Question about General Electric Vehicle Parts & Accessories
I need parts in antigua for a toyota noah 2005 from japan
I need parts for my toyota 2005 noah from japan how do i get an fax and telephone number for a parts place in trinidad
    Problem Solver:
  • 5 Answers
Hello there! You may be able to use the website www.rockauto.com to purchase your parts. They cover all makes and models, are super cheap, and ship internationally. I hope this helps! Have a great day!
Posted on Nov 28, 2013
I have a 2002 Toyota Noah. Its shaking the whole body when I accelerate. The shaking increases with speed. Does this Noah have Mass Airflow Sensor, if so where is it located?
has a mass air flow sensor
check engine light should be on if the maf is faulty
could be other EFI sensors
look for this part in the engine bay
Mar 30, 2017 | Toyota Cars & Trucks
Toyota Noah 1az engine starts and idles but does not Rev up
Trottel has to get re set to factory settings to work did you disconnect the battery if yes you will need a cod for the trottel
Oct 12, 2016 | Covercraft Noah Custom-Fit Car Cover for a...
How many litres of oil for toyota voxy 1.998 engine capacity
How many litres of oil for toyota voxy 2.0 engine Kufa, 4.2L of oil with a filter or 4.0L without filter change.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Toyota VOXY Solving Car Problems
Toyota Noah Voxy 2001 2007 Guide to repair and maintenance Page 4 Catalog...
http://autorepman.com/en/toyota/3422-toyota-noah-voxy-2001-2007-engine-repair-manual.html
Mar 24, 2016 | Toyota Cars & Trucks
What is the address and contact number of the Philippine Embassy in Morioka Japan and what are the things needed in renewing our passport? ( I'm in Japan now)
Unfortunately there is no Embassy in Morioka only a Consulate. Here is the address and phone number, please give them a call to make sure that the address still good.
Mr. Murayama Masahiro
Consul
Head of the Mission
Philippine Consulate
Morioka, Japan
Telephone (+81) 19-625-2131
Sep 03, 2011 | Computers & Internet
I can't send fax to Japan, but can make calls.
Dial the fax number in Japan with a regular phone. You hear how responsible you a fax from the other side? If you answer a fax can be heard, the more likely the issue is still in the phone company that gives you the link.
Jul 27, 2010 | Brother IntelliFAX 1270E Plain Paper Fax
How do I reset the fax machine to answer on my
Turn off auto receive and set to manual, or unplug phone line to fax when not in use. -Carl
Jul 14, 2009 | Brother IntelliFax-2820 Laser Fax
Setup fax machine with new telephone number
no change is needed for incoming faxes (it your new number) and the person (s) on the outgoing side will see the new number also....so just connect it correctly and happy faxing
Mar 22, 2009 | HP OfficeJet 6110 All-In-One InkJet...
On the m9516 what is the fax switch on and off used for?
The Fax Switch
The Fax Switch feature allows you to have two telephone numbers on one incoming line.
There is one telephone number for the line and another telephone number for a Fax Switch peripheral (e.g. fax machine).
To use the Fax Switch, you must subscribe to your telephone company for Distinctive Ringing†. The telephone company will then provide you with an additional telephone number (for your Fax Switch peripheral) which will have a slightly different ring. The 9516 will use the two ring types to determine whether an incoming call is for the telephone or the peripheral. The peripheral should be set to answer after three or more rings.
Note: If Long Distance Ringing† is available in your area, long distance calls will be sent to the Fax Switch peripheral. Also, you cannot use the Fax Switch feature and the Special Greeting feature at the same time. The 9516 must be configured so the Fax Switch peripheral is connected to pins 3 and 4 of jack number 2. See Connecting an optional fax machine or modem on
page 4 for more information.
Note:
If you subscribe to your telephone company for Call Waiting services, your Fax Switch peripheral may lose data or get disconnected if someone calls while your fax is receiving data. We recommend that you do not subscribe to the Call Waiting service from your telephone company if you are using the Fax Switch feature.
Jan 30, 2009 | NorStar Meridian M9516 Phone w/ Digital...
Cannot receive faxes
Step one: Check the fax number
Make sure the fax number is correct; include any numbers that you have to dial to use the telephone, such as an area code, access codes for outside lines or long-distance services, and so on. If you have to dial a particular sequence of numbers to make a telephone call from that telephone line, you also have to dial that sequence of numbers to send a fax.
If the issue is resolved, you do not need to continue troubleshooting.
If the number is correct, continue to the next step.
Step two: Dial the number manually
Instead of using a speed dial setting or sending the fax from the computer, dial the number manually from the product control panel.
If the fax sends when you dial the number from the control panel, follow these steps to recreate the speed dial setting and insert pauses in the number.
On the product control panel, press the Setup button.
Press the Left Arrow button ( ) or Right Arrow button ( ) until Speed Dial Setup appears on the control panel display, and then press the OK button.
Press the Left Arrow button ( ) or Right Arrow button ( ) until Individual Speed Dial appears on the control panel display, and then press the OK button.
Press the Left Arrow button ( ) or Right Arrow button ( ) to select an unassigned speed dial entry, and then press the OK button.
Use the product keypad to enter any numbers that must be inserted before the fax number, such as an area code or access codes for outside lines or long-distance services, and then press the Redial/Pause button to insert a pause.
Enter the rest of the fax number, using the Redial/Pause button to insert pauses between the numbers, and then press the OK button.
Enter the name of the speed dial setting, and then press the OK button to save the speed dial setting.
Try to send the fax again.
If the issue is resolved , you do not need to continue troubleshooting.
If the issue is not resolved , continue to the next step.
Step three: Run a fax diagnostic test
Press the On button ( ) to turn on the product, and then make sure the product is correctly connected to the telephone jack.
Make sure that there is plain white paper in the input tray.
On the product control panel, press 6 , and then press 6 again.
This selects the Tools menu and then selects Run Fax Test .
The fax diagnostic test page prints.
Review the results of the test.
If the result of the fax diagnostic test is All Pass , skip to Step four: Reinitialize the fax.
If the result of the fax diagnostic test is a failure, a page prints that describes the issue and offers possible solutions. Follow the solutions on the printout.
If the solutions on the printout resolve the issue, you do not need to continue troubleshooting.
If the solutions on the printout do not resolve the issue, continue to the next step.
While the product is on, disconnect the power cord from the back of the product and from the electrical outlet.
Make sure that the telephone cord is fully inserted into the port labeled 1-Line on the back of the product.
Connect the power cord to the back of the product, and then connect the power cord to the electrical outlet.
When the product is in the ready state, try to send and receive a fax again.
Step five: Test the send/receive functions
Use the product keypad to send a fax. Watch the product control panel display and listen to the sounds the product makes.
If the product is working correctly, the following events occur.
When the product begins to dial, a dial tone is audible, followed by the sound of the product dialing. A Dialing message appears on the control panel display.
When the receiving fax answers the call, the product and the fax exchange tones. A Connecting message appears on the control panel display. During this phase, the product and the fax compare capabilities, exchange information about how to send the fax, and try to establish a reliable transmission speed.
After the connection is established, the product sends the pages of the document. Messages appear on the control panel display that indicate the status, such as Sending page 1 .
Review the results of the fax.
If the fax is transmitted successfully, continue to the next step.
If there is no audible dial tone or the receiving fax does not answer the call, try sending the fax to a different destination. If this second attempt also fails, continue to the next step.
If the receiving fax answers the call and begins beeping, but the Connecting message does not appear on the product control panel display, the product is not detecting the tones from the receiving fax. Continue to the next step.
Step six: Use an analog telephone service
HP Fax and All-in-One products are designed to work with analog telephone services and might experience some difficulties when they are connected to phone lines with digital services. Make sure the product is connected to an analog telephone service.
To obtain digital services information or support, contact the telephone service provider or system administrator.
Step seven: Check the phone cord and fax connections
Disconnect the telephone cord, and then examine the connector on the end of the cord. Make sure the cord only has two wires.
Figure 1: Telephone cord with two wires
Figure 2: Telephone cord with four wires
If the cord has four wires, replace it with a two-wire telephone cord.
If you must use a cord with four wires, use the converter that shipped with product. The converter allows a cord with four wires to work with a device that requires a cord with two wires.
Make sure the fax is connected directly to the telephone jack by a telephone cord. Connect the cord to the 1-Line port on the back of the product.
Figure 3: Fax only
1 - Telephone jack
2 - Telephone line
3 - 1-Line
4 - 2-Ext
If other devices need to use the same telephone jack, make sure they are connected to the 2-Ext port on the back of the product.
Connect a single-line telephone to 2-Ext , and then pick up the receiver and listen for a dial tone. Make sure you are able to dial out using the telephone keypad. If you hear a dial tone and are able to dial out using the phone, the product is properly connected to a working telephone cord and telephone jack.
Figure 4: Fax and telephone
1 - Telephone jack
2 - Telephone line
3 - 1-Line
4 - 2-Ext
5 - Telephone
Figure 5: Fax and PC or modem
1 - Telephone jack
2 - Telephone line
3 - 1-Line
4 - 2-Ext
5 - PC or modem
If you change any cable connections, try sending and receiving a fax again to make sure that the issue is resolved.
Step eight: Remove any other devices from the telephone line
If any other devices, such as a telephone, an answering machine, or a modem, are connected to the telephone line, remove each device.
NOTE: Remove each device even if it is in another room, connected to another telephone jack, or connected using a line splitter.
Connect the product to an analog telephone line by connecting one end of the two-wire telephone cord directly to the telephone jack and then connecting the other end of the telephone cable directly to the 1-Line port on the back of the product.
Try to send a fax again.
Step nine: Perform a partial reset of the product
A partial reset of the product returns all fax settings to the default values. It might be necessary to reset the language and country/region settings after the partial reset is complete.
Disconnect the power cord from the back of the product.
Wait 20 seconds, and then press and hold # and 3 on the product control panel.
Connect the power cord to the back of the product, and then release the buttons when the product turns on.
The product is reset to factory defaults.
Try to send and receive faxes again. If the problem still exists, continue to the next step.
Step ten: Service the product
If you have completed all the steps listed above and are still experiencing a problem, service the product.
Aug 05, 2008 | HP Office Equipment & Supplies
Vehicle Parts & Accessories Logo
126 people viewed this question
Top General Electric Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a General Electric Vehicle Part and Accessory Expert? Answer questions, earn points and help others
