Question about Toys
2005 745i has engine code 0x2a6b - Toys
I have a small block chevrolet engine with an engine ID code #V12IOXI. Can you tell me what size engine this is and what type vehicle it was from.
Looks like -
V = Flint factory
12 = December
10 = 10th day
XI = 1969 350 engine 2bbl carb C50 or C60 truck
Mar 20, 2016 | Chevrolet Cars & Trucks
Fault code 1 Fail 31 Spn1569 2015 Cascadia Cummins engine
spn 1569 relates engine protection torque derate -condition exists.
critical fault codes related to engine operation are active
code 1 means urgent attention
A sort of limp mode setting that requires immediate attention by a cummins service center to prevent further damage to the engine
go google and type in--- cummins engines fault codes (or cummins engine fault code 1569) and there are pages of pdf downloads that list all the codes and what they stand for
Oct 07, 2015 | Cars & Trucks
I'm getting code PO300. Drove fine to work, going home it ran horrible.
P0300 GMC - Engine-Codes.com
engine-codes.com/p0300_gmc.html
OBD-II Trouble Codes Definition, Description and Repair Information ' Engine-Codes. Engine- ... 2000-2008 GMC Yukon XL ... 2002 Chevrolet Blazer P0300 Misfire Diagnostics ... 2008 GMC ENVOY Engine And Engine Cooling:engine Details.
Jul 14, 2015 | GMC 2002 Envoy XL SLT
Engine light code P0304
The P0304 code means that the cylinder 4 is misfiring or is ... P0304 MAZDA P0304 ... Engine Light ON? The Engine-Codes.com ELM327 WiFi Car Diagnostic
OBD II Trouble Code Information and Diagnosis Engine Codes com Welcome to Engine Codes
Apr 18, 2015 | 2001 Mazda Tribute
Identify honda h engine by engine serial #?
Honda identifies all of their engines by a four-characters code for the Japan Domestic Market, and a five or more characters code for export markets.
For the Japan Domestic Market, the four characters code is made up of a letter, usually taken to identify the engine series; a two digits code indicating engine capacity in litres; and ends with a letter. So the legendary 1595cc (1.6litre) DOHC VTEC engine used in the Integra RSi/XSi and Civic/CRX SiRs has a B16A code. This engine is a 'B' series, 16 indicating a capacity of 1.6litres and ends with an 'A' code which TOVA have not yet managed to find any significant meaning. Another example would be the 2156cc (2.2litre) DOHC VTEC 190ps/200ps engine used on the Prelude and Accord SiRs. This engine is the 'H' series, with 2.2litres and has an engine code of H22A. An exception to this 4-characters code rule is the famous ZC 1590cc series of engine used on various Integra, Civic, and CRX types.
The engine code for export engines are more varied. Honda normally appends a number to the four-character code so the B16A engines for various export markets might be coded B16A1 or B16A5 (eg US or UK markets). Another example would be the B20A2 code for export Honda CR-Vs, where the JDM versions would have a plain B20A code.
However, other variations also exists, eg the 1590cc engine used on current Malaysian market Civics are coded ME516 or MF816 etc. These codes seems to be made up of first a code for the country (M for Malaysia), then a series code comprising a letter plus a number (E5 or F8) and ending with two numbers, again a code for the engine capacity in litres.
[img src="http://asia.vtec.net/topics/engcode1.jpg">
The engine code for any Honda engine is engraved at the top of the engine block, just below the head gasket. The code is usually followed (on another line) by a 7 digits engine serial number. For eg, somewhere in the world, there is a 1989 Honda Integra RSi or XSi that has the 1595cc DOHC VTEC engine bearing a code of B16A followed (on the next line below) by a code of 1000001 -ie the firstB16A manufactured by Honda.
The pictures on the right shows the location of the engine code and engine serial number clearly.
Sometimes the identification plate in the engine bay also has the engine code and serial number (together in one line) but for the later generations of Hondas, they are usually left out. TOVA would also like to emphasize here that all JDM engines have only 4 characters in their code regardless of the codes that might be used on their equivalentexport counterparts.
Aug 23, 2013 | Vehicle Parts & Accessories
Identify honda h by engine serial #?
How to reset engine lite in dash
Check engine light comes on and off, these are indication that there is some error code stored in your vehicles ECM. The engine module computer needs to be scanned. These will give the code and as per the error code the further problem can be detected and confirmed. The engine light indicator blinks or remains steady on dash when engine computer noticed any problem with any engine electrically operated components.
For more help, I suggest you to refer the help links provided below. These will let you know more about which areas to look, check, when there is engine light coming up on dash panel.
Click the link below: -------
Check Engine Light Reset Procedure?
http://whoisbyme.blogspot.in/2012/06/check-engine-light-reset-procedure.html
Check Engine Light ON?
http://whoisbyme.blogspot.in/2012/06/check-engine-light-on.html
Intermittent Check Engine Light?
http://whoisbyme.blogspot.in/2012/06/intermittent-check-engine-light.html
WHY Check Engine Light On car?
http://schematicsdiagram.blogspot.com/2011/06/check-engine-light-on-car.html
Check Engine Light, VSC light and Traction Control Light ON?
http://whoisbyme.blogspot.com/2012/06/check-engine-lightvsc-light-and.html
Check engine light flashing?
http://technoanswers.blogspot.in/2012/02/check-engine-light-flashing.html
Service engine soon Light Turned OFF after Jump Start?
http://whatisbyme.blogspot.in/2012/06/service-engine-soon-light-turned-off.html
After replacing throttle body the Check engine light starts blinking?
http://technoanswers.blogspot.com/2012/01/after-replacing-throttle-body-check.html
2005 Chevy Impala: Service Vehicle Soon Warning Light?
http://whoisbyme.blogspot.in/2012/06/2005-chevy-impala-service-vehicle-soon.html
Malfunction Indicator Light ON
http://whoisbyme.blogspot.in/2012/06/malfunction-indicator-light-on.html
Check power-train message with orange engine light came on?
http://howtobyme.blogspot.in/2012/02/check-power-train-message-with-orange.html
2007 Toyota Highlander Hybrid: Yellow Check Engine Light ON dash?
http://whatisbyme.blogspot.in/2012/05/2007-toyota-highlander-hybrid-yellow.html
1999 Toyota Tacoma: Check Engine Light Read Code P0171?
http://whatisbyme.blogspot.in/2012/05/1999-toyota-tacoma-check-engine-light.html
Car Runs Fine But Check Engine light is ON?
http://whatisbyme.blogspot.in/2012/05/car-runs-fine-but-check-engine-light-is.html
Check engine light with codes P2195 and P2197?
http://howtobyme.blogspot.in/2012/01/check-engine-light-with-codes-p2195-and.html
How to Read Codes from Check Engine Light?
http://schematicsdiagram.blogspot.com/2011/12/how-to-read-codes-from-check-engine.html
Vehicle smog test failed Due to NO MIL/check engine light?
http://schematicsdiagram.blogspot.com/2011/12/vehicle-smog-test-failed-due-to-no.html
OBD Code is cleared but check engine light will not RESET?
http://schematicsdiagram.blogspot.in/2012/02/obd-code-is-cleared-but-check-engine.html
Car jerks while going uphill and Check engine light is ON?
http://schematicsdiagram.blogspot.com/2011/12/car-jerks-while-going-uphill-and-check.html
Toyota Camry Check engine light flashes while driving?
http://schematicsdiagram.blogspot.in/2012/02/toyota-camry-check-engine-light-flashes.html
These details will help.
Thanks.
Nov 28, 2012 | 1999 Acura CL
D0108 fault code
I will assume this is a "P" code.
P0108 FORD - Manifold Absolute Pressure/Barometric Pressure Sensor High Inputxicon.jpghttp://engine-codes.com/p0108_ford.htmlForum CodePossible causes- Manifold Absolute Pressure harness is open or shorted
- Manifold Absolute Pressure sensor poor electrical circuit connector
- Faulty Manifold Absolute Pressure sensor
- Faulty Engine Control Module (ECM) When is the code detected?The Engine Control Module (ECM) has detected a performance fault with the anifold Absolute Pressure (MAP) sensorSymptoms- Engine Light ON (or Service Engine Soon Warning Light)
- Engine rough idle
- Engine hesitation
Read more: http://engine-codes.com/p0108_ford.html#ixzz21lGYXzRP
Jul 26, 2012 | 2003 Lincoln Aviator
1999gmcjimmy diagram for vacuum hose
Engine vacuum schematic-1994 4.3L (VIN Z) engines, California models with a M/T (Code TDK)
Engine vacuum schematic-1994 4.3L (VIN Z) engines, California models with M/T (Code TLM)
Engine vacuum schematic-1994 4.3L (VIN Z) engines, California models (Code TFL)
Engine vacuum schematic-1994 4.3L (VIN Z) engines (Code TFN)
Engine vacuum schematic-1994 4.3L (VIN Z) engines, California models with M/T (Code TCY)
Engine vacuum schematic-1994 4.3L (VIN Z) engines (Code TCU)
Hope helps, keep us updated and remember to rate this answer.
Aug 10, 2011 | 1998 GMC Jimmy
What is the 1987 pontiac fiero gt v6 check engine light code list?
CODE 12- NO DISTRIBUTOR REFERENCE PULSES ECM. CODE 13- OXYGEN CIRCUIT. CODE 14- COOLANT SENSOR HIGH TEMP CODE 15- COOLANT SENSOR LOW TEMP. CODE 21 - THROTTLE POSITION SENSOR VOLTAGE HIGH.CODE 22 - THROTTLE POSITION SENSOR VOLTAGE LOW.CODE - 23 MIXTURE CONTROL SOLENOID.FOR CARBURETOR ENGINE. CODE 24 -VECHICLE SPEED SENSOR. CODE 32 - BARO CIRCUIT LOW.CODE 32 - FUEL INJECTED EGR VALVE VACUUM SWITCH SHORTED TO GROUND.OR EGR VALVE SOLENOID CIRCUIT OPEN. CODE 33 - MAP SENSOR.CODE 34 - VACUUM SENSOR OR MAP SENSOR.CODE 35 - IDLE SPEED CONTROL. CODE 41 - EST CIRCUIT. CODE 42 - ELECTRONIC SPARK TIMING.CODE 43 - ELECTRONIC SPARK CONTROL UNIT. CODE 44 - LEAN EXHAUST.CODE 45 - RICH EXHAUST. CODE 51 - PROM OR MEM CAL.CODE 52 - CALPAK. CODE 53 -EGR VALVE CARBURETED ENGINE THE EGR VALVE VACUUM SENSOR HAS RECEIVED IMPROPER EGR VACUUM. CODE 54 - M C SOLENOID CARBURETED ENGINE MIXTURE CONTROL SOLENOID SHORTED OR FAULTY ECM.CODE 54- FUEL INJECTED ENGINE FUEL PUMP VOLTAGE IS LOW.CODE 55 - ECM MAKE SURE PCM GROUND CONNECTIONS ARE TIGHT.IF OKAY.REPLACE THE ECM.
Mar 27, 2010 | 1987 Pontiac Fiero
Toys Logo
683 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
