Question about Goodman Heating & Cooling
My heater is blowing cold air
I have a goodman AR48-1
  • 148 Answers
Check high limit safety switch
Posted on Feb 06, 2014
aries_67
SOURCE: 1993 goodman status light 4 times blinking
I have a goodman GMP075-3 that won't turn on. I think it is the pressure switch since I do not have a vent blockage. What is a venter and where can I find it??
Posted on Dec 30, 2008
  • 189 Answers
SOURCE: The Heater is only blowing cold air
I would need a lot more info. if this is a natural gas furnace you may have a bad hot surface ignitor
Posted on Mar 28, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: my heater blows cold air. any ideas?
Your unit has a diagnostic light on the circuit board. You need to look thru a small viewing port to see it. Once you count the number of b links, remove the lower panel and look at the wiring diagram for an error code chart. Then read the following to give you some ideas what to do.
On a call for heat, the 24 volt thermostat sends a signal to the control module. The control module will indicate a call for heat with a light on the control either blinking or remain solid depending upon model. The inducer (exhaust) blower will purge all gasses from the furnace and pressurize a pressure switch. Once the pressure switch tells the module to continue, the electronic ignition will energize and send 120 volts to the igniter. The igniter will glow and you will be able to see it if viewed thru the small inspection port. Once the igniter gets hot enough, it sends a signal to the module opening up the gas valve (24 volts). Either a pilot will come on or the burner tube will ignite then spread the flame to all burners. Lastly a safety sensor will be looking for a certain temperature within a few seconds and the furnace will continue to operate and the room air blower will turn on in a minute or two.
What could go wrong? The unit will not run if there is no signal from the thermostat (bad thermostat or broken wire), the control module does not sense a signal from the thermostat (bad control), the inducer does not energize (bad motor), the pressure switch does not close (blocked vent piping, bad switch, plugged condensate hose), the igniter does not energize (bad control, bad igniter), the gas valve does not open or there is no gas (bad gas valve, broken wire, no gas), the pilot does not light (dirty pilot), the burner does not light (bad burner, plugged orifice, not enough combustion air), the flame does not spread to each burner (bad flame spreader, dirty flame spreader, more bad burners), the flame safety sensor does not detect flame (dirty or bad flame spreader, bad flame sensor, broken wire, bad control), or the room air blower does not energize (bad fan motor, bad control).
Posted on Dec 01, 2009
  • 185 Answers
SOURCE: DAEWOO MATIZ 800CC 1999 HEATER BLOWING COLD AIR
Or you need anitfreeze.
Or your thermostat is shot. Both are easy fixes.
Try the antifreeze, first,check and top off.
and if teh problem persists, check and repalce the thermostat.
Posted on Feb 02, 2010
heatman101
  • 43501 Answers
SOURCE: reddy heater blows cold air
Here are a couple of tips that I wrote that tell you how to troubleshoot aTorpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters Torpedo Heater Pump Pressure Adjustment
heatman101
Posted on Oct 31, 2010
How do I get my heater to blow hot air?
I assume this is gas . induced draft blower or ignitor.
Apr 30, 2014 | Goodman GMS90703BXA Heater
Goodman furnace, blowing cold air
Replace termorelay cose it overheating in service centre 12_26_2013_5_48_58_pm.jpg
Dec 06, 2013 | Heating & Cooling
THE IGNITION DON'T FLAME AND THE HEATER BLOW COLD AIR
Can you verify if the igniter is receiving 120 volts?
Dec 09, 2012 | Goodman GMS90703BXA Heater
Our goodman furnace igniter trys to kick in, but blows cold air. Gas company came checked furnace and told me goodman igniters tend to have this problem of them working fine and then blow cold air at...
it sound slike the presure switch is not working , if it is not lighting try jumping it out it may work some times you can fool it in to working
Feb 21, 2011 | Goodman Heating & Cooling
I have a 3 ton goodman heat pump warm air is delivered from all the vents except for two which blows cool to cold air . help me , freezing im both bedrooms
if these are the longest runs from the air handler this can sometimes happen ,about the easest solution is to install a in duct heater into the duct feeding the rooms this is basically a set of electric coils installed in duct to re-heat the air going to the bed room
Jan 08, 2010 | Goodman CLQ36AR49 Air Conditioner
Goodman Dependable 92 blowign cold air only - no heat
blowing cold air on this furnace usualy caused by high limit trip, or flame roll out. the first one, (high limit) is from insf. air flow. (blocked filter,bad zone damper?
The second,(flame roll out) caused by bad heat exchanger,blocked vent.ect.
Jan 09, 2009 | Heating & Cooling
Heating & Cooling Logo
18 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
