Question about Electronics - Others
Woxter pocket x div 35 firmware - Electronics - Others
2 Suggested Answers
SOURCE: woxter i-cube x-div 35 xp
Have u tried the new firmware?
http://www.woxter.com/en-gb/products/view/48/Woxter_i_Cube_X_Div_35_XP_Pro/support
I'm looking for installation instructions ...
Posted on Jun 12, 2010
Tip
PS3 Recovery Options Screen
A lot of PS3 problems can be solved by accessing the PS3 Recovery Menu. You can do that by
1. Turn off PlayStation 3.
2. Hold the power button down until the system turns on and then off once again.
3. Once the System has been shutdown, re-press power until you hear 2 consecutive beeps .When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
7. Choose to 'Restore File System' and follow the process through.
If that doesn't work you can try some of the other options.
  • 1)Restart SystemThis option boots your system as normal without changing any settings or files.
  • 2)Restore Default Settings.Restores all default settings on the PS3 for networking, clock, video, etc. For a full list of the restored settings you can look under settings> system settings > restore defaults on your console. This should not eliminate your game saves or other saved content, including your user login.
  • 3)Restore File SystemThis will rewrite the files the PS3 uses to boot. This feature will help if files have become corrupted and are not allowing the console to boot as normal. This should not erase any of your saved data or settings.
  • 4
  • )Rebuild DatabaseThis can be a usefull feature if you have lost files on your system for no apparent reason. Try using this feature to see if it can restore those files. This will also rewrite corrupted files within the database, potentially eliminating future issues. This feature should not erase any of your saved data or settings.
  • 5)RESTORE PS3 SYSTEMThis will restore your system to original including, formatting and erasing all of the data on the HD and returning all system settings to default. This will not take your system back to a previous Firmware release. Use this option as a last resort, unless you have nothing on the console that you want or you want to erase everything on the console, do not use this option.
  • 6)System UpdateThis will allow the user to update their console with new firmware via a Flash drive or other portable media. This will not allow you to update via an internet connection. This can usefull if your system has become corrupted to the point you can not boot. You will need a portable media device with the correct firmware and in the correct file structure to complete the upgrade. For further information on using portable media to upgrade your system please see our section on upgrading your Firmware.
  • on Nov 27, 2011 | Microsoft Video Game Consoles & Games
    No media being played on TV
    reformat the hard drive you have lost the fat file and, the display and, audio drivers
    May 28, 2009 | Electronics - Others
    Tip
    Why Your Front-Load Washing Machine Sucks.
    After spending a year working as an in-home repair technician fixing washing machines, dryers and the like, I'd like to say, "Thank You." Thank you for buying that gigantic POS front-load washing machine that probably cost more than both my washer and dryer combined. You kept business good! During my short tenure I would estimate that approximately 70% of all of my service calls (covering powered lawn equipment, powered exercise equipment and laundry) were for front-load washing machines. Here are some of the most common malfunctions you paid me >$60 to come look at:
    1. My Washer Won't Drain
    This was one of my most common service calls, and one I dreaded the most. The cause was typically a foreign object jamming the drain pump, causing the water to get stuck and preventing the door from unlocking (so your laundry room didn't flood when the water poured out the door). I've seen all sorts of items lodged in the drain pumps, such as children's socks, bra underwires and other miscellaneous items, but the most common offenders were coins and small pencils. The repair consisted of me sucking water out of the drain pipe with my small, portable wet-dry vacuum and usually required several trips out to the tree in your back yard to dump the stuff. BTW, if you've never experienced it before, week-old dirty clothes water (especially with fabric softener in it) smells HORRIBLE. After sucking out as much water as I could the pump repair would be fairly straightforward, but there would always still be some residual fluid in the pump housing and lines that would spill out onto your floor. Not much I can do about that; the pump is on the very bottom of a very heavy machine and getting any sort of bucket underneath was out of the question. Moral of the story? Check those pockets and then recheck 'em!
    2. My Washer (and Clothes!) Stink
    Ah, you front-load washers and your wiley ways! Sorry to say this but YOU are the cause of this problem. By closing the washer door after moving the clothes to the dryer, you did not give the washer an opportunity to air out and residual moisture in the drum and drain area caused the rubber door boot to grow a friend. This mold will eventually grow on even the mold-resistant door boots if subjected to these conditions long enough, but there's something you can do about it. At LEAST once per month, whether there are clothes in the washer or not, run a load on HOT water with bleach. You can also take a diluted bleach-soaked washcloth and wipe the door boot out once in a while. Most importantly, leave your washer door open a little between uses... your clothes (and your nose) will thank you.
    3. I Have Some Sort of Error Code
    This comes with the territory of computer-controlled appliances and should be expected. Unfortunately for you, many repairs involve replacing the integrated motherboard and not for a small amount of money... most circuit boards were over $200 in parts alone, plus my service call fee and the labor to replace the parts...
    4. The Control Panel Stopped Responding
    This problem can be caused by the same potential problem as #3 - fried electronics due to a surge in your power supply. In other words, you wouldn't plug your computer into the wall without a surge protector in-line, so why would you plug your computer-controlled washing machine directly into the wall? (note many laptops have signal conditioners integrated with the power supply, performing the same duties as a surge protector.) It is cheap insurance to purchase a single-outlet surge protector, and really if your dryer has a digital display and input keypad it needs one as well. The second-most common cause for this malfunction was a stuck key; before calling the repair guy, try pressing each of the buttons (soft, hard, sideways, whatever you can try to get a potentially stuck button unstuck) to see if it will release.
    5. My Machine Walks Across the Laundry Room
    Ok, so this is a problem that some top-load machines have as well, but front-load machines amplify it much more so. Because of the nature of the front-loaders, they are very heavy machines (concrete counterweights on the wash basket) and can get off-balance pretty easily during the spin cycle. There are things YOU can do to minimize this, but sometimes you are just the victim of your environment. First and foremost is to wash items sorted by bulk, not color (or at least color secondary). This means wash jeans with other heavy items like towels. Keep in mind the weight of the items need to be roughly equivalent when the item is WET. Don't wash sheets with blankets. Put your pillowcases in with the t-shirts. You get the idea.
    The other primary cause of these problems stem from the condition of your floor. Front-load washers require a very sturdy base, like concrete or hardwood. Floating floors (Pergo, for example), second-floor installs, mobile homes and other "soft" floors have too much give and will allow the device to shimmy itself right out the door. Those fancy pedestals you bought to elevate your machines and give you some storage are not helping matters either... they raise the center of gravity and amplify the problem.
    Lastly ensure the machine is properly balanced. Yes, you may have had the "experts" install it for you but that doesn't mean that A) they took the time to actually adjust the feet to the contours of your floor, or B) that the locknuts were set to prevent the feet from adjusting themselves. Crawl on down there and check to see if you have wobble with the machine off. If so, you're in luck - it's an easy, cheap fix!
    In conclusion, I know that front-load washers have some benefits - less water consumption, more energy-efficient, larger capacity - but my 10-year-old top-loader is still running strong and hasn't required any maintenance yet. You can mitigate some of the potential for problems by following my advice, and good luck - maybe we'll never meet someday.
    on Nov 23, 2011 | Washing Machines
    Tip
    How to unlock your Nokia N series phones.!!
    Hey mate, try this... sarkar raj's tip
    FORMATTING CODES
    *#7370# .......... Format phone...[Hard-Reset]
    *#7780# .......... Factory Reset
    Note:
    Format phone restores phone to as if it was out of the box. Retains firmware version and operator Variant changes but wipes all applications you have installed. Does not format the memory card so any apps on there may reinstall once powered back up again.
    Factory Reset resets all settings to defaults but keeps any applications you have installed and photos etc. Both need the Security code, which, by default, is 12345.
    Another way to format some symbian phones: Power off phone. Press and hold Green, * and 3 and keep them held whilst powering on and for a few seconds after, if kept pressed this formats without asking for Security Code confirmation. ->I just re-read your post, you will probably have to try this method.. make sure you back everything up first!!
    on Aug 16, 2011 | Nokia N95 Cellular Phone
    Woxter i-cube x-div 35 xp
    Dec 21, 2007 | Electronics - Others
    Tip
    Driver updates
    Sometimes after a fresh install of a new operating system, the system won't recognize a certain device. If this happens then you need to update drivers in device manager.
    click start,right click computer,click on manage,click on device manager,look for yellow ? and ! symbols,right click,update driver.
    (note) you have to be connected to the internet for the update to work.
    Hope this helps.
    on Jul 18, 2011 | Microsoft Computers & Internet
    Tip
    How to activate Mobile INTERNET service (GPRS) ------>For most of Mobile Phones
    To activate the INTERNET service in your mobile (GPRS or WAP)
    service....
    You need to set up the service in your mobile first.
    The correct settings of GPRS are provided by the SERVICE
    PROVIDER (OPERATOR,CARRIER).
    You need to contact your Service Provider by calling them and ask for
    GPRS or WAP settings of your mobile (Every Mobile Model has its own
    settings almost)
    Then they will send the settings to your mobile as a text message.
    After they been sent to you,Just save them and run if you been asked to
    run.Then turn your mobile off for 2 to 4 minutes.
    Then turn your mobile on.
    Now the INTERNET service in your mobile is activated.
    on Jun 11, 2011 | Cell Phones
    Electronics - Others Logo
    29 people viewed this question
    Top Electronics - Others Experts
    Are you an Electronics - Other Expert? Answer questions, earn points and help others
