Question about Shop Vac Vacuums
Shop-Vac 6.0 hp Peak 12 Gallon 'Exploding' after 10 seconds of use. Happened twice on two different brand new Shop-Vacs.
I purchased a 12 gallon Shop-Vac 6.0 hp to **** up water out of a trench and within 10 seconds of turning on the Shop-Vac it there was a loud pop and all suction ceased. I immediately turned off the motor and opened up the canister and found plastic and aluminum shrapnel everywhere. Nothing was actually sucked into the canister. I returned it thinking it might've been a rare thing but the exact same thing happened with my replacement. Both were brand new.
  • The Yard
    The Yard Nov 20, 2013
    I believe the motors on both the Shop-Vac's are still working but the fan is blown apart.
    Scholar:
  • 86 Answers
Since you said you were sucking water out of a "trench" I would bet there was some debris in the trench that impacted the impeller on the vacuum and caused the metal impeller to fragment, taking the plastic pieces with it. It is highly unusual for this to occur on vacuums if some type of debris, such as a small stone or piece of metal does not reach the high speed impeller/fan. I suggest using either a foam sleeve over the filter cage, or an old nylon stocking if you can get one, to screen out the debris that will cause this condition.
Posted on May 31, 2014
3 Suggested Answers
SOURCE: shop vac sucks water for a few seconds then it spits it back out
Don't use the paper filter for sucking water. It can ruin it. It will still be usable if you just set it out to dry but there is no reason to use it for water in my experience. I have a sears shop vac and it will fill up more than half full without ejecting the water.
Posted on Mar 15, 2009
SOURCE: no suction in new Hoover Steam Vacs
http://www.hoover.com/pdfs/manuals/F5914900.pdf hopefully this helps
Posted on Jun 21, 2009
Our BLB500, 12 gallon, 5.0 peak HP, Shop Vac won't come on.
From what I have heard, the switch on these units can sometimes be defective. Also, looking closely at the the AC cord may help determine if there is damage to it that should be repaired.
Jan 08, 2016 | Shop Vac Vacuums
Genie shop vac 6 gallon 2.0 is blowing air out of the hose and not sucking
Lots of shop vacs have an exhaust.....which the hose can be hooked up to for blowing stuff.... sounds like you might have the hose plugged into the exhaust.... look for another hole on the side of the bucket part. .... plug the hose in there.
Oct 09, 2014 | Shop Vac Vacuums
Is there an 800 number where I can reach customer service for my shop vac?
I cannot find a 1-800 # but here is some of the contact info from their website. Hope this helps.
https://www.shopvac.com/contact.asp
United States Customer Service
Phone: (570) 326-0502xepmsfks7ymm8bsamlyf2owtpszamzmeaygcpjvaaaaaelftksuqmcc
Fax: (570) 326-7185xepmsfks7ymm8bsamlyf2owtpszamzmeaygcpjvaaaaaelftksuqmcc
Web: Send Email
Regular Business Hours: Monday - Friday, 8:00 AM - 5:00 PM EST
Jul 16, 2014 | Shop-Vac Corporation 18 Gallon 6.5 Peak Hp...
How do you replace the switch on a shop vac 2.0 quiet series
The switch should be connected to the power cord just use a multimeter to work out where the wires go , do you have a pic of the switch ?
Jun 25, 2014 | Shop-Vac Products 5-gallon 2 0-peak Hp Wet...
6.0 hp 12 Gallon Shop-Vac 'exploding'
Those type of vacuums are designed for light duty work around homes anyways. For commercial industrial work as you are doing you need a sump pump. We used to drop one in a 5 gallon (20 liter) pail, drill holes in the pail and suspend from a rope. (you can put screen around the pail covering the holes if needed too). Use a stiff hose to expell the water. You can change to a flat hose like a pool waste water hose or fire hose after the water is out of the trench.
Nov 20, 2013 | Shop Vac Vacuums
On off switch stopped working 3rd one to do so this one cannot be returned to old ? model QPV10.5b nothing on shop vac site and nothing comes up on Digi-key site really do not want to buy 150.00 vac...
Hi Ashley,
This website has one for the 12/14/16 gallon vacs:
http://www.vacsrus.com/CartGenie/prod-1165.htm
If yours is a different size, write back and I'll see if I can find it for you. Hope the 4th one lasts a bit longer.....
Hope this helps. If it does, please place a vote for me. Thanks,
Handie Andie
Mar 30, 2011 | Vacuums
Older model shop.vac parts/owners manuel
Hi, I know on my Craftsman shop vac 2 different sizes of vacs that I use, I try and stick to the craftsman filters, but you can use other brands if they are not available or you want to save some ( $ ) ? As far as a manual for this vac, more then likely you will have to go to the maker and distributor as Sears, O.C.Hardware also sell there products. You may have to go with a manual that is the same peak H.P.and gallons that covers all different makes and models. Filter wise, make sure you have the right ones on or off when using the wet or dry pick-up settings.
Sincerely,
Shastalaker7
Jan 23, 2010 | Craftsman 17765 Canister Wet/Dry Vacuum
I need to replace a brush to operate the shop vac. Where can I find it?
true value hardware stores have books to order these parts , piar of brushes are between $3 -$7 ,also most vaccume sweeper shop
Jul 13, 2009 | Craftsman 9-17765 12 Gallon Wet/Dry Vac,...
Vacuums Logo
125 people viewed this question
Top Shop Vac Vacuums Experts
Mike
jdthefixer
Are you a Shop Vac Vacuum Expert? Answer questions, earn points and help others
