Question about Sharp XE-A106 Cash Register
Z-report problems I cannot run a z-report. When I turn the key to z/pgm i just see four dashes like this: ----
  • Sharp Expert
  • 592 Answers
Need to input manager's pasword. default is 0000
good luck
Posted on Nov 26, 2013
Xe a102 manual
You have a Z mode password. Type the password before printing the report
Nov 05, 2013 | Casio Parts Cash Register PC Desktop
Casio TE 4500f till register, trying to print Z report but it says error code 001 - wrong mode and will not allow me to clear. I have tried turning key back, even tried PGM key according to user manual...
You have turned the key before you finished in the previous mode. Turn the key until the mode error stops (not counting the off position). That is the mode you need to finish. Try pressing SUBTOTAL in this mode and then turn the key
Sep 12, 2011 | Casio Parts Cash Register PC Desktop
I am scanning and can't pick up ANY signals how do i program my handheld radio shack 82 200 channels scanner
Hi my name is John. Turn the unit on, press PGM,enter the channel you want to store the frequency in (1-200), press PGM,use the number keys and DELAY/. to enter the frequency you want, including the decimal point. Press ENTER to store the frequency, and your done..Get your frequency,s here www.RadipReference.com ..or www.RadioFreq.com.. Hope this was helpful.....Rate this solution on the four thumbs-up....good luck.. John
Oct 11, 2010 | Radio Shack Pro-82 Scanner
Car cranks but dose not start, there is no power to distributator or fuel pump
I suspect the at this point, the main relay is defective. This relay controls power to fuel and spark circuits.
The PGM-FI Main Relay is actually comprised of two individual internal relays. When the ignition switch is initially turned ON , the Powertrain Control Module (PCM) supplies ground to the PGM-FI Main Relay. This ground triggers one of the PGM-FI internal relays that sends battery voltage to the fuel pump for two seconds to pressurize the fuel system.
When the engine is running the PCM supplies a continuous ground to the PGM-FI Main Relay. The supplied ground keeps the relay in the "closed" position providing electrical current to the fuel pump, keeping the fuel loop pressurized while the engine runs.
If the engine is not running with the ignition on, the PCM cuts the ground to the PGM-FI Main Relay, causing the relay to "open" and stop the electric current flow to the fuel pump. As mentioned previously, if the engine is not running, the PCM will only supply ground to the PGM-FI Main Relay for two seconds when the ignition switch is initially switched to the ON position.
The PGM-FI Main Relay also supplies electrical power to the Idle Air Control (IAC) Valve and to the fuel injectors.
TESTING
If the engine starts and continues to run, the PGM-FI Main Relay is working and does not need to be replaced.
  1. Locate and remove the relay.
On some models of the Civic and Civic del Sol it is located to the left of the steering column under the dash. Many later models position it either near the passenger right side kick panel under the dash or by the driver left side kick panel up under the dash.
  1. Attach the battery positive terminal to the No. 2 terminal.
  2. And the battery negative terminal to the No. 1 terminal.
  3. Check for continuity between terminal No. 5 and 4.
  4. If there is no continuity, replace the relay and retest
Aug 05, 2010 | Honda Civic Cars & Trucks
Casio PCR-T2000 Turn off display time
To leave out the time on receipts see page 46 of the manual:
http://www.casio4business.com/sa/products/downloads/manuals/PCR-T2000_E030326D.pdf
Look underneath the table:
The program ( PGM ) key will be needed and the lock on the register must be set to PGM mode.
Program the array as told on the page:
for the second block D7, change the first number 0 into 1 .
Feb 19, 2010 | Casio Parts Cash Register PC Desktop
Sharp ER-A330 cash register. Have to enter Cashier # every sale.
You might need a special key to program this change, but try this:
  1. Turn the key to PGM
  2. Enter 9910 . @/FOR CA/AT
If you don't get an error, you're done. Turn back to REG sign on one more time, and try two or more sales in a row.
If you get an error, this kind of programming is disabled in PGM mode. you may have to take it to a Sharp dealer who has a Service key. Your MA (Manager) key can get you to any position marked on the Mode Switch, but the SRV key goes to two more unmarked positions beyond PGM. If you have that key or find a dealer who has, turn it one notch past PGM (to 7 o'clock position).
Enter 910 . @/FOR CA/AT
[Yes, it's a different number than in PGM mode.]
If you ever want to make cashier entry compulsory again, do the same thing, except enter 100 just before touching the CA/AT button.
The reason Sharp doesn't pass SRV keys with its registers is that you can totally mess up your register if you make mistakes with this key. Don't experiment with it, or your only hope may be to wipe all machine memory to get it working again.
Sep 29, 2009 | Monroe 2020Plus Calculator
Buzzing fuel pump
sounds like the fuel pump relay is stuck on. find the relay and replace it. hope this helps mike
Jun 16, 2009 | Acura TL Cars & Trucks
91 Honda Accord LX turns over and over, upon turning key BUT WILL ABSOLUTELY WILL NOT START when temperature outside is HOT. I know this sounds CRAZY, but I've had starter replaced, battery new, etc. I...
crank angle sensors and ignition modules, ignition coils that are faulty behave like this when faulty try pouring water over crank sensor when it stops and see if it starts after being cooled down if it restarts then you found which is faulty.
you need 3 things for engine to run
air
heat(spark)
fuel
which one is missing when vehicle wont start?
Jun 14, 2009 | 1991 Honda Accord
Viewsat ultra 2000
I would suggest to try to use the NULL cable and do the following:
1.Load VSULTRA_v117_factory_bin.pgm
2 Load DBPSW-061127U_A.PGM
3 Load the latest xxxxxx-xxxxxxU pgm file.
You will know where to find those programs.
Good Luck.
Feb 07, 2008 | Audio Players & Recorders
Sharp XE-A106 Cash Register Logo
134 people viewed this question
Top Sharp Retail Supplies Experts
k24674
Electroboy
Electroboy
Are you a Sharp Retail Supply Expert? Answer questions, earn points and help others
