Question about Measuring Tools & Sensors
I have a Robinair Cooltech 34134Z AC machine and the digital display will not come on
Machine turns on, can hear fan running, digital display inoperative
mhkamran
  • 180 Answers
SOURCE: I have a Robinair cooltech 700 a/c machine. does
Please check your machine ISV tank liquid hose,it's may lose or too tight
Posted on Jun 11, 2010
mhkamran
  • 180 Answers
SOURCE: i have a robinair a/c machine cooltech i need to
Form the main menu go to ''CHANGE DEFAULT'' then press 5454 & YES key (passwoed to access default option).Once you enter to default menu,go to "SCALE CALIBRATION" & press YES key.now follow the on screen text.Hope this will solve your problem.
NOTE:you should have 9KG/20LBS of weight for scale calibra
Posted on Jul 01, 2010
mhkamran
  • 180 Answers
SOURCE: ROBINAIR 347002K WON'T INJECT OIL
I think you'v try to inject the oil from ''WRONG'' side,as you say RECOVER/VACUUM which is LOW side manifold valve. You should inject the oil from HIGH side ( Turn the high side valve to CHARGE/OIL INJECT after vacuuming & low side vulv to CLOSE possition ) with pressing F1 key. once you press it then hold the key as long as you wish to inject the oil. If you try this way & you still have problem with oil injection then you may need to check oil injection CHECK VALVE or oil injection SOLENOID ( Both located under Hidg side panel mountin valve). NOTE: UV Dye is not a problem for oil injection! I hope this will help you to solve the problem,Good luck. Don't forge to vote for my solution!
Posted on Jul 10, 2010
mhkamran
  • 180 Answers
SOURCE: robinair cooltech 34788 scale error reset
You may overfill the ISV tank. #1 Open front cover & close LIQUID valve on the ISV. #2 Disconnect LIQUID hose from tank,then open tank liquid valve (which you close earlier) to reduce some refrigerant manually from the ISV tank. #3 after reduce refrigerant from tank, re-connect everything & switch on the machine. #4 If you still have the same problem then you have to re-calibrate the scal. I hope this will help you
Posted on Nov 05, 2010
mhkamran
  • 180 Answers
SOURCE: The high pressure unit is disabled in my Robinair
This is a common problrm of Robinair 34700Z / 347002k & 347112k series machine.so don't worry just do the following :- 1# Verify the ISV tank is not overfilled.if full,remove refrigerant manually from tank. 2# Verify if there is high pressure in the tank.Purge excess air from the tank manually.( Open air purge hose from the tank,then press tank valve as needed) 3#Check the high pressure switch for proper operation,if not then replace high pressure switch.Hope this will solve your problem, if so please vot for it
Posted on Jan 04, 2011
HELLO I HAVE A ROBINAIR 34788, MY UNIT WILL NOT CLEAR THE LINES. I TRIED SHUTTING OFF AND ON , BUT LINES ARE STILL HOLDING PRESSURE. I ALSO CANT RECOVER BECAUSE IT WILL NOT GET PAST CLEARING. THANK YOU
sounds like you need to check the grommet between the motor and the pump. If this grommet connector breaks, the motor will come on but the pump will not work. Turn the unit upside down and look where the motor connects to the pump. Be aware if you can lose your oil while turning upside down unless you cap the port and exhaust. If this is it, go straight to the Robinair web site and you can order one for around $25.
May 11, 2011 | Robinair CoolTech 6 CFM Two Stage Vacuum...
We have a robinair cooltech 34700z, looking for directions to change pump oil, can anyone help? thanks
For change vacuum pump oil follow the bellow step: Press main menu then keep pressing up or down arrow key till display show "CHANGE VACUUM OIL" then press "YES" key. Now vacuum pump will run for two minute & stop automatically. When pump stop you just open the oil drain cap and drain all used oil from pump (oil drain cap located outside of the machine near high & low side hose). After draining all used oil replace oil drain cap and fill 5 ounce new ROBINAIR vacuum pump oil then press "YES" key and keep filling oil up to middle of sight glass of vacuum pump. Press "STOP" key to complete the process.
NOTE: Do not over fill the pump & do not use any COMPRESSOR oil on the vacuum pump!
Hope this will help you & if it is please vote for my support
Hope this will help you. If so please vote for it. Good luck
Apr 08, 2011 | Robinair Cool Tech 34700Z Recovery,...
The high pressure unit is disabled in my Robinair Cooltech 34700z wat could be the problem?
Jan 04, 2011 | Robinair Cool Tech 34700Z Recovery,...
Hi, I have a robbin 34134z indicates high pressure and do not work. At times it works and then stops working. I can do? . I live in Venezuela and here there is no Robinair agent indicated as repair them. I...
This is a common problem of Robinair 34700Z / 347002k & 347112k series machine.so don't worry just do the following :- 1# May the ISV tank is not overfilled,remove some refrigerant manually from tank. 2# Purge excess air from the tank manually.( Open air purge hose from the tank,then press tank valve as needed to purge air from the tank) 3#Check the air purge solenoid for proper operation.Hope this will solve your problem, Best of luck & vote for my solution!
Nov 25, 2010 | Robinair Cool Tech 34700Z Recovery,...
Robinair cooltech 34788 scale error reset
Nov 04, 2010 | Robinair Cool Tech 34700Z Recovery,...
34788 cool tech will not accept new filter codes tried two different filters and is locked out of recovery
It will not unlock till you enter origenal robinair Spin-on filter code! Try with this code FD32C46B01. This is a free gift for you. Good luck & don't forget to vote it.
Aug 05, 2010 | Robinair Cool Tech 34700Z Recovery,...
PROBLEM WITH WEIGHT CALIBRATION
Calibration procedure for Robinair AC machine.
NOTE:FOR SCAL CALIBRATION YOU SHOULD HAVE 9KG/20LB OF WEIGHT.From main menu go to change default (press 8787 for old type machine or 5454 new type machine)
then press enter/start key.after enter to default nenu you have to select calibrate scal option.press again enter/start key then follow the on scree message.once you done so,press stop/exit key to complete the prcess.
Aug 18, 2009 | Robinair Cool Tech 34700Z Recovery,...
Measuring Tools & Sensors Logo
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
