Cannot center my web pages far emough to the left
I was able to partially move web pages to left but not far enough
BigdaddyTDW
  • 62 Answers
SOURCE: Printer is creating a crease and smudge down center of page.
There sounds like there is somthing in the path of the printhead. Using a flash light, remove back cover of machine and look for a small piece of paper,etc. Be careful not to jam anything in to th machine. It may take running a thick piece of paper through manually with your hands to remove the object.
Posted on Feb 12, 2009
  • 139 Answers
SOURCE: alignment will not work corectly, still have blue and yellow show
Make sure the Size and Linearity adjustments are not cranked too high. This can affect the ability to move side to side. Center green first and then red and blue. Some pattern generators can produce a horiz shift. Also, check for a horiz start position adjustment. If blue is way off from Red and Gren then you have a bad amp.
Posted on Mar 23, 2009
  • 10406 Answers
SOURCE: I was changing my printer ink and as soon as I
Did you completely turn the printer off, and unplug it from the AC power? Is it still "busy" after reconnecting it?
Is it still protected by Dell's warranty?
Posted on Sep 19, 2009
Testimonial: "THANK YOU! I spent and hour trying to figure this out on my own. Unplug it and plug it back in...why didn't I think of that. THANK YOU!"
davon242
  • 62 Answers
SOURCE: web page is off center
CSS Conditional comments are not supported in Chrome. Use javascript to detect the browser type and set classes on elements accordingly.Here's you can find the java detection link http://www.w3schools.com/js/js_browser.asp hoping to resolve your problem - cheers
Posted on Nov 04, 2009
  • 20 Answers
SOURCE: Have to keep pulling back my screen to the left each time to center my web page
Just double click (fast) on empty space of active window , above the address bar. it makes your window central to screen with maximise. and if you do again double click (fast) it makes window small (its original place)
Posted on Jul 09, 2012
Google page not centered on monitor
You don't specify if you're PC or Mac User.
If PC user then it should be easy to fix. Top right corner of your web browser program should have three symbols: a minus sign, a box and an X.
Try clicking with your mouse on the box. It should make the program viewed slightly smaller. When it does you can move your mouse to the top of the window (usually a blue bar) and while clicking the left mouse button you can move it wherever you like (centre it).
It's more of a temporary solution and if the window is too big to fit the screen you can move the mouse to the left, right, bottom and when you move over the edge it will turn into a line with arrows at both ends.
When it does that you can click the left mouse button and drag the edge of the window to make the window smaller. Adjust each side as needed.
To fix things permanently you may have to adjust your monitor's settings using the buttons on the monitor itself. For that you're on your own as I don't know how to adjust every monitor's settings.
Jan 11, 2014 | Computers & Internet
Jul 09, 2012 | Dell Computers & Internet
On the Onscreen Menu I accidentily set the horizontal position of my monitor too far to the right- how can I decrease it so I don't have it offset??? and no it's nothing to do with software issues i just...
Go back to menu and look for icon box with smaller box inside and partially outside the bigger one. use the plus minus keys on monitor to move screen back into position.
Good luck
If this helps you resolve your problem, please
consider giving me a good rating .It will help me
as well. Thank you.
Sep 25, 2010 | E-Machines eMachines Desktop PC
Web page is off center. cannot view entire page. i am unable to move web page to left. it currently displays to the right. this problem occurs only when using google chrome.
Nov 04, 2009 | Video Game Consoles & Games
I was changing my printer ink and as soon as I closed the printer the cartridges moved to far left and now it won't do anything. I tried printing the alignment page but it says it's busy. I opened the...
Sep 19, 2009 | Dell Office Equipment & Supplies
Alignment will not work corectly, still have blue and yellow show
Mar 23, 2009 | Zenith Televison & Video
Shutter Opens Partially
This is a common problem for the A520 (it happens on mine sometimes). Recommend trying only the simple fixes listed on the following web page, but do not recommend opening the front cover which is also listed here. The A520 is a little tricky getting back together.
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
May 17, 2008 | Canon PowerShot A520 Digital Camera
Dell 924 Inkjet Printer False Paper Jam
Got rid of my problem!
In an act of despair I started to poke around the inside of the printer with a wooden match. Especially I found a small black lever mentioned on a Dell web site (general paper jam help page) that could be pressed a little. It is placed just a little bit right of center behind the carriage and just above the roll that feeds the paper beneath the printer heads. I'm not sure if this was what finally did it, but now the paper jam problem has gone away.
Another thing I noticed is that my carriage is now moving to center when I open the top. When the paper jam error was present it always moved to the far left (so I could remove any jammed paper, I suspect).
Mar 30, 2008 | Dell 924 All-in-One InkJet Printer
Computers & Internet Logo
11 people viewed this question
David Payne
David Payne
