Question about Boating
80hp yamaha idles good.but when I cuts off when put in gear
    Sergeant:
  • 456 Answers
Sounds like it is running on two cyl,could be many things,check for spark,change plugs,check compression,clean carbs,check fuel pump diaphragm,check stator,coils,cdi,trigger coil good luck
Posted on Nov 22, 2013
2 Suggested Answers
  • 86 Answers
SOURCE: 1996 evinrude outboard stalls when put in gear
Start by adjusting your idle mixture screw. Start at 1 1/2 turns out and with the engine in gear at an idle slowly turn the screw clockwise until the engine starts to die, then back off a half turn and that will be your proper setting. If you need to you can bump up your idle stop screw just a touch so it will hold also.
Posted on Aug 10, 2009
2001 XV 1600 Road Star Silverado lurches forward and dies when put into gear
Hi, Tom and the usual suspects are:
1. Clutch not properly adjusted.
2. Clutch plates rusted together.
3. Hydraulic clutch needs bleeding.
4. Faulty clutch slave cylinder.
5. Faulty clutch ramp mechanism.
6. Broken clutch rod
7. Clutch pack loose on the main shaft.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Re dies when put in gear Road Star Forum Yamaha Road Star
runs at idle but dies when in gear
Yamaha XV16AL Service Manual
OEM parts for Yamaha
YAMAHA XV1600A Owner Manual
Aug 11, 2017 | 2001 Yamaha XV 1600 Wild Star
1996 Yamaha XV 535 Virago DX will not start
You have clogged pilot jets in the carbs.
Aug 02, 2017 | 1996 Yamaha XV 535 Virago DX
I have a 1986 yamaha virago 1100..when I first start the bike and put it into gear it dies out...when I rev it to 7000 rpm it goes into gear and is fine for the day until the next day
Hi, Floyd and the usual suspects are:
1. Idle circuit and transfer ports clogged.
2. Air fuel mixture adjustment too lean.
3. Pilot jet clogged.
4. Faulty accelerator pump.
5. Float level too low.
6. Float bowl contaminated old fuel, water, dirt, rust, etc.
7. Float bowl vent or overflow tube clogged.
8. Fuel flow to carburetor restricted.
9. Intake manifold leak.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
Engine dies when put into Gear
Stalls when put in first gear
Yamaha 1986 XV1000 Service Manual
Aug 04, 2016 | Yamaha Motorcycles
FZS 600 Fazer stalls when put in gear
Hi, Anonymous and the usual suspects are:
1. Faulty wiring to any safety switch.
2. Safety switches loose at the mounting point.
3. Faulty kickstand safety switch.
4. Failed kickstand safety switch circuit diode.
5. Stretched side stand spring.
6. Side stand not coming up far enough to disengage switch.
7. Faulty clutch lever safety switch.
8. Faulty neutral safety switch.
9. Clutch not properly adjusted.
10. Clutch plates sticking, forward lurch
For more information about your question and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Engine cuts out when put in gear
Yamaha FZS600 98 Service Manual
YAMAHA FZS600 Owner Manual
Apr 08, 2014 | 2002 Yamaha FZS 600 Fazer
Yamaha Ybr 125 engine cuts out when I put it in gear
Hi, Supersonicjo and the usual suspects are:
https://yamahaclub.com/forums/topic/35411-yamaha-ybr125-fires-up-in-neutral-but-dies-the-second-it-goes-into-gear
Yamaha YBR125ED 2005 Service Manual
YAMAHA YBR125ED Owner Manual
Feb 01, 2013 | Yamaha Ybr 125 Motorcycles
I think my bike is idled to high i put it 1sT AND IT DIES WHATS THE PROBLEM
Hi, Renee and the usual suspects are:
For more information about your question and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Starts in neutral dies in gear
XZ550 and XZ400 resources
Yamaha XZ 550 1982
Jul 11, 2012 | 1982 Yamaha XZ 550
1982 yamaha xj650 starting
Check the electrical switch in the clutch lever, most bikes have one as a safety, so you cant start it in gear, unless the clutch is in, could be a faulty switch, also do you have a switch on your side stand, sometimes these can be faulty as well.
Apr 17, 2010 | 1982 Yamaha XJ 650
Engine cuts out when selecting gears
Hi and welcome to FixYa,
Check, clean, bypass or replace the sidestand switch.
Good luck and thank you for asking FixYa.
Apr 16, 2010 | 1986 Yamaha FJ 1100
Boating Logo
55 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
