Washing Machines Logo
A
Audrey Fowler Posted on Nov 20, 2013
What is the load capacity for Frigidaire FWXB45RGS0
How do you change a drain pump on this machine
well for starter , please make description of your utility machine , brand name , load capacity , type of load ( i.e: Frigidar affinity , front load , ultra load capacity ( meaning over 3 qf ) per load . and then we may can help you , you can also use the internet to log on to your washing machine brand name manufacturer , in example if you have Frigidaire like i do then the link to that machine is this address :
http://www.frigidaire.com/Owner-Center/Product-Support-Manuals/
this is the product support link for all Frigidaire .
Can you tell me what size capacity this front load washer is?
Good Morning Friend, that's a great question!
In order to provide you the correct size capacity of your Frigidaire front load washer, I would need your model number please. You can normally locate the serial tag (which lists your model number) on the upper front, as you open the door. Thank you and I look forward to further assisting you! - Z
Capacity frigidaire fwt445ges2 load
Good Afternoon Friend,
I understand you want to know the capacity of your Frigidaire washer, model# FWT445GES2. After researching your model, I found that the capacity of your washer is 4.5 cubic feet. Hope this is helpful.
-Best Regards-
WP
Frigidaire super capacity 2speed - 3/4 motor i
Good Afternoon Carlos, thank you for your post!
Based on the symptoms you are describing it sounds like something could possibly be lodged in the blower wheel or your laundry center has a failed motor. Regrettably, this is not a simple DIY job. I would strongly recommend connecting with a professional to narrow down the precise issue before investing in parts that may or may not be the root cause. You can often locate a qualified service provider through the manufacturer website.
2helpful
What is the capacity size of washer model fws1339ac1
Dimensions/Weight/Electrical Height: 43 5/8" Width: 27" Depth: 27" Approximate Shipping Weight: 180 lbs. Electrical Requirements: 120V/60Hz. Features Control Location: Top Console Capacity: Super Capacity Tub Size (cu. ft.): 3 Agitator Style: Twin Spin Cycles: 13 Wash/Rinse Temperature Combinations: 3 Motor Speeds: 2 Heavy Duty Motor (Hp): 3/4 Total Front Serviceability: Yes
Wont fill
the rug backing is catch in pump...the unit will not fill unit pressure switch is trip,,to the empty position..we need to clear that pump..onthejob
What is the capacity of the top load frigidaire washer FWS445RFS2? And if possible, other specs. Thanks.
Should be in the manual or advertising info. Go to frigidaire.com and you should be able to find it. Thanks, please leave feedback or contact me again for more info if you need it.
White-Westinghouse model la450mxw1 top load capacity in Kg.
I called Frigidaire technical support, they informed me that the capacity is 2.7 c/feet.
Top Washing Machines Experts
john h
