Question about Husqvarna 3100 PSI 2.8 GPM Gas Pressure Washer 020490
Where can I print owner's manual for husqvarna 3100 2.8 gpm gas pressure washer
    Sergeant:
  • 417 Answers
Probably from their website.
Posted on Nov 22, 2013
Chemical sihone line blows water instead of sucking out the cleaning fluid
Ron, it sounds like a faulty suction valve may need replaced.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Feb 28, 2016 | Husqvarna 3100 PSI 2.8 GPM Gas Pressure...
How to hook hose to ryobi pressure washer
same as an air compressor connection,pull back on outside and insert in middle
Jul 25, 2015 | Ryobi Gas Pressure Washer: 3100 psi 2.5...
Starter cord want pull on husqvarna model 020524 pressure washer, not even with pressure of water off
hold the trigger down on the spray gun and then try, the pressure is built up in the pump - the pump can't turn against the back pressure.
Dec 27, 2014 | Husqvarna 3300 PSI 3.2 GPM Gas Pressure...
Why do i have no pressure when running?
divertervalve shot. never run a pressure washer for more than a few seconds without pulling trigger. Rebulid kits are available however todays chinese junk pumps quit rather quickly. order a new pump on ebay and read your owners manual and last but not least do what it says.
Jun 27, 2014 | Husqvarna 3100 PSI 2.8 GPM Gas Pressure...
Why won't the cleaning solution come out of the hose for Husqvarna 3100 PSI 2.8 GPM Gas Pressure Washer 020490?
Most people I run into with this problem are trying to get the cleaning solution to work with one of the high pressure tips, usually red, green, white or yellow. The only way to make the machine use the cleaning solution is with the low pressure, soap tip, usually black. With the high pressure tips there is too much back pressure for the solution to be picked up and mixed into the water stream.
Apr 28, 2014 | Husqvarna 3100 PSI 2.8 GPM Gas Pressure...
Cannot remove hose from water pump-Husqvarna model 020490 power washer
Use pliers an next time don't gorilla it on there. The rubber gasket doesn't need super strength to tighten it enough to do its job
Nov 03, 2013 | Husqvarna 3100 PSI 2.8 GPM Gas Pressure...
Where do you add the pump oil and where do you add the engine oil on husqvarna 020490 pressure washer. I see a yellow oil plug on both sides.
Hi Andy.
The yellow oil plugs are for the motor. At the bottom of the crankcase you should also see a screwed drain plug. Remove this, allow the oil to run out, replace and refill with a good quality multigrade engine oil.
The water pump oil may or may not be accessible, depends on the pump manufacturer. If you have a sight glass, you will be able to drain and change the oil. You will also have a filler cap with a breather.
Use a good quality tractor transmission oil or oil supplied by the manufacturer. DO NOT USE ENGINE OIL IN THE PUMP TRANSMISSION. It may aerate and overflow.
In normal use a pressure washer should not use either engine oil or pump oil between servicing. Excessive engine oil consumption indicates a tired motor. Oil consumption by the water pump is a big indicator of overuse.
Husqvarna 3100 PSI 2.8 GPM Gas Pressure Washer 020490 Logo
218 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
