Question about Garden
I have places on my skin that hurt badly,they make a tunnel like thing under my skin,when i reach the end of the tunnel thing what ever it is is very painful to remove.They are attached very firmly and deep especially on my fingers.My hands throb especially under the nails
    Sergeant:
  • Garden Expert
  • 417 Answers
What does your warts have to do with lawn mowers?
Posted on Nov 21, 2013
Suski bandit leaking oil around the plugs
sounds like the plug tunnel seals are leaking or badly fitted...these are the seals found inside the rocker cover (top cover) of the engine that stop top end oil from leaking into the spark plug tunnels.
Jan 13, 2014 | 1999 Suzuki GSF 600 S Bandit
Does acupuncture hurt?
no, the needles are very small, and the acupuncturist puts them in in a way that does not hurt
Jan 23, 2013 | Health & Beauty
How to remove drip tray at back of aeg fridge
On an AEG SANTO 3533, the tray sits on top of the compressor. There is a short metal "tunnel" on top of the compressor. The tray has a plastic clip in the middle which goes through the tunnel and latches up on the other side. To remove, reach to the back of the metal in the middle of the tray, press the plastic clip firmly down, and pull/wiggle the tray backwards horizontally to remove. Needed a torch to see clearly on mine. One of these things that's easy once you've done it once.
Feb 21, 2012 | Refrigerators
How can I treat my puffy eyebags and it has these small rounds like warts? I hate looking at it.
For puffy eyes, I steep teabags in water for about five minutes. Gently squeeze the liquids out, and once the bags are cool (or gently warm, depending on your personal preference) lay back in a comfortable position and place them over your eyes. I usually leave them for about 10 minutes. Also, I would opt for a gentle tea, such as chamomile. Some teas have acidic properties, and could possibly sting sensitive skin.
Regarding the small wart-like blemishes - are they on your under-eye skin? If so, they may be benign cysts which is actually a quite common occurrence in women. You can talk to a dermatologist to see about having them removed by laser. If in doubt, I would still go to a dermatologist to have them checked out. They may be able to diagnose what the blemishes are, as well as advise you the best treatment options.
Jul 25, 2011 | Health & Beauty
How do you remove a hydraulic line from the master cylinder
if this is an older truck like mine the slave cylinder is internal, inbettween the trns housing and the bell housing. go under driver side of vehicle, stick your arm up in bettween the trans tunnel and the trans where the line comes down and you should feel the end of the line and the bleeder valve for the slave cylinder. at the bottom of the line there will be a clip, if u cant grab it, get something with a strong hook on the end, hook the clip and pull, ( tip) watch out for the fluid comming out it will hurt if you get that in your eyes.
Jan 08, 2011 | 1987 Ford Ranger
Since reaching menopause my skin has really changed. Does Hormeta have a product that will help with these skin changes such as very dry skin, dull, flaky, wrinkled, sagging, rough texture etc.?
Absolutly, skin changes can start with pre-menopause and continue all the way through post-menapause. Hormeta has a cream to address all those problems. Try "Feminissime High Redefinition Cream" day and night. You may also want to try our new "Feminissime Serum" which can also be used day and night under any of our day or night creams. You will find these in our mature skin line section.
Nov 23, 2010 | Health & Beauty
Hood wire is out from the latch at the hood end...how to open the hood (1997 Honda accord)
first, try smacking the hood at one of the front corners while someone else pulls the release handle. or even after you've pulled on it. if that works, once open, adjust and lubricate the hood latch assembly. if it still won't open, and it's the cable and not the latch you'll have to replace it anyway, so instead of removing the grill, cut the cable behind the pull lever under the dash where you can reach it. then skin the outer cable insulation away from the actual steel cable exposing an inch or two of it. then holding the insulation and plastic housing with pliers, grab the steel cable itself with pliers and pull it to open the hood. then replace the cable. the further you can reach up under the panel the better your chances of getting past the broken part of the cable and avoid removing the grill. you might also be able to gain access from up under the car if you're lucky.
May 11, 2010 | 1997 Honda Accord
Can't access network folder after connect thru vpn
if you connect through vpn and your network folder is in your local network, you cannot access the network folder because you are virtually connected to an external network other than your local network. because of this you are actually trying to find your local network folder that is not present on that external network. you may need to disconnect your vpn before you access the network folder in your local network
Nov 06, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
Replacing the light lamp for the 60V500
Hi, pull off the plastic cover just below the bottom of the screen, remove the phillips screw from the lamp door cover then the screws from the lamp housing and pull straight out, do not touch the glass portion of the lamp with your fingers, the oil from your skin will shorten the life of the lamp,
when installing new lamp push into tunnel just far enough that it touches end of tunnel then snug with screws. DO NOT push in hard on lamp, re-install lamp door and front plastic cover and enjoy,
good luck, video tek
Feb 07, 2009 | Hitachi 60V500 60" Rear Projection...
Hoover Wind tunnel V2
Either the brush rolls are bad, ends are bad, or the gear housing/motor asm. is bad and will have to be replaced. ee84874.jpg
Oct 23, 2007 | Hoover U8147-900 WindTunnel V2 Bagless...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
