Question about Vacuums
Riccar n2100 need extension hose
RicCar vacuum overheating
If your Riccar is overheating you most likely have a full bag, clogged filters or a clog somewhere in the hose or vacuum tubes.
Jun 17, 2017 | Riccar Vacuums
How do you replace a vacuum hose on a Riccar upright Vacuum.
Riccar Tandem Air models have a hose that has releases to push to remove the hose. Most Vibrance & 8000 series and older series vacuums have the hose attached to a swivel on the back of the vacuum. The hose can be unscrewed from the swivel. To remove the swivel you need to remove the vacuum bag inside the dust compartment, you must compress the tabs holding the swivel to the body to be able to pull it out.
Aug 08, 2016 | Riccar Vacuums
What size replacement belt for riccar 1700 vacuum
You need to contact your local Riccar dealer. They are not available except from Riccar dealers.
www.riccar.com
Sorry.
May 30, 2014 | Riccar 3623210300 RC 1700, 1800 Full Size...
Riccar 8995 no suction in hose
drop a quater thru hose make sure it goes thru
May 18, 2014 | Riccar Vacuums
I think you mean it's an 8955, Riccar has not had a 8995 model. If there is no suction in the hose it has to have something clogging it. Open the little round opening on the back of the vacuum where the hose attaches to see if you have suction there.
HOw do I replace the riccar 8850 hose?
Inside the bad compartment you can see the swivel portion sticking through. You will need to take a screwdriver and push in on the tabs on the swivel to release it so it can be removed from the body of the vacuum. The new hose ans swivel will just push into the hole and the tabs will hold it in.
May 04, 2014 | Riccar 8850 Vacuum
Riccar N2100 vacuum hard to push
Start by replacing the belt, check the brush roll while you have it out.
Apr 12, 2014 | Riccar Vacuums
The switch to my Riccar 1500p hose is broken for the 2nd time. I don't want to replace the entire hose again, where can i get the switch and leads?
Take the screws out to take the handle apart. Remove the switch and take it to your hardware or local vacuum to to get the correct replacement.
Apr 03, 2013 | Riccar 1500 Simplicity S24 And S20...
Riccar rc1100 won't turn off
I am an riccar dealer, and you either have a short in the wire leads from front of vacuum to circuit board or a bad circuit board which if so the boardd will have to be sent to manufacture to be rebuilt as there are no new circuit boards available. if not under warrenty which i doubt since riccar hasnt made these models for a while. would recomend replacement with either sunburst or moonlight model as they are a comparable replacement to the repair. or just simply just plug and unplug machine, if it doesnt bother you to do so. If more questions email me at drago640@yahoo.com subject riccar, or go to www.riccar.com to locate nearest dealer
Mar 22, 2008 | Riccar RC1100 Compact Vacuum
Vacuums Logo
19 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
