Question about NEC DTU 8D-2 Corded Phone
Can't turn off night mode
When a call comes in the night mode is set and automatically goes to voicemail prompts. How do I turn off night mode?
My mobile ... Kogan Agora8double sim does not ring when calls come in but goes directly to voicemail
Check the ringtone volume, and make sure its turned up. Also make sure you haven't set your phone to "do not disturb" or Airplane mode. Some phones have a driving mode which is like do not disturb.
Jan 22, 2018 | Cell Phones
I cannot figure out how to set up my voicemail for my alcatel one touch. How do I do it?
Voicemail isn't set up by the phone it is set up by your cellular provider. Usually is a paid for add-on to your plan. You need to check you have it. Then you dial into the number and set it up.
Search Results Once voicemail is set up, new messages will be played automatically. ... To access the voice mail system after the initial setup, press and hold the 1 key for 2-3 seconds. If prompted, enter the voicemail password to access new messages.
Show Me How on your Alcatel ONETOUCH Fling ' Boost Mobile
devicehelp.boostmobile.com/scenario/ONETOUCH.../Set_Up_and_Access_Voicemail
voicemail set up for Alcatel one touch Google Search
Dec 10, 2017 | Alcatel Cell Phones
We have a Uniden DECT 6.0 series phone and voicemail service through AT&T. For some reason, the base answering system has been picking up calls, seemingly at random. Sometimes the base picks up, s
Hi Jessica,
I would suggest contacting Uniden rather than AT&T. I included their contact information below as well as 3 issues that may be going on here.
Uniden Technical Support
1.800.297.1023
M-F 8:30am-11:45pm CST & 2:30pm-4:45pm CST
Ask a Question: http://mycusthelp.net/UNIDEN/_cs/QuestionAsk.aspx?sSessionID=&
1. Are you getting messages? If not, the voicemail may have set to "Announce Only." This means the Answering system will answer the call, but will not allow callers to leave a message. If so, there may be an LED "A" lit up on your base. You can change this setting in the Answ setup --> record time.
2. Does it occur after a particular number of rings? You can set the voicemail to answer after 2, 4, or 6 rings. This may be the problem.
3. Does the phone ring at all? It is possible the phone is in Silent Mode. You can set silent mode to last anywhere between 1-9 hours or keep it on all the time. If it is set to a particular number of hours, the phone will exit silent mode automatically. If not, you need to hold # to deactivate it. I don't think you can set silent mode to turn on automatically on a schedule, but this is something you could ask Uniden about.
I hope that helps. Good Luck!
Jan 08, 2014 | Uniden D16602 Twin Cordless Phone
How to change recording on day/ night mode
This depends what voicemail you have, SVM OR TVM. and you need to know what group rings in each mode SVM day *47 (voicemail extension number) (PIN number) *38801 record STORE NIGHT *47 (voicemail extension number) (PIN number) *38811 record STORE TVM voicemail extension number (500 or 200) #6* (ringing group number) option 3 then 1 then 1 follow the prompts
Aug 12, 2013 | Panasonic BTS KX-DT343-W-NR Digital Corded...
When the Norstar m7324 phone is set to night mode after business hours, the caller goes direct to voicemail when the caller dials an extension. How do I change it so that it rings at the extension a f
Night service will only control if AA to answer (main greeting) or human, you!.
If people enter extension and it goes straight to vmail then the user invoked that option (Feature 987) which is what you should do when you leave your office.
Oct 11, 2012 | NorStar M7324 Telephone
Forgot unlock code voicemail kyocera jax
Go to this link...
http://www.virginmobileusa.com/resources/phones/prepaid/manual/kyocera-aw-jax.pdf
DOWNLOAD THE MANUAL FOR FUTURE REFERENCE!! LOL
Scroll down to page #39 to where it says Use Voicemail and follow the instructions!! As per the service tech I spoke to on the phone to find this link, following these instructions will automatically erase your old voicemail unlock code as well as any as yet unheard messages.
Just in case anyone still has difficulty in finding the instructions.....
Set Up your VoicemailBefore your phone can receive voicemail messages, you must set up a 4-10 digit passcode and record a personal voicemail greeting.When you have set up your voicemail, all unanswered calls to your phone are automatically transferred to voicemail, even if your phone is in use or turned off.1. Press and hold the 1 key.2. Follow the system prompts to create a password and record a greeting.
Check your Voicemail
When you receive a voicemail message, a
notification with a voicemail message icon
appears at the top of your screen.
• At the voicemail notification, select Call to call
your voicemail number and follow the system
prompts to retrieve the message.
Select Ignore to clear the notification without
checking messages. The notification icon
remains on top of the screen until you listen to
the message
• When only the voicemail message icon
appears on top of the screen, select
Voicemailand follow the system prompts
Best of luck!!
Susan
Jan 27, 2012 | Kyocera Jax Cell Phone
How do you erase and change after hours greeting?dhalman
Call voicemail by pressing the Intercom button then dialing 777, when it answers login by dialing 99# followed by the password(default is 1234#) then press 9 for system features menu. Press 3 to choose Automated Attendant, the system prompts for the Auto Attendant number(1-4), start with Auto Attendant 1,if you do not know which one is being used by pressing 1. Press 2 to choose Night Menu, press 6 to change the Night Menu prompt. Lift the handset, press 1 to record your new Night Menu prompt using the handset, press 1 at the end of your recording. To listen to the new recording press 23, to immediately re-record press 21, to save the recording press *#. Press # to save all programming changes and activate new recording. Press *7 to return to system features menu or hang up to end programming session.
Changing the Auto Attendant prompt should be done when you are able to do a test call on each line to verify that you have changed the correct prompt(in your case after hours or by putting the system in After Hours mode manually to ensure the After Hours prompt is active) for each line being answered by the Auto Attendant. By default all lines are assigned to Auto Attendant 1, if your system has been modified to use a different Auto Attendant for some or all lines, you will need to repeat the above procedure for the Auto Attendant being used. If at any time you get lost or confused while in the voicemail programming, hang up and start over. Once you get comfortable with navigating the voicemail programming, it gets easier. If you have trouble send a comment, I will try to help.
Feb 10, 2011 | Lucent PARTNER18 Corded Phone
How do i put the whole system in voicemail or night voice mail on a panasonic KX-T7433
The simple answer is you can force the PBX into night mode by dialing 782 on the main phone. However, it does requre programming, so if you don't have night ringing and voice mail defined, then it still won't work. 781 goes back to day mode.
Carl
Sep 21, 2010 | Panasonic KX-T7433B Corded Phone
Set password for voicemail
1.Turn your phone on and press and hold the "1" button on your keypad in normal standby mode.
2.Enter your four digit passcode with your keypad and press *. If you do not yet have a passcode, you will be prompted to create one.
3.Press "1" to listen to the options in English, or "2" to listen to them in Spanish.
4.Press "1" to record your own voicemail greeting. Wait for the beep and speak your greeting into your phone. Press "1" again to confirm your greeting.
5.Press the red "End" button on your keypad and your voice mail will be set up. Press "1" again or at any time to listen to your voicemail by entering in your passcode and following the prompts to navigate your different messages.
Let us know if this helps ...
Thanks
Shiv.
Aug 23, 2009 | Samsung Hue SCH-R500 Cell Phone Car...
When an incoming call comes in my motorola rokr rings once and then go directly to voicemail even if I press the answer key. What do I need to do to fix this problems?
Possibly it is on aiplane mode, to turn that off
Press menu key
scroll to settings then press the joystick
scroll to airplane mode, then press joystick
scroll right to turn airplane mode on / off
set prompt at startup to turn on or off when you turn the phone on or off here.
Also~
ANSWER OPTIONS:
Press [_] > settings > incall setup > Answer options > multi-key > on or off
Cheers
Apr 29, 2009 | Motorola Mobility ROKR E8 Cellular Phone
NEC DTU 8D-2 Corded Phone Logo
Top NEC Lands Phones Experts
Craig Butler
Craig Butler
Oloyede Monsuru
ray gallant
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
