Question about Canon imageRUNNER 400S Copier
Data cable input?!
Several people in my office have looked and none of us can find it! We need to hook the copier/printer up to our network, but cannot find where to plug in the data cable. Manual is no help. Anyone know?
  • 62 Answers
IR400 requires a printer board fitted to it to make it network capable. The data cable goes in the socket at the rear-left of the machine.
Posted on Oct 08, 2007
SOURCE:
We use a Canon 8180c in the office and it worked fine for a while on a network. (except that it changes the port everytime the power goes out) Now we can't even pick it up on the network. The lights at...
The simplest solution would be to set the printer up to use a static IP Address. It sounds like it's currently setup to get a dynamic address via DHCP - which would explain it getting a new address every time the power goes out.
If you set the printer up with a static address you can then setup each computer to use that IP port. That should maintain a direct connection that you won't lose after a power outage.
If you need additional help just reply to this solution.
May 03, 2011 | Canon imageCLASS MF8180C All-In-One Laser...
IR2200 as a printer/scanner - wireless network configuration
You need to hook an ethernet cable into your network. You could get a wireless router to extend another one and connect via ethernet into that if you prefer.
For setting up network settings, do you have the Network Guide?
Go to page 2-11 and follow the instructions there.
You can click the DHCP icon and hopefully you'll get an IP address etc. (you may have to restart using switch on right hand side of copier to turn off, wait a while then turn back on). Once you have an IP address click on the DHCP icon again to make sure it's not filled in with black and save settings.
IP address must be in same range as other devices on your network e.g 192.168.1.x or 192.168.0.x (only specify a number for x between 1 and 254, must not be used by another device). Subnet mask must be same as for other devices. It's probably 255.255.255.0 Canon Network ScanGear 2.21 (don't get the colour version) can be found on the Canon website (google it). Instructions for scanning are in the manual included with the download.
Jan 09, 2010 | Canon imageRUNNER 2200
I need the cable from the printer to the computer. where do i purchase one
u can ask for a usb cable 4 pin at the end and square shape on the other end
Nov 07, 2009 | Lexmark X5070 ALL-IN-ONE InkJet Printer
HP DeskJet 1220C
Hp has an excellent online support site, which will usually offer the best sequence of troubleshooting solutions for your problem, provided you can locate them. Take a look here and here, for a couple of possible options. Also try clearing the print spooler by following these instructions.
If none of that works, try resetting the printer. This can be done by turning it off, disconnecting the electrical and data cables from the printer, wait a minute or so, then restarting it with only the electrical cable connected, then turn off and reconnect the usb or data cable and restart...frequently this will sort it all out...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
May 15, 2009 | HP DeskJet 1220c/ps InkJet Printer
Printer hooked up right but reads on the screen check network connection
If the unit states check network connection:
Check the network settings: additional functions, report settings, network, user data list, yes. Check the settings shown here. update and power cycle the unit if needed. You much power cycle after changing IP settings.
Examine the network cable. Look for link lights on the unit and where it connects to the network. Consider also taking the network cable and plug it into another device. If the other device cannot access your network, you know that it is the network side. If the other device works fine, you know that you have an issue on the copier.
May 06, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Can not hook up an imagerunner 330 for the office.
Try LPR port called print with the appropriat ip address
Mar 23, 2009 | Canon imageRUNNER 330 Printer
Oki 5150 can not network
Where your network cable plugs into the printer there should be a green led on and possibly an orange one flashing (Shows data passing thru). If neither are lit then try another network cable (may be stretched). If still nothing then just try another network port. if still nothing then yes the network port which is part of the main board will be U.S. and new main board will be required. maybe expensive.....
Aug 04, 2017 | OKI C5150n Led Printer
Computer can't find printer
Your using an Ethernet cable and your not on a network. You most likely need a USB cable, or connect the computer and printer together with a router. How are you accessing the internet from home?
Nov 19, 2008 | HP Laserjet 2605 Printer
The 8860 printer is showing offline on the network
sounds like you need to open the sharing section of the printer set up, and set it for sharing on the network
Jun 16, 2008 | Brother MFC-8860DN All-In-One Laser...
Canon imageRUNNER 400S Copier Logo
54 people viewed this question
Clive
Clive
old marine
old marine
Ekse
