Question about Toshiba Satellite M100 Notebook
Uninstallation Problem i installed nortan 360 antivirus software, but during insatallation there was an error in activating the software, i am trying to uninstall the software through control panel add or remove the program, but it is not uninstalling and i tried to delete the files directly from the program folder, it does not delete, it shows the message that "acces denies the file cannot be deleted make sure the disk may not full or write protected" please help me how to uninstall or delete, Thanks!
  • 81 Answers
Re: Uninstallation Problem
First thing to do is  Back up the Registry. I'll be saying more about the Registry later. But suffice it to say that the presence of uninstalled security
software in the Registry can conflict with newly installed securitysoftware and cause system freezes. So can folders of "uninstalled"programs for that matter. Once again, go to Start, then click on "Run". Type in "regedit" Go to the top of the Regedit window.  Click (+) next to HKEY_CURRENT_USER. Go down the thread until you see  Software.
Click on Software and scroll down the thread until you see Symantec. Right click on Symantec and choose "Delete". From there go down to HKEY_LOCAL_MACHINE and repeat step
3. Restart your PC.  Click (+) next to HKEY_LOCAL_MACHINE, now: Click (+) next to Software,Click (+) next to Microsoft, Click (+) next to Windows and Click (+)next to CurrentVersion. Select the Run folder.  Right-click and delete each Symantec entry you see (if present). Restart your PC.
Posted on Jan 23, 2009
  • 4,889 Answers
Well if you want to delete click start->run->type "msconfig" In the configuration window click on services tab. Uncheck all the entries named symantec or norton. Now click on STARTUP tab and uncheck the symatec startup entries. Now restart the computer and try deleting once again. By the way that access denied message is displayed because the file u want to delete is being used by some symantec service if unselect and restart they will be terminated so that you ca delete the folder.
Posted on Oct 08, 2007
  • 457 Answers
Its a devil of a software to uninstall try in safe mode.....doing the things you first did including the program files etc....
0 characters
3 Points
I have a problem with my laptop acer travelmate 550. Display an error number 0280 previous boot incomplete default configaration used press F1 to resume, F2 to setup
Possible that PC is hanging up as there is fault on the OS ( operating system) or a virus in the OS. Also it is possible that the back up( CMOS) has low voltage or the memory card is a suspect. In this case you need to check the voltage and also try and swap a memory card. If not the OS is a suspect.
It is best to go for a paid antivirus software which you can get in a package. Personally we are not recommending any particular company but you can try with Avira, Antivir, AVG, Kaspersky. It is always best to install the antivirus when the installation of the OS is done.
Now before this you can open the internet options in the browser and clean all the cookies, temporary internet files, defragment the drives and RESTORE the PC to an earlier set date.
You can use a registry cleaner like Advanced system care. Download from the site and check you system for corrupt files. Also use a good antivirus software which is active to keep your system performing without an attack on the OS. Remove all unnecessary programs installed which you do not use all the time and clean up the drives. This will free up the space and make your system faster.
If there is no response but the PC tends to work slower and occasionally hanging when a program is being executed then you might have to install the OS once again. Install the OS and then an antivirus before the drivers of the PC is installed.
Thank You for using Fixya
Sep 20, 2011 | PC Laptops
Transform your windows xp to windows 7
Seven Transformation Pack will replace many of the resources in Windows Vista/XP/Server 2003. It can change such things as:
Boot screen
Welcome Screen / Logon Screen
New msstyles files (visual styles)
New desktop and file icons
New toolbar icons
Progress Dialogs
Sounds scheme
System Tray icons
New Wallpapers
Some Windows 7's popular features
And much more
Changes in Version 5.0
-Added automate User Account Control deactivation upon checking
-Added changing desktop wallpaper during transformation
-Added completed set of Windows 7 wallpapers
-Added Gavatx's Rainbar in Vista compatibilities exclusion list as there's already Windows Sidebar in Vista
-Fixed bugs that some options are not saved in registry during installation
-Fixed currupt system sounds scheme in Windows Vista after uninstallation
-Fixed logon screen system files modification to not change system font in non-English MUI (Requires uninstall for older version)
-Fixed setup files detection glitches in Windows XP/2003 x64 Edition
-Fixed system files modification critical error for integration with Windows XP/2003 x64 Editions
-Fixed system files modification compatibilities with non-English edition OS
-Fixed Welcome Center not running on startup after installation on x64 operating system
-Fixed x64 system files modification incompatibilities for some systems
-Improved transformation process for faster and better performance (This involves a lot of work in various places and they're all technical stuff)
-Optimized Deferred Launcher's startup sequence and delay time for better resource utilization
-Removed minimum hardware requirements for 3rd-party applications but still keep recommended specifications in list
-Shortened installation sequence UI for smoother process
-Updated 3rd-party applications hardware requirements specifications
-Updated screensaver to Windows 7 logo
-Updated TrueTransparency
'-Core program to version 1.4
'-Optimized blurring interval for better system performance
'-Rebuilt SevenStyle skins based on Seven structure with real reflections
'-x64 application support
-Updated ViGlance to version SE2 build 1276
'-Added Drag shortcut support
'-Added Hyprid Jumplist support
'-Added Shift+Left click opens new instance
'-Fixed 64-bit application compatibilities
'-Fixed multi-monitor compatibilities
'-Fixed UI and code refinements
'-Optimized timer interval and program configuration
'-Updated default skin
-Updated ViStart to version 2.0 build 3738
'-Added blur support (experimental)
'-Added run functionality in searchbox
'-Optimized programs discovery routine with better program support
'-Optimized UI rendering for better performance
-Updated Welcome Center
'-Added back button in ui navigation control
'-Added system files repair list in repair page and Repair alert with red text
'-Fixed icon and text UI placement
'-Removed using system files from backup source in uninstallation
'-Reworked Removal UI with installed components verification to ensure safety of uninstallation
'-Updated backup files status indicator to available/not available (no need for overwritten check)
'-Windows 7's additional user pictures and wallpapers will no longer be removed (few MBs being too insignificant for TB storage)
-Updated UXTheme patching engine to deepxw's universal theme patcher
Download it from here---
It works perfectly and tested by me...
For more softwares and antiviruses go here
on Mar 28, 2011 | PC Laptops
Norton Advantages & Disadvantages
<p>Advantages & Disadvantages:-<br /> <p>Though Norton anti-virus products and its various versions are one of the best protection software, Norton anti-virus software has some advantages and disadvantages.<br /> <p> <br> <p>Advantages: -<br> <p>When Symantec redesign Norton for Widows compatibility, Norton becomes one of the best protection software in the market. With its every release Norton introduced new features or upgraded features. Norton release new versions almost every year. Some unique features of Norton anti-virus are Sonar protection, File Insight, Network Insight, Power Eraser tool etc. which provides more reliable protection against viruses and other malicious code. It can run at background to work silently. It will warn you before running or installing malicious programs. It can protect your computer spreading viruses from your Facebook feed, e-mail attachments. Simple user interface will help you to work more easily. Norton provides PC utility tool to tune-up your pc and Backup and Restore tool. You can solve your problems online from tech support, where you can find answers for possible problems, use-one-click-solution-first to solve your problems manually and customer help desk, where you can interact with tech support personnel for your query.<br> <p> <br> <p>Disadvantages:- <br> <p>While Norton offers variety of benefits to its users, there are also some drawbacks as well. Prior to the 2009 version of Norton anti-virus, reviews claimed that the software required considerable memory to run, this slowed down the overall performance of the computer. Computers that have an old copy installed might experience this resource issue.<br> <p> <br> <p>Uninstalling is another drawback of Norton. If you attempt to remove Norton Antivirus, the uninstallation process proves difficult. This is one area where Norton fails to compete with its competitors, according to PC Antivirus Reviews. Reviewers asserted, "Uninstalling Norton is nowhere near as good as uninstalling McAfee, which sets the standard for fast, clean, easy uninstallation for anti-virus software."
on Mar 17, 2011 | PC Laptops
Not instal kespersky antivirus,now how to instal that
Sounds like you're having troubles installing Kaspersky Antivirus (KAV). You will need to uninstall any existing security software before installing KAV. Restart the computer. I recommend downloading the latest version from After downloading the installer, run the application. It will ask you for a product key to activate the software, so you will need to have/purchase that.
Mar 24, 2011 | PC Laptops
Tried to install nortan on sony vaio laptop next day i tried to start laptop it shows the system menu but then image error pops up with a black screen. cannot use laptop i think i may have lost data....
There might be a problem during the installation of norton. What you can try to do is to perform a system restore and bring back the computer to an earlier date before you install norton or befor you get the problem. Here are the steps on how to do it:
  1. restart the computer
  2. press F8 key repeatedly when you see the VAIO logo until you get the screen that says Advanced boot option
  3. use the arrow keys on the keyboard to highlight safemode then press enter
  4. when it loads to safemode, go to start menu
  5. go to all programs
  6. click accessories
  7. click system tools the select system restore
  8. on the system restore window, click next
  9. in choose a different restore point, you will see list of dates or calendar where you can pick a date that you want to use in restoring back the computer settings.
  10. click on the next button again
  11. click finish
the computer will start restoring the settings back to the selected date which may take for a few mins(2mins to 10mins usually). system restore does not delete any personal files/documents. It only undo software applications, updates and settings.
Sep 27, 2009 | Sony VAIO VGN-FJ270/B Notebook
Ended a process and cant login, HELP PLEASE
Try to boot your system in safe mode by pressing F8. Try to uninstall anti virus. Press Start>Run>Regedit> Go to HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run Delete all values of Norton Antivirus and reboot your system. Hope this will work, otherwise new windows installation will resolve this issue.
Jul 22, 2009 | HP Compaq Presario CQ60Z Notebook
Antivirus 360???
check the control panel its in the start menu
choose add/remove programmes.
Mar 07, 2009 | HP G70-250us Notebook
Recovery Disc will not work
That's terrible. The right soution should be to try Ashampoo Uninstaller or similar software that gets off EVERY BIT of unwanted software. Use function "Install new applications". It asks for setup.exe, install.exe or similar executable file, that runs Antivirus 360 installer. Point to it. After all the installations completes, "Ashampoo Uninstaller" logs the installation. Now uninstall the unwanted program using "Uninstall logged programs". That's it!
If you really damaged your operating system, do buckup of your important data and reinstall OS
Feb 04, 2009 | Toshiba Satellite A105-S4034 Notebook
Initializing error :registry value is not of binary type
First of all, its AVG, not AGV. Now the solution.
You may be trying to install AVG when you have already one antivirus program running. OR you had once installed AVG sometimes in the past, but uninstallation was not properly done. Hence it is showing registry key error.
1. If you are running any anitvirus prog now, first uninstall it. Then restart the machine.
2. Now you try install AVG. it should install. if not, try the following
Go to system restore and create restore point for safety.
go to run and type regedit and then enter
Press cntrl + F for finding earlier registry keys of AVG. Try to find out all old registry keys amd delete them all.
Restart the machine. Its DONE.
Jan 25, 2009 | HP Pavilion dv6000z Notebook
PC Laptops Logo
91 people viewed this question
Top Toshiba PC Laptops Experts
Brian Sullivan
Brian Sullivan
john smith
Are you a Toshiba PC Laptop Expert? Answer questions, earn points and help others
