Question about Canon Office Equipment & Supplies
I can not get my printer to copy double sided
My printer does not allow me to copy 2 sided. The screen that you are supposed to use to choose is not highlighted.
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 125 Answers
Have you tried unplugging it and plugging it in again?
Posted on Nov 22, 2013
  • 9 Answers
SOURCE: copy double sided
You should check the settings in the menu for duplex, there are several choices depending on what you are trying to do.
Posted on Oct 10, 2008
  • 2692 Answers
SOURCE: Printing double sided with MFC-6490CW printer
Hee is you support website See if they have directions(manual ) to download for instructions. I take it that this printer is designed to print double sided else I can tell you the method that works on all printers.
http://welcome.solutions.brother.com/bsc/public/us/us/en/dlf/download_top.html?reg=us&c=us〈=en∏=mfc6490cw_all
Posted on Mar 13, 2009
SOURCE: HP Laserjet #3015. Double feeds when feeding
Separation pad (not feed rollers), is responsible for preventing double feeding. Clean or replace it.
As for toner low...hold the "go" or "online" button until both (all) lights flash then release, this should give you a supplies status page.
Posted on May 16, 2009
  • 183 Answers
SOURCE: Double sided copying does not
look my friend try to open side door and move that two rullers hanging in exit unit try to move more than 5 on's it's works
Posted on Jan 23, 2011
  • 514 Answers
SOURCE: Why does the printer (EPSON Artisan 710) print out
test it with 2 pages of text, one page with an "A" on it, then the 2nd page with a "B" on it. once they print out, flip them over and run them thru again to see which side of the paper is being printed on during a pass thru the printer.
Posted on Mar 03, 2011
How can I print single sided copies?
There should be a copy options button on the screen (often the left hand side). If you are copying a double sided page to make single sided copies choose 2 sided to 1 sided.
Or if you are copying 1 sided to 1 sided, make sure this option is selected (it is usually the default). Hopefully this helps!
Mar 21, 2017 | Office Equipment & Supplies
How to change to double sided printing on mfc-j470dw
Double sided printing it usually set in the software.
For example: printing from Chrome, go to the print screen and at the bottom of the list are options, choose two-sided.
- MS Office, choose print, then choose Properties (next to the printer listed), it is on the first tab - Layout.
Aug 19, 2014 | Brother MFC-J475DW All-in-One Inkjet...
Double sided copies
Your printer has Duplex printing Capabilities. However when you are ready to send the print job, open the Printer Properties and select Double Sided.
To copy a Double sided document, insert it in the ADF (Automatic Document Feeder) and open the copy settings on the machine and select Double sided.
Jan 07, 2014 | Office Equipment & Supplies
How to reduce the size of a color copy?
You will want to press the MENU button on your printer until the Change Copy Settings item appears. You will then scroll through that menu using the left and right arrows on your menu panel until you see the ENLARGE/REDUCE menu choice. This will give you 3 choices to enlarge or reduce your copy. There are Preset Ratio, ZOOM, or Fit To Page.
Preset Ratio has 2 different sizes you can choose.
Zoom allows you to choose from 25% to 400%.
Fit To Page will automatically scan your image and then fir it to the size of page you have chosen to load into your printer.
If you haven't already done so you can go to the following webpage:
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp210#BrochuresAndManuals
Choose the MP210 series On-screen Manual (Windows 7/7 x64/Vista/Vista64/XP/XP x64/2000), the actual link is called "mp210sosmwin110us.exe". Clicking on that link will allow you to download the file to your desktop. Then double-click the icon and your manual will automatically unpack and install itself. You will then see an icon on your desktop called MP210 series On-screen Manual. Double-click this to load the actual manual. Then choose User Guide. When the User Guide loads choose Changing the Copy Settings under the Copying heading on the left hand side. You can then see a detailed description of the information I gave you in this answer.
This should let you do your adjustment but if not please let us know. Thank you for the opportunity to assist you in resolving your issue.
Feb 15, 2011 | Canon PIXMA MP210 InkJet Printer
Cannnot copy a double sided document to cardstock
This is normal. The cardstock is fed from the manual feed or bypass tray and when selected the duplex option goes away. Many manufacturers do this....meaning they do not allow duplexing from the bypass tray. For the same reason they do limit automatic duplexing to standard or near standard papers. Cardstock is specifically excluded from duplexing obviously due to it's thick nature and when duplexing the paper has to be turned over and go thru paper paths that are not suitable for thick paper. If you must make a 2 sided copy using cardstock you will have to run the sheet thru the machine 2 times, also known as manual duplex.
Hope this helps.
Apr 12, 2010 | Copystar - CS-3035 Printer
How to make duplex copies from toshiba e-studio202L
I am going to assume you have a document feeder (ADF) on the copier.
Insert originals into document feeder and press the 1-1 simplex button on the LCD screen. If have single page documents that you want to turn into double sided documents then select 1 - 2 button. If you have double sided originals already and want to make double sided copies then select 2 - 2 button. Then hit the green copy start key...done.
Jan 17, 2010 | Toshiba e-Studio 202L Copier
Double sided printing with Toshiba Studio 3510c series
In the middle of the main screen (in copy mode) there is a big button called "simplex 1 to 1" or it may say "duplex". on the next screen you'll see different ways to do duplex copies. if you have a double sided original then select 2 to 2 / if you have 2 single side originals then select 1 to 2. Place originals in the document feeder and press start
Apr 07, 2009 | Toshiba Office Equipment & Supplies
EP 4000 Drawer Duplex
The duplexer is for 2 sided copies. You can take 2 single sided copies and make (duplex) them into 1 double sided copy. You can take double sided copies and make more double sided (2 sided) copies with the duplexer. You can also take double sided copies and make single sided copies. Hope this helps.
Jan 12, 2009 | Minolta EP4000/5000 CS/PRO Copier
Copying from HP 5610 All-in-One Printer
Can I do double sided printing like Company ID Cards on the 5610
Jan 02, 2009 | HP Officejet 5610 All-In-One InkJet...
AL1641 CS won't make two sided copies anymore
Sounds like a driver or configuration problem, 1st) Make sure when you are printing, to go to Properties, you must choose 2-sided printing each time on that model, some programs won't allow you to change your printers settings.
2nd) go to control panel/ printers/ Al-1641, right click, properties, In the first tab General it should say at the bottom (Double sided - Yes) If not you need to delete the driver, a fairly common problem, and reload the driver, get the driver from Sharps website to be sure you have the most current driver, if a driver is corrupt it won't tell you there is a problem, make sure it allows you to print two sided.
Jan 11, 2008 | Sharp AL-1641CS Color Copier
18 people viewed this question
old marine
old marine
