Question about Proform XP 580 Trainer Treadmill
Noisy treadmill has begun making loud scrubbing sound when running
Treadmill makes loud grinding sound when I run in the middle of the tread. it doesn't make the noise if I run on the left side.
1)you must LUBE the DECK BELT, inmediately, for to avoid the friction
2)LUBE the rollers bearing.too
3) See the main motor for bearing and repair the motor for bearint too.
4) If the problem persist you have worn deck belt, and replace.
God bless you
Nov 07, 2012 | Exercise & Fitness
My Maytag Dependable Care dryer, model MDE9206AYW has begun sueaking very loudly when running. The noise sounds like it may be a rubbing-type of a noise, or possibly a belt. I have not tried to take...
Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time.Here is a link to the part in case you need it.
Dec 31, 2010 | Maytag Dryers
I have a noisy Pro-Form Model 285T treadmill
Hey Richard Depending on the noise it could be one of several components failing. If loud clanking or clunking noises these components are Drive Motor, Front or Rear Rollers.
If it is a loud humming noise increasing and decreasing when planting yours feet then it is either the Inductor ( square object ) or the internal windings of the Drive Motor.
Unplug your unit remove the motor shroud with a long shaft flat tip screw driver you'll be able to pin point the problem with this tool.
Now locate front shaft and rear roller tension adjusting bolt ( refer to owners Manual) plug in unit, start unit and touch flat tip on the shaft and place your ear on the handle the noise will be amplified and you will be able to locate the noise repeat this procedure on the other above mentioned components if problem is not found. GOOD LUCK!
Jul 31, 2010 | Proform Exercise & Fitness
Noisy precor treadmill motor
that sound is due to the bearing failing inside the motor this is cause by capacitance discharge thru the armature thru the bearings. these unit can be rebulit I 've done plenty
Apr 13, 2010 | Precor C956i Treadmills with HR /...
Proform 400GI Treadmill making a very loud noise, which is worse when using speeds between 2.7 and 3.1, noise is so loud can't hear tv when turned up to full volume. It makes the noise without anyone...
This definitely sounds like the drive motor. One way to check is to remove the drive belt and run the motor without the walk belt connected. Obviously if you still have the noise it will be a motor issue. If not then it will be one of the 2 rollers. Good Luck! Tim
Nov 04, 2009 | Proform 490GS Treadmill Walking Belt
Very noisy on spin
hello there.....the noise you hear is most likley due to failed drum bearings or something trapped in the drum....test as follows....isolate machine....open the door...test the drum for up and down lift...there should be no movement at all....if all is well here...remove the lid and remove drive belt....spin the drum by hand and listen for any bearing noise (rumble). or metallic sound of something trapped in drum..if all is well here refit the lid temp...Then select spin and start machine...if motor is noisy then the problem is with the motor bearings
regards Sir Galahad
Sep 21, 2009 | Hotpoint WMA64 Front Load Washer
Noisy treadmill.
lose some weight -lol-its working for mine,cheers!-mine is noisy too-place a square of shaggy carpet under her- i find mine slips somewhat too even tightened-ok ill lose some more!
Jun 30, 2009 | Bowflex Treadmill Series 7
Hoggan Sprint Runner ltreadmill very noisy
I am the marketing director for HOGGAN Health. Check out the youtube.com video below, it will show you how to re-track the runner. If that doesn't help, call us: 800-678-7888 or visit HOGGAN Health Runner Treadmill for more info.
Jun 17, 2009 | Sportime Hoggan Sprint Runner Treadmill
How do you fix a noisy whirlpool dish washer DU1100XTP(Q) ?
A hard object has entered the wash module (on some models).
When the object is ground up, the sound should stop. If the
noise persists after a complete cycle, call for service.
Mar 12, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Proform XP 580 Trainer Treadmill Logo
23 people viewed this question
Top Proform Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
Owen Barnes
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
