Question about Frigidaire Washing Machines
What is the load capacity of Frigidaire model FWXB45RGS0
How do you change a drain pump on this machine
well for starter , please make description of your utility machine , brand name , load capacity , type of load ( i.e: Frigidar affinity , front load , ultra load capacity ( meaning over 3 qf ) per load . and then we may can help you , you can also use the internet to log on to your washing machine brand name manufacturer , in example if you have Frigidaire like i do then the link to that machine is this address :
http://www.frigidaire.com/Owner-Center/Product-Support-Manuals/
this is the product support link for all Frigidaire .
Mar 05, 2016 | Washing Machines
Can you tell me what size capacity this front load washer is?
Good Morning Friend, that's a great question!
In order to provide you the correct size capacity of your Frigidaire front load washer, I would need your model number please. You can normally locate the serial tag (which lists your model number) on the upper front, as you open the door. Thank you and I look forward to further assisting you! - Z
Sep 05, 2014 | Frigidaire GLTF1670A Front Load Washer
Capacity frigidaire fwt445ges2 load
Good Afternoon Friend,
I understand you want to know the capacity of your Frigidaire washer, model# FWT445GES2. After researching your model, I found that the capacity of your washer is 4.5 cubic feet. Hope this is helpful.
-Best Regards-
WP
Jul 05, 2014 | Frigidaire GLTF2940ES Front Load Washer
How to operate frigidaire washing machine, ill dont have a manual since i bought it 2nd hand ...
Hello Ruby Torres - I understand that you will like instructions on how to operate the washer, however may I please have the model number so I can assist you better in pinpointing you the information. Generally speaking, the serial tag on a front load washer is usually located on the upper front, as you open the door.
Dec 16, 2012 | Frigidaire ATF6000ES Front Load Washer
What is the capacity of this washer
Hello Diane Swartz - If your model number to your washer is GLTF2940ES, then the capacity of the unit is 3.5 Cu. Ft. However, if that is not the correct model number, may you please provide me the correct one?
Nov 29, 2012 | Frigidaire GLTF2940ES Front Load Washer
What is the capacity size of washer model fws1339ac1
Dimensions/Weight/Electrical Height: 43 5/8" Width: 27" Depth: 27" Approximate Shipping Weight: 180 lbs. Electrical Requirements: 120V/60Hz. Features Control Location: Top Console Capacity: Super Capacity Tub Size (cu. ft.): 3 Agitator Style: Twin Spin Cycles: 13 Wash/Rinse Temperature Combinations: 3 Motor Speeds: 2 Heavy Duty Motor (Hp): 3/4 Total Front Serviceability: Yes
Aug 30, 2012 | Frigidaire FWS1339A Top Load Washer
What is the capacity of the Frigidaire Gallery model FWT449GFS0? It is approximately 13 years old.
The capacity of the Fridigaire FWT449GFS0 is 2.7 cubic feet. I got this info from calling the Frigidaire toll-free help line. It is NOT part of the model number!
Jun 14, 2012 | Frigidaire Washing Machines
White-Westinghouse model la450mxw1 top load capacity in Kg.
I called Frigidaire technical support, they informed me that the capacity is 2.7 c/feet.
Nov 26, 2008 | Westinghouse WWS833ES Super Capacity Top...
Frigidaire Washer machine with burning smell
burnt belt, tight center tub bearing, motor going bad, loose idler pulley spring, wiring issues at the motor, a lot of could bees
Apr 12, 2008 | Washing Machines
Washing Machines Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
