Question about Frigidaire FMV145K Microwave Oven
Stopped working after I changed the handle.IT automatically turns on when closing the door.but doenot heat. have to keep the door open to keep it off.
Turning off the power and turning back on doesn't work.
    Scholar:
  • 178 Answers
This sounds like either a bad door switch or possibly a latch head problem from taking the door apart......
Posted on Nov 20, 2013
5 Suggested Answers
SOURCE: It works while the door is open. It stops working
I have same problem. Just called Frigidaire and they gave free parts, and local repair contacts. The labor is $109... Anyone has better experience?
Posted on Jul 19, 2010
heatman101
  • 43501 Answers
SOURCE: every thing works wheb
The relay in the control board has welded together on the on position...the board will have to be replaced...
There are parts for some microwaves and not for others...here are a couple of tips that will help you...
Basic TroubleshMicrowave Ovenooting Tips
Here is a tip that will help you with the online buying...
How to Buy
Appliance Parts Online
heatman101
Posted on Dec 15, 2010
  • 6771 Answers
SOURCE: Frigidaire microwave FMV156DBC turns on with door
One or two of the door switches has failed, replacement only option, consider price.
Posted on Apr 07, 2012
MicrowaveSvc
  • 9098 Answers
SOURCE: frigidaire microwave plmv168cc1 makes humming noise when door closed
Chances are that the secondary (cook) relay on the control circuit board is shorted, meaning that the oven is actually cooking any time the door is closed.
You can test that by putting in a cup of water, shutting the door, and letting it go for about 30 seconds, then checking the water temperature.
This is dangerous, and can lead to a fire, so please unplug the oven until it is repaired.
The relay can be replaced for far less than the cost of a new control circuit board.
Posted on May 31, 2012
Why microwave won't stop running unless door is open ?
Is it actually heating or just making noise and acting like it's heating? (put a cup of water inside and close the door.) IF it's actually heating, then you have a shorted relay on the main control board, and you will have to replace the board. IF it's just making noise like it's working, but it's not heating, then the problem is 1 of the door switches is not working right (it's either stuck open or stuck closed).
Aug 16, 2014 | Whirlpool Microwave Ovens
DOOR LATCH PROBLEM...HOLDING IT CLOSED AND TURNING IT ON WORKS AND HEATS. IS IT A DIY FIX PROBLEM? THANKS FOR THE HELP, DEBBIE
follow this steps and fix it. God bless you
  1. Open leverCheck your microwave lever to determine if it is damaged. If it is broken, simply replace the lever to get your microwave door fully functional again.
  2. Door springResponsible for keeping downward pressure on the door hook, the microwave door spring can begin to malfunction. If this part is broken and prevents you from opening your microwave door, replacement is necessary.
  3. Door latchOne reason your microwave door may not open properly is a broken door latch. Located inside the microwave, the door latch manipulates the door hook to keep the door closed for safety and top performance. If broken, the door could become stuck in the locked position.
  4. Door hookIf your microwave door will not release properly, the door hook could be damaged. Located inside the door, the door hook is made of plastic and prone to breakage with extended use or age. As this part is unable to be repaired, the only option is to replace it.
  5. Button or button springIf the microwave door will not open, it could be an internal failure of the button or button spring. If it is determined that either of these parts is the source, both are replaceable and it is recommended that they be installed at the same time.
  6. Handle actuatorIf the microwave door will not open the plastic handle actuator could be broken. Connected between the door button and the door latch assembly, this plastic part could become damaged and brittle over time, which makes breaking inevitable. If this occurs, replace the handle actuator to get your microwave fully functional again.
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#11#ixzz2gPqmd5pf
Sep 30, 2013 | Frigidaire FGMV174K Microwave Oven
Sharp Insight Pro microwave drawer KB6024MS not working
The drawer often stops working when it is abruptly stopped while opening and forced closed or vice-versa. To fix, simply do the following:
1) Push the draw all the way closed
2) Push the "Setup" button repeatedly until the "Open/Close ...?" appears.
3) Hold the Start Button until the time reappears in the display.
4) Repeat steps 2 & 3 three more times
5) Unplug the Microwave for 30 minutes.
The drawer is now reset. The drawer will now open electronically (automatically) either by pushing the open button on the panel or by pulling the drawer handle slightly.
Feb 05, 2010 | Microwave Ovens
Microwave not heating
You need to replace the whole door latch with an original part.
If it is working but not heating, then test the high voltage capacitor,the rectifier diode.or the magnetron. If all this are fine, test the control board.If turntable is not running check also the door switch.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts.
You can also order from MicrowaveSvc , they also provide parts.
Mar 18, 2009 | GE Advantium SCA1001SS Convection /...
Microwave is not working
One of the door switches needs to be replace.
Oct 30, 2008 | GE JVM1440 Microwave Oven
Hi there in my microwave when i switch it on the rotator, fan and lamp gets switched on automatically. but magnetron doesnot get started untill i start the timer on the microwave. how can I stop rotatorm...
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 06, 2008 | Microwave Ovens
Sharp carosel R310FK-keeps going
control panel is hung up - replace panel and keypad.
Dec 28, 2007 | Sharp R-510HW Microwave Oven
No heating, no clock, no timer, otherwise fine!
One of your door interlock switches is defective . I would suggest having it repaired by a qualified repair tech in your area.
Oct 04, 2007 | Sharp R-1500 Microwave Oven
Frigidaire FMV145K Microwave Oven Logo
52 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
