Question about Hotpoint HSS25GFP Side by Side Refrigerator
Have a hotpoint CSX22GRSA side by side refridgerator freezer with ice maker and ice keeps forming and stopping the fan. What could be causing this?
It has been doing this every now and then for awhile now, but I always just cleaned all the ice off and it worked fine. This time I did that and it iced back up again and stopped the fan. The ice it was making before it did it this time were smaller and some were hollow. Please help me figure this out. Thank you
  • 3 more comments
  • nancytmc2 Nov 21, 2013
    I replaced the water inlet valve, but it hasn't made any ice. I get water from the door but it hasn't produced any ice. I saw the
    the ice maker fins working but no ice had fallen
    Where is the control board?
    No offense but I would like to thank all the helpful suggestions I got; "not". I finally figured it out without anyones help from this site. Also it cost me an extra $50 because of the one suggestion I got from someone elses problem in 2009. Just to be helpful to someone like me in the future my problem was caused by the fill tube for the ice maker.
  • nancytmc2 Nov 22, 2013
    It was the fill tube for the ice maker
    Champion:
    Habit-Forming:
  • 275 Answers
I don't think it is defrosting properly, possible defrost element failure, the ice being produced is smaller because of this.
Posted on Nov 22, 2013
Testimonial: "It was the fill tube for the ice maker. Thanks though."
2 Suggested Answers
FreeTech
  • 426 Answers
SOURCE: Our Hotpoint side by side refridgerator, the ice/water not workin
It sounds like you have a failing relay/valve that wont stay open when current is passed through them, check there first otherwise your control board could have water/heat damage remove inspect and if necessary replace let me know how it goes :)
Posted on Jul 11, 2009
My Refridgerator/freezer is not working
Sounds as if the compressor is not running even tho the fans are. The overload relays on the side of the compressor are usually the source of this problem. They are on the side of the compressor and if you change these out you should be fine. Fairly easy to do as it should just be a plug connecting it. Hope this helps.
Feb 21, 2010 | Maytag MTB1953HE Top Freezer Refrigerator
Whirlpool refridgerator is leaking water on the freezer side (side by side refridgerator) onto the floor. The ice machine was overflowing with ice and has frozen ice in the ice maker that won't budge. We...
WAS IT LEAKING FROM INSIDE THE FREEZER OR FROM BOTTOM OF FRIDGE? ONCE IN A WHILE YOU NEED TO TAKE OUT THE ICE BIN AND DUMP ICE OUT AND CLEAN IT. HOW CAN THE ICE MACHINE OVERFLOW WITH ICE WHEN THE ICE IN THE TRAY WON'T BUDGE? NEED CLARIFICATION. SOUNDS LIKE YOU EITHER HAVE A BAD ICE MAKER MODULE OR THE SOLENOID FOR THE ICE ON THE WATER VALVE IS BAD.
Jan 24, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Jul 11, 2009 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Refridgerator not cooling
is it side by side or freezer on top/bottom...check to see if the fan inside the freezer is running when the compressor is running..also check to see if ice is covering the evaporator coils.. the freezing should be even with a thin layer of ice/ not partically melted..sometimes the ice forms in the vents and stops the air flow...to review...check and see if fan is working in freezer
check to see if vents are clogged......good luck!!
Apr 29, 2009 | Refrigerators
GE Monogram refrigerator/freezer problem/ice dam in ice maker
I have had the same problem with ice forming. I found the problem is from the ice maker. The water fill tube delivers water to a plastic piece that acts like a funnel. The water goes through this plastic piece into the ice maker. Ice forms in the plastic funnel piece causing the water to overflow into the ice bin and freezer.
Mar 26, 2009 | Refrigerators
GE SIDE BY SIDE/MODEL #GSS25JMDCC
I also had a loud fan and it was caused by ice build-up on the fan in the back of the freezer. From inside the freezer, I removed the plastic grill that covers the fan (I think I also had to remove the side rails and ice maker) then just let the fan defrost in the sink. Made sure it was nice and dry before putting it back in or else ice would just form again. I also took a sheet of plastic and put it between the ice maker and fan grill to stop water from dripping onto the fan and haven't had a noisy fan since. I just need to remove the ice build-up from on top of the plastic sheet every now and then, but that's much easy than taking everything apart to get to the fan.
Feb 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
No cold air n at all in refridgerator or freezer oadmirall sideo
I believe i just posted part of your answer and mine, switch icemaker switch to off position and noise stops i'm assuming ice maker has had better days but hope it can be remidie
Jan 03, 2009 | Jenn-Air JCD2295HES Side by Side...
Aug 18, 2008 | Refrigerators
I REPLACED ICE MAKER UNIT BECAUSE REPAIR MAN TOLD ME THAT THE HUMMINING NOISE WAS DUE TO ICE MAKER BEING STUCK IN A CYCLE. AFTER REPLACEMENT THE NOISE IS STILL THERE. WHEN I SHUT THE ICE MAKER OFF NOISE...
theres ice in the fan propelar, if you see no ice blocking the propellers its the fan motor itself,if you unplug the fridge and stick something thin between the vents where you feel the air blowing thru and try turning the fan,gently and it spins smooth its the fan motor,if you dont wish to do this turn freezer off,open the door and let it defrost,then plug it in if buzz still there its the fan motor
Jul 08, 2008 | Hotpoint Refrigerators
Hotpoint HSS25GFP Side by Side Refrigerator Logo
62 people viewed this question
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
Sal DeAngelo
Dan Webster
Dan Webster
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
