Question about GE Dryers
E61 thats what it shows
Replaced circuit board and i have heat but still shows e61 code
Hello friend, thanks for your post!
Based off what you have described your Frigidaire dryer is displaying an error code of E61. I understand that you have replaced the circuit board and you are still receiving the error code. An E61 means that your heater relay as had a failure which could be a potential problem with your heater relay or a wiring harness. You may need to seek professional assistance with proper troubleshooting this will help you to avoid any further unnecessary part purchases. If you need help locating a local technician you can visit your manufacturer's website for a list of available technicians. -Matt
Aug 05, 2015 | Frigidaire Dryers
Error code E61 shows on my Frigidair Affinity washer. Do you know what E61 Means?
Hello Murray;
My name is Peter. I am a retired field service appliance technician.
Hi E61 means that the control board is sensing an incorrect/abnormal voltage present at its input.
1.) Unplug the unit for 5 minutes. If the error comes back -
2.) Lets check your power cord:
a.) Unplug the machine. Is the middle connector on your power cord connected to 'N'?
b.) Tighten all the connectors. Make sure you have a good ground.
c.) Check the voltage. Between 'L2' & 'N' = 110V, 'L1' & 'N' = 110V, 'L2' & 'L3' = 240V.
3.) Lets check your control board for shorts:
a.) The following link will show you how to access. Ground yourself by rubbing your hands on bare metal. Static electricity will knock out a board.
b.) Check all of the connections, push in on the wires at the connectors.
c.) Reassemble and try to start
http://www.applianceblog.com/manuals/5995413084_Washer_2004.pdf
4.) Well, if none of the above solved the problem, you have to replace the control panel.
Part #: 134523106 - Cost: $168.00
Dec 08, 2014 | Frigidaire ATF6000ES Front Load Washer
Zanussi 1200 stopping on drain and not emptying showing error e61
Problem in heating phase. Could be heating element.
Dado
Sep 18, 2014 | Zanussi Washing Machines
E61 shows up and it wont heat up
Hi Carrie, this is JK. I understand that you are experiencing an E61 error message on your dryer. Typically this error could mean that there may be a failure in the heather relay. I would recommend having a professional check the wiring. If no problems are found, you may want to consider replacing the Main Control Board. Hope this helps!
Mar 16, 2014 | Frigidaire Dryers
PXE-E61 media failure check cable
PXE-E61 Error message showing due to Media cable failure.
You have to fix this media cable failure one must return to the BIOS screen at start up. Depending on the model of the laptop, press f1, f2, or delete to enter the BIOS screen (the computer will tell you what keys to press). At the bottom of the BIOS screen, there will be a menu. One of the options should be "setup defaults." By pressing the corresponding key, it will return all of your settings back to how they where originally.
Hopefully it will help you
Jun 26, 2013 | ASUS X401a 14.1-Inch Laptop Black Intel...
Panasonic sa pt550
PXE-E61 ERROR
The error PXE-E61: Media test failure usually means the hard disk has failed or the hard disk needs re-seating or the disk controller is faulty.
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
May 05, 2013 | Computers & Internet
PXE-E61 media test failure check cable
Your unit is telling you that there is a cable problem (between HDD & MoBo) try a new one or if you have another drive with same cable swop over.
Sep 18, 2009 | IBM NetVista PC Desktop
The screen beeps and show E61:00. The pics come out blurry. HELP!
yes.its the lens error for sure.either the lens is dirty then needs cleaning.or the lens is got dirty plus lost its allignment then it needs allignment or replacement.
thanks.
Dec 15, 2008 | Sony Cyber-Shot DSC-P51 Digital Camera
Wont connect to pc
Try turning off and on your phone. ;D
Sep 24, 2008 | BenQ-Siemens E61 Cellular Phone
Dryers Logo
188 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
Sal DeAngelo
Are you a GE Dryer Expert? Answer questions, earn points and help others
