Question about Kohler Home
Cleaning vikrell bathtubs
Is mr. clean magic eraser ok to clean vikrell bathtubs
  • 32 Answers
SOURCE: Screen Discoloration Problem
dJbsharp1: Check if the cleaner you use discolor or remove the clear of the screen. Touch the cleaned part and somewhere else on the screen to see if is rougher than the part you didn't clean-up. If this did not occur you can clean it up completely and watch the difference. If it's rough as I described you, a replacement will be necessary. It is easy to replace. Very easy. Part Number: 23430829 https://www.vancebaldwin.com/webwiz/wwiz.asp?wwizmstr=WEB.SEE&partnumber=4003246&smodel=56H80 Click below to all the info and also for instructions on how to do-it-yourself with the service manual for FREE!!! Good Luck !!! https://www.vancebaldwin.com/shop/research_new/TBA/56H80.pdf SithPitt
Posted on Jul 04, 2007
SOURCE: cleaning ceramic cooktop
we use Bar Keepers Friend with a rag or sponge. I've had the oven for 5 years and have no stains on the cooktop. I highly recommend it. Hope this helps.
Posted on Sep 15, 2009
  • 715 Answers
SOURCE: Can't get tape marks off black refrigerator, tried
try WD-40
Posted on Oct 08, 2009
  • 827 Answers
SOURCE: There is always a yellowish staining on the top
the yellowish "staining" is a result of a bad seal. Since it is heat changing the color of the surface, you would probably have to do some damage to remove the discoloration, either like a soft abrasive scrub or other, bleach will not fix that.
Sounds like the cleaning cycle could be too long or otherwise too hot for too long? Perhaps a wipe down with a damp cloth to the interior of the oven prior to a self clean to remove any loose material may help.. Also if there are any other vents for this oven (say under one of the burners of the stove top) make sure they are kept free and clear of any blockage of air flow..
Best regards
Ck
Posted on Mar 12, 2011
SD Tech
  • 14553 Answers
SOURCE: cloudy microwave keypad. dries cloudy
It would have to be replaced as too harsh a chemical was used to clean it.
Posted on Jun 15, 2012
How can I remove coloured marks made by toys
Mr Clean magic eraser. Its a white sponge. It works.
Jun 02, 2014 | Villeroy & Boch Home
We did some fruit canning. Burnt sugar is on our ceramic stove top. It is a Sears Frigidaire. What can I do, use, to get the "burnt" off without scrating the surface?
the Mr. Clean Magic Eraser works pretty well to clean the glass without scratching the glass...the glass is pretty durable and not that easy to scratch..in addation to servicing them i have a glass stove in my house and use the Magic Eraser with pretty good results
Sep 08, 2011 | KitchenAid KESI901P Electric Kitchen Range
How do I clean burn marks from my white stove after using the self cleaning feature?
Most of the time they will not come off..But most people will use Mr.Clean magic eraser.
Jun 06, 2011 | GE Kitchen Ranges
Crayons on wall paint
hi!
if your precious lil one made a nice desing in your wall with crayons, the solution is MR CLEAN MAGIC ERASER.
i tried with everithing(heat/oxyclean/wd40/go gone)as all the web pages recomended AND NOTHING WORKS, but with this magic eraser was so easy to clean it!!
good luck!
jess
Sep 24, 2010 | Crayola Toys
Just the plastic glass cove the digital clock are spoted by clean solution, my clean lady use stanley steel clean& shine and when lokk close to the clock you see small dots all over the small glass. I...
try mr. clean magic eraser. I have had the same probleam with a few of my customers and the magic eraser did the trick give that a try befor anything else
Feb 24, 2010 | Coffee Makers & Espresso Machines
Orange stain on tub surface
Have you tried Mr.Clean Magic Eraser?
Jan 05, 2010 | Maax Calla 6042 Bathtub - 101058-000
Blackened spots on the ceran cook top's most frequently used burner will not come off, even with prescribed cleaner
Try using the Mr Clean Magic Eraser, it works well on most surfaces that other cleaners don't. Just be sure to follow the Mr Clean instructions and rinse out the sponge frequently and use it damp.
I've used this for cleaning just about everything, when everything else has failed. It's the neatest cleaning product I've seen in years.
Hope you find this Very Helpful and best regards!
Aug 25, 2009 | Maytag MER5770 Electric Kitchen Range
I would like to clean inside my oven on the top
if you have a self clean oven, do not use an abrasive cleaner to clean
I would recommend running a self clean cycle, and anything left
"Mr. Clean Magic eraser" should take care of it.
it works miracles in ovens
May 26, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Can't remove burnt milk from right burner on stovetop?
I'm happy to say burnt milk can be removed with a combination of cerama bryte and let sit for one hour and then lots o elbow grease hard rubbling with also applying Mr. Clean Magic Eraser. The Mr. Clean Magic Eraser works very well but you have to still rub alot to get it safely scratch-free removed.
Dec 13, 2008 | Jenn-Air JED8430 Electric Cooktop
Home Logo
230 people viewed this question
Top Kohler Home Experts
john h
Tim Whalen
Mike
Are you a Kohler Home Expert? Answer questions, earn points and help others
