Question about Kitchen Appliances - Others
Magic chef dehydrator
Brand new but won't turn on.
SOURCE: Magic chef oven won`t heat
I can not get ovento work it will work if I have it on manuall but I cn not get if off aut It is a Chef Constellation Delux We have just brough this hopuse and thwere is no manuall to operate
Rwegards Fay
Posted on Apr 22, 2008
SOURCE: Kneading Blade for Magic Chef CBM 250-2
I found a compatible belt!!! It's a Dayco # 15260, which you can order from partstore.com!!
Posted on Nov 25, 2008
  • 12 Answers
SOURCE: gas oven won"t stay lit
you eaither have a bad regulator from the tank to the house or you have a bad appliance regulator behind your appliance you would need to check the pressure at the appliance if it is propane you should have between 10-14'' of water colum or if it is nat-gas it should be 4-7'' of w/c
Posted on Feb 20, 2009
  • 7 Answers
SOURCE: magic chef dryer quit working
There is a thermal fuse inside the dryer usually located behind the back cover on the upper part of the combustion chamber. When this fuse "blows" it turns off power to the whole dryer. This keeps your house from burning to the grown, and you from dying. The fuse "blows" for a reason, most likely to is lint build-up in the dryer and/or dryer vent system. The good new it only cost a few dollars to get a new one. The bad news is you need to find out why it "blew", the dryer got to hot for a reason.
Posted on Mar 04, 2010
heatman101
  • 43501 Answers
SOURCE: ovens not lighting magic chef
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
wwt
Posted on Sep 30, 2010
Need house & home dehydrator manual
Hello, Vickie -
Do you know the model of your House & Home Food Dehydrator?
Apparently the House & Home Model LD-1010 Food Dehydrator is the same as the Magic Chef Model LD-1010 Food Dehydrator. Also, I have seen information indicating the model LD-1010 is the same as (or very close to) model 469-1. Perhaps yours is a a model LD-1010
I have not yet found a PDF version (electronic, Adobe Acrobat Reader software) of an instruction manual for a House & Home food dehydrator or a Magic Chef food dehydrator, any model.
However, I have found directions (not the full manual) for using a Magic Chef food dehydrator here:
https://www.leaf.tv/articles/instructions-on-using-a-magic-chef-food-dehydrator/
I have found manuals for other similar food dehydrators (PDF documents), which may prove instructive:
http://pdf.lowes.com/operatingguides/1000317095_oper.pdf
and:
https://www.manualslib.com/manual/107232/Mr-Coffee-Fd5.html
Note: I also found a 1997 U.S. Consumer Product Safety Commission for a K-Tel Model LD-1010 food dehydrator:
https://www.cpsc.gov/Recalls/1997/cpsc-k-tel-international-usa-inc-announce-recall-to-replace-food-dehydrators
I have not been able to determine if the K-Tel product was manufactured by the same company which made the House & Home LD-1010 Food Dehydrator or the Magic Chef Model LD-1010 Food Dehydrator. However, I recommend you read the full recall notice and be watchful for any overheating when you use the dehydrator.
Note: If you eventually choose to dispose of the dehydrator, please do not toss it in the trash. Instead, make sure you send it to electronics recycling in your area.
Best wishes.
Mar 27, 2018 | Kitchen Appliances - Others
I have a brand new magic chef microwave that don't heat food
brand new --under warranty --take it to a service agent for a warranty check
if you touch it the warranty is void
Feb 28, 2017 | Magic Chef Microwave Ovens
Hole in coolant line magic chef stainless steel refridge
You will need to purchase a new unit.The problem when moisture and oxygen enters the sealed system, it breaks down the refrigerant into hydrochloric and hydrofluoric acids, which then in turn damage the mechanical components. You have a major problem, and I'll save you a house call charge by telling you that the entire sealed system has to be replaced. If you only have the system evacuated and dehydrated, then recharge the system, which even if its done properly and legally, by an EPA Certified Type I Technician, in other words, not recommended for a DIYer, due to the process required, would still be a major repair, and would not last as long as it should due to the acid damage.
Nov 02, 2012 | Magic Chef Refrigerators
Magic chef food dehydrator model 469-1
http://kitchen.manualsonline.com/mdownloads/c95aabcf-2067-4b32-90da-92d2228fe8e1.pdf (provides pdf manual for 469-1, not nesco, et al below)
Jan 16, 2012 | Kitchen Appliances - Others
Manual for GE magic chef food dehydrator. Model # LD-1010
Need plastic lid for Walmart GE food dehydrator model LD 1010B
Sep 15, 2010 | GE Food Processors
Who manufactures Magic Chef refrigerators
google "magic chef" trademarks you may be supprised.(haier IS THE WORLDS LARGEST MANUFACTURER OF WHITE GOODS IN THE WORLD......MADE IN .......CHINA....)
tata make the worlds cheapest NEW car 1500 dollars
pre tax......made in india.
Jul 04, 2010 | Magic Chef CTB1821AR Top Freezer...
Magic Chef Broiler won't turn off
If this is brand new you need to get this taken care of under warranty. Any thing you try to do to repair will void the warranty and with all the electronics on this stove you want warranty to repair. Sorry I wasn't much help but you don't want the warranty voided.
Mar 10, 2010 | Magic Chef CER3725AA Electric Kitchen...
Vent fan high comes on automatically with cooking
Right, that would be MCO10UW and the owner's manual is here.
The owner's manual does say this, of course,
"To prevent overheating from taking place, the exhaust
fan is designed to automatically turn on at a low speed if
excessive temperatures occur. Should this happen, the
fan cannot be manually turned off, but it will
automatically turn off when the internal parts have
cooled. The fan may stay on for up to an hour after the
range and microwave oven controls have been turned
off."
That;'s standard on microwaves.
But these models do have a separate internal cooling fan (which should run any time you microwave) plus the hood vent exhaust fan, which should only run when you select it, or if there is an excessive stovetop or under-hood temperature.
So if it comes on whenever you microwave, that is incorrect.
When that happens, it's usually a defective vent thermal switch (a.k.a. hood TCO).
But since it's brand new, I would certainly contact Magic Chef about this. If it's in need of repair, they will fix it free, assuming the oven wasn't physically damaged.
For more help from Magic Chef / Ewave see here or their contact page.
For Magic Chef in Canada call 866.587.2002
Jan 08, 2009 | Magic Chef CMV1000B Microwave Oven
Kitchen Appliances - Others Logo
65 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
