Question about Brandt WFH1176 Front Load Washer
AFTER START APEARS THE F07 CODE. WHAT CAN I DO?
Hot point ariston aqualtis condenser dryer fault code f07
F07
Heater relay stuck
Check wiring
Check electronic control PCB
Jun 21, 2014 | Hoover Dryers
Aqualtis fault code f07
Heater relay stuck
  • Check wiring
  • Check electronic control PCB
Jun 21, 2014 | Hoover Washing Machines
Fault code f07
The type of dryer would help a lot.... If it is a Maytag you can try resetting the code...
To reset the error code you need to turn the dial to the 6 oclock position.
Press the start button 3 times
Turn the dial 1 position clockwise
Press start button again 3 times
Then turn to off and this should clear the error code.if you still get the F07 error code then the control board may be the problem
If it is a Hot point You have a lower element failure..
Dec 31, 2013 | Dryers
The copier is giving error code f07
F07 Communication error between boards (LGC and SYS boards)
Firmware is where I would start along with the wall power.
If this isnt work, replaced logic board and updated firmware. Machine will must works perfectly.
Hope this helps.
Oct 12, 2011 | Toshiba e-Studio 45 Black and White Copier
ERROE CODE IS F07
Is it a Hotpoint ? If so F07 is heater relay stuck this is on the control module which will have to be replaced.There could also be a problem with the pressure switch and or element. Call an engineer but it won't be a cheep repair
Jul 15, 2011 | Washing Machines
F70 mhwe900vj00
What is f70? is that an error code? there is no f70. there is an f07 code.
http://www.repairclinic.com/0078.asp
there it will tell you what f07 means and what to check
but if i am way off tell me what exactly you want to know thanks
Mar 31, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F07 error message
F07 - Motor Control Unit (MCU) Error - Disconnect power and unplug unit. Check wire harness connections between drive motor and Motor Control Unit (MCU), and between MCU and the Central Control Unit (CCU). Reconnect power and plug unit in.
Check the MCU by looking for operations of the drive motor, and check drive motor for powered rotations. Replace failed component.
Note: If this failure occurs during high-speed spin, the door will be unlocked after three minutes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Oct 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F07 occurs at end of first rinse cycle
Mar 26, 2009 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Ariston Front Loading Washing Machine error code F07
Error code F07 is indicating that the heater relay is stuck for one reason or another.
This could be a board problem, as this where the relay is located.
However, it would be worth checking that the heater is o/k before you do anything else., as this possibly could cause the relay to malfunction.
Plz rate my solution.
Thanks.
Jan 11, 2009 | Ariston Technologies AW125NA 13 lbs. Load...
Brandt WFH1176 Front Load Washer Logo
32 people viewed this question
Top Brandt Washing Machines Experts
Gerry Harvey
Gerry Harvey
john mabry
Are you a Brandt Washing Machine Expert? Answer questions, earn points and help others
