edge. I was a little worried too, when after spending some time in Photoshop, it lifted away as if stuck to my wrist.
This is not a fault and it will just lay back in it's recess, no harm done.
NEVER EVER glue it down, or when it comes time to replace it, you will not be able too. If it is peeling up and not laying flat, buy a replacement.
Aug 20, 2008 | Wacom Intuos3 Graphic Tablet
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
