Question about LG W2246S-BF 21" Monitor
IC power LG W2246s
Hi.I can read number IC power it's broken. Thanks
LG FA 162 doesnt power on.
Dry electrolitic condensator on main power unit or short circuit on speaker cables
Nov 27, 2013 | Sony MHC-GX555 Mini Hi-Fi System Shelf...
Bose burned Integrated Circuits
I have the same problem here, this IC is shorted, is made by International Rectifier, it must be a inverter IC the number printed should be a ghost number because I can't find it, maybe BOSE ask IR to put a nonexistent number to block people fix it, the number by the way is P834 HA1M1 here is a photo also, if someone knows about which other number works here let me know please
Aug 13, 2013 | Apple Bose SoundDock Series II Digital...
Jamo sub 660 wont come on
Hi,I have the Jamo sub 660 and it won't come on,I took it to my technician,and he told me that it has a broken ic,the broblem is that he cannot replace it cause the number on it is scratched,does anyone know what the number is pls! Thanks in advance Joseph
Aug 25, 2012 | Jamo Audio Players & Recorders
Blinking red light
You did not give a model number. If this is an older model Sony, I would be concerned with the audio IC with standby. This IC will be of the TDA-XXXX series. I doubt if you have a problem with power supply. If you can locate the IC mentioned, and read the TDA number, cross reference this in an NTE semi conductor manual. If it does tell you it is an audio IC with standby...replace this IC with the cross reference. Be sure to check any grounds that need resoldered in the same area as the IC mentioned. Thanks for asking and show a few hands of support!
Mar 26, 2011 | Sony Televison & Video
42 inch LG will not power up after moving, there's no red or blue to indicate power, i've tried different outlets etc..
There are two possible causes for this problem, either AC cord is internally broken or power supply board got defective for some reason.
Let me know model number of tv to find out helpful info/ suggest a solution.
Thanks.
Feb 16, 2011 | LG 42LH30 42 in. LCD TV
THIS TVFACEBOOK HOW DO U GET UR PIN GOT N LG LE5900
hello i want to know about TCL 21e20 power ic regulator description about the ic coz i the ic is broken i cant read the description please help me
Dec 14, 2010 | Televison & Video
My LG rear projection TV RE40NZ60RB colour is ghosting with three colours separating. Colour converging does not rectify
There is a problem with the convergence circuit. It can be as simple as poor solder connections at the pins of the convergence IC or a defective IC. If you can solder, you can fix this yourself. Please confirm the model number of hte set and I'll provide the part numbers etc. required to resolve this.
Thanks,
Dan
Aug 20, 2009 | Televison & Video
Hi my philips television model number 34PT 5693 just sudden can't turn it on and the 'on' button was no light at all. I try to change the fuse inside the television and just blow off the fuse.
Check the mains rectifier ( 4 diode's or 1 block ) for short circuit ,also check the NTC/PTC resistor ,the power FET and power IC,if the last 2 parts are broken then measure al high omhic resistors between 300V and IC.
Jul 27, 2009 | Televison & Video
Philips 60 inch projection
The I2C message that you get means the Inter IC communication bus on the system board has gone bad. Replacing the IC would not solve the problem.Philips patented this technology to reduce the number of ICs on the systemboard.There would be a physical I2C chip on the motherboard.
You can read about the technology on the post by philips
http://www.nxp.com/acrobat_download/applicationnotes/AN10216_1.pdf
I would suggest update the firmware on the board, or try replacing the I2c interface controller chip.
Thanks
Proton
Jul 28, 2008 | Televison & Video
LG W2246S-BF 21" Monitor Logo
32 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
