Question about Craftsman 4 Cycle Blower/Vac
My craftsman 4 cycle blowers air filter keeps clogging up with oil. What is causing it to do that?
    Problem Solver:
  • 21 Answers
Make sure you have the right mixture of oil and gas. mixtures to rich will plug up the filter
Posted on Nov 21, 2013
rwvanlue
  • 486 Answers
SOURCE: gas leaks from air filter. sears craftsman
engine is flooded,
spark plug fouled,
choke has been on too much while pulling recoil rope
ignition coil or switch is malfuncitoning
Posted on Nov 08, 2009
rotorcrafts
  • 302 Answers
SOURCE: Craftsman 2 cycle blower stalls.
Most Probably the problem lies in the adjustment of the carburettor. There are two needles in the carb one for lowend adjustment and one for high end adjustment. Your lowend adjustment seems fine. The highend needle needs to be adjusted. Following are some very detailed procedures for adjusting these types of carbs
http://tech.flygsw.org/walbro_tuneup.htm
http://www.drystacked.com/Walbro%20Carburetor%20Theory%20ebook1.pdf
If your machine has a carb other than a "Walbro" dont worry the procedures are same. I am sure if your engine has not completed its life span this will solve your problem.
Posted on May 19, 2010
SOURCE: what oil do you use in the four cycle motor/ 29cc
Generally speaking, if there is a place on a gas-powered device that is labeled "gas" & a separate location labeled "oil" than you will need to use a 4-cycle oil for that machine. If there is just a place to put gas, you would use a 2-cycle oil; however, you would need to read the directions/manual to find out the correct proportion of oil to use, because you will have to MIX the appropriate amount of oil with the correct amount of gas, making a oil/gas solution that you would use for that specific device.
Posted on Jun 01, 2010
  • 15 Answers
SOURCE: Craftsman 2 Cycle leaf blower has good spark &
YOU MIGHT CHECK THE MUFFLER AND SEE IF IT IS CLOGGED OR RESTRICTED. THIS COULD KEEP IT FROM RUNNING
Posted on Aug 30, 2010
  • 6468 Answers
SOURCE: craftsman 4-cycle weedeater armature air gap spec.?
i just use i layer of a brown paper bag
Posted on Mar 27, 2012
How do I change the oil in my 4 cycle engine Craftsman Leaf Blower?
If this is a hand held machine. It doesn't require engine oil changing.!
Although its a 4 cycle engine. its basically a 2 stroke engine with valves. It runs on the same fuel/ oil mix as a normal 2stroke engine. 50:1
Apr 21, 2016 | Craftsman Garden
Leaf blower runs on half choke
My craftsman leaf blower ran great for 4 years.. It stop running on me one day while using it.. I replace the carb, muffler and fuel filter with a new one.. it still will only run when the choke is half closed and don't run good doing that.. I have also noticed oil around the plug and muffler. I have to use either to get it started and I noticed when I pour a little oil in the spark plug hole before cranking it seems to run loner but not at full throttle think it might be piston rings shot.
Nov 11, 2013 | Craftsman 25cc Gas Blower
Leaf blower not pulling fuel into carbeurator
Check age of gas. Cannot be more than 30 days old.
Make sure to use fresh gas w/synthetic 2-cycle oil @ 40:1 ratio (1 gal.) Gas to 3.2 oz. Oil). Do not use old or stale oil/gas mixture. Always use the proper oil/gas mix. If you do not, your engine will suffer rapid, permanent damage.May need to replace carburetor.
Dec 31, 2011 | Craftsman Garden
Craftsman 2 Cycle leaf blower has good spark & fires but won't run. Pulled off fuel filter & makes no difference.
Aug 29, 2010 | Craftsman Garden
Someone just gave me a Craftsman 32cc blower without the manual. What fuel does this use?
IF it says 4 CYCLE then it uses regular gas.(87-89 octane unleaded) Another sign to prove it's 4 cycle it should have a crankcase you keep filled with oil.
Jul 18, 2010 | Craftsman 4 Cycle Blower/Vac
Leaf blower wont go into full speed when you shift the throttle. changed the plug, gas and checked the filter. Do these things have a fuel filter?
Yes, there is a small filter at the end of the pick up line. However, you did not specify whether you are "starving" for fuel, indicating a filter that is clogging. Most likely, you have a dirty air filter, it may look clean but is not letting in enough air. I believe there is a carb adjustment available on that engine, if you elect to adjust it, keep the current reference marked, and make adjustments in 1/8 turns, no more than 1/2 run in, or 1/2 turn out.
Apr 15, 2010 | Craftsman 4 Cycle Blower/Vac
Won't start --has gas--has spark craftsman leaf bower
most likely the air filter is clogged, take it out blow it out or spray water through it and allow it to dry completely.
alterinavely, just pouring a small amount of gas onto the filter should make it work, i would do that even if you do clean it properly.
this method works for cars too!
Nov 07, 2009 | Craftsman 4 Cycle Blower/Vac
Model 358 craftsman blower, where is the fuel filter
Follow the fuel line from the tank to the carb. If it has one, its in that tubing line. There will prolly be a particle filter screen inside the tank to keep crud from getting to the carb. Other than that - there's really not much to the fuel system on these.
Jun 22, 2009 | Craftsman 4 Cycle Blower/Vac
Craftsman leaf blower
Hi
Check the fuel lines,fuel filter and clean the fuel tank.Disassembly the carb and clean it carefully.Diafragm type carb has a fuelpump,pay attention to it ,has to be tighten not folded.When the engine gets warm ,the fuelpump cannot keep the right proportion of fuel and the air/fuel mixture is changing.It has to be changed.
regards savumihai71
Nov 09, 2008 | Craftsman 4 Cycle Blower/Vac
Craftsman 4 Cycle Blower/Vac Logo
127 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
