Question about Husqvarna 3100 PSI 2.8 GPM Gas Pressure Washer 020490
Operator's manual for husqvarna 3100 psi 2.8 gpm gas pressure washer 020490her
  • 794 Answers
How to hook hose to ryobi pressure washer
same as an air compressor connection,pull back on outside and insert in middle
Jul 25, 2015 | Ryobi Gas Pressure Washer: 3100 psi 2.5...
When i pull the trigger on my pressure washer it idle's down instead of idling up causing lower pressure, how do i fix this problem?
If it has seat with water in it. For long periods of time it can cause problems with the pump take it apart and clean it or rebuilt it
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jim_c09d8140f32619a8
Jul 12, 2015 | Ryobi Gas Pressure Washer: 3100 psi 2.5...
I HAVE A RYOBI PRESSURE WASHER 3100 PSI WITH HONDA ENGINE PURCHASED FROM HOMEDEPOT USED IT 2 WEEKS AGO RAN PERFECT TRYED USING YESTERDAY AND I HAVE NO PRESSURE THE UNIT IS ONLY 10 MONTHS OLD ANY SUGGE
  • I have the exact same pressure washer..bought 10 months ago from Home Depot with the same problem..no pressure. Have you had any luck finding out what the issue is?
Jul 22, 2014 | Ryobi Gas Pressure Washer: 3100 psi 2.5...
Why do i have no pressure when running?
divertervalve shot. never run a pressure washer for more than a few seconds without pulling trigger. Rebulid kits are available however todays chinese junk pumps quit rather quickly. order a new pump on ebay and read your owners manual and last but not least do what it says.
Jun 27, 2014 | Husqvarna 3100 PSI 2.8 GPM Gas Pressure...
Why won't the cleaning solution come out of the hose for Husqvarna 3100 PSI 2.8 GPM Gas Pressure Washer 020490?
Most people I run into with this problem are trying to get the cleaning solution to work with one of the high pressure tips, usually red, green, white or yellow. The only way to make the machine use the cleaning solution is with the low pressure, soap tip, usually black. With the high pressure tips there is too much back pressure for the solution to be picked up and mixed into the water stream.
Apr 28, 2014 | Husqvarna 3100 PSI 2.8 GPM Gas Pressure...
Cannot remove hose from water pump-Husqvarna model 020490 power washer
Use pliers an next time don't gorilla it on there. The rubber gasket doesn't need super strength to tighten it enough to do its job
Nov 03, 2013 | Husqvarna 3100 PSI 2.8 GPM Gas Pressure...
Husqvarna 3100 PSI 2.8 GPM Gas Pressure Washer 020490 Logo
617 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
