Question about Vacuums
?how do I programme Micromark MM9536 plugin digital timer?
I have 2 micromark mm9565 electronic timers but have lost the user guide in a house move. Can you supply a downloadable PDF for this timer. Thanks David.
I really do apologize for the inconvenience, however I checked everything on website but I can't find a user guide for your product, I am so sorry. But upon looking for the user guide I accidentally read a blog that this link below is the site of user manual that is might pretty similar to your product, please check it out this might help. Just click the link below:
http://nanohelix.tripod.com/BQ7DayTimer.pdf
Jul 22, 2011 | Vacuums
I replaced a Intermatic light timer with a GE 15086 timer. I have read several solution, but none fit my wire sceme. This is hooked up as a 3-way switch so the second switch can turn outside lights on...
1) GE 15086 is not a 3-way timer.
GE programmable timers are for single-pole switch replacement only. I have tested this timer, and own several GE timers, and many other brands.
2) Open following link to identify timers that work for 3-way switching.
http://waterheatertimer.org/GE-timers-and-manuals.html#15071
3) After buying correct timer, then you need to review wiring diagrams carefully because the timer replaces 1 of the 3-way switches, but other 3-way switch has to be wired exactly right to match your brand of timer.
4) Links on page above show manuals for each of the 3-way timers. Compare wiring for each timer with Intermatic wiring that you are replacing, because Intermatic is wired differently than Aube.
5) Or just buy another Intermatic ST01C or EJ500 or EI400, etc, and wiring with change out 1 for 1.
6) Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 19, 2011 | Vacuums
I have a Micromark MM23224 Alarm - I know the code to the key pad but would like some helpful information upon how I may change it to a new code - and possibly adjust the the time delay. Thank you.
If you go to micromark web page all the instructions are there, but any way press *1122# press *1 # to go into password programming mode enter 4 digit password and #, press * 0 # to exit programming mode. All done.
Dipo
Jan 03, 2011 | Vacuums
Can the GE 15086 digital timer be wired to work on lights operated by two 3-way switches? The package indicates it is a single pole switch and needs a neutral wire. If it can be used, what happens with...
GE 15086 7-day programmable timer will not work for 3-way switching.
http://waterheatertimer.org/GE-timers-and-manuals.html#15086
It is possible to wire GE timer in place of a 3-way if you tape the other switch in one position.
Add a comment if you want help with that wiring.
There are several 7-day programmable timers that can be wired for 3-way. Each of these is wired slightly differently, and you have to look at wiring diagrams carefully. But they are completely do-able.
Links below go to pages that show manuals and information.
Aube T1032
Aube T-1070 7 events
Aube T-1073 21 events
UPM ETW193 20 events
UPM ETW350
Brinks 46-1022
Intermatic ST01C 40 events
Intermatic EJ500 40 events
Also take advantage of fixyas phone service.
For a price, fixya expert speaks with you over phone while you work on timer.
I have a micromark electronic safe and need to contact the manufacturer for a spare key, unfortunately the telephone number I have in the uk is dead. Do you have their contact details?
You are in luck! I am a safe cracker! Just kidding.
Go to this web site for your solution.
http://www.rotteneggsx.com/r3/show/se/198433.html
Sep 17, 2010 | Vacuums
How do I program a Micronta programmable timer--I set the time to have it go on, but how do I set it to go off?
LCD Programmable Timer (630-0892) Operation Faxback Doc. # 17153 Setting The Time and Day Follow these steps to set the current time and day. 1. Slide RUN/PROG/TIME SET to TIME SET. 2. Press HOUR to set the hour digits. Pressing and holding down HOUR rapid- ly advances the hour digits. NOTE: P appears to the left of the hour digits to indicate P.M. hours. 3. Press MIN (minute) to set the minutes digits. Pressing and holding down MIN rapidly advances the minute digits. 4. Press DAY until the correct day abbreviation appears. 5. Slide the RUN/PROG/TIME SET switch to RUN. The colon flashes to show the clock is running. NOTE: Keep this switch set to RUN to prevent accidentally changing the time. Setting The Timer The timer has 14 settings (1-14). Odd numbered settings specify a time to turn on the appliance and even numbered settings specify a time to turn off the appliance. Follow these steps to set your timer. 1. Slide the RUN/PROG/TIME SET switch to PROG. The display shows the first setting. If you have not entered any setting, the display appears as shown in the illustration. 2. Press Event to select a setting to enter or change. 3. Press Hour to set the HOUR digits and press MIN to set minute digits to the correct time. NOTE: Be sure P appears to the left of the hour digits when you want to set a P.M. hour. 4. Press Day to select the day of the week for this setting. If you want the setting to apply to every day of the week, repeatedly press DAY until all day indicators appear on the display. 5. When you finish entering the setting, press EVENT. The timer advances to the next setting. 6. Repeat Steps 3 through 5 to enter additional settings. NOTES: Be sure to set the timer to turn off the appliance. The appli- ance remains on as long as there is power if you do not set a time for the appliance to turn off. To replace an existing event, select its setting number and set the new event time. To clear an event, select its setting number and press CLEAR twice. Be sure to clear both the on time and the off time for an event. If you set the timer to turn on the appliance every day, be sure to also set the timer to turn off the appliance every day. 7. Set the RUN/PROG/TIME SET switch to RUN. NOTE: You must set this switch to RUN to turn on or off the appliance either automatically or manually. When the timer automatically turns on the appliance, ON appears on the display and the indicator lights red. When the appliance turns off, the indicator turns off. Reviewing The Settings To review the settings in your timer, set RUN/PROG/TIME SET to PROG. Setting 1 appears on the display. Repeatedly press EVENT to view the other settings. NOTE: To determine event being programmed, pull the power for a period of 5 minutes. Then re-power the unit. The first event will be "ON" and the next will be "OFF", etc. There will be a number to the side of the display that tells you which event you are programming, The even numbers are "OFF" and the odd numbers are "ON" events. (EB 3/17/97) (EB 7/16/97)
Privacy Policy
Sep 10, 2010 | Vacuums
Vacuums Logo
46 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
