Question about Keystone Plastic Alcohol Torch Keystone
Plastic alcohol torch - Keystone Plastic Alcohol Torch Keystone
How to remove sharpie off hard plastic
The vehicle for Sharpie is alcohol. Using a Q tip or swab wetted with denatured alcohol, test it on an inconspicuous area of the plastic to make sure it won't effect the finish first, then gently attempt to erase the marks. It may require several applications depending on the porosity of the plastic. Some plastics will absorb the ink too deeply for removal by this method.
Mar 22, 2014 | Cars & Trucks
How to replace u-joints
you have to heat the old u joints up witha torch and it will pop out in a second they are put in with a plastic to keep em in. heating them up melts the plastic you will see what im talking about when you put the torch to em.
Mar 03, 2011 | 1999 Chevrolet S-10 Pickup
How do I refill a Scripto Aim n Flame lighter? This is a plastic and metal wand with a plastic handle and metal barrel. About 6 inches long. I use it to start a fire in the fireplace or get the grill...
The new Scripto Aim n Flame disposable butane torch lighter. Aim n Flame is the first low cost disposable torch lighter - no messy refilling to worry about. Yet, it lasts for thousands of lights. Child resistant lighters.
No reifills.
http://www.rvwholesalers.com/catalog/scripto-aim-n-flame-lighter-03-0287.html
Dec 17, 2009 | Kitchen Ranges
I am trying to change the blade on my Bosch PHO1 planer. I have taken out the two grub screws holding it but it won't release - any ideas?
If the blades are hard to remove, you will have to remove the blade clamp completely in order to clean everything up. Your blades are probably gummed up from use. If you have a small torch available, you may want to try heating it up a little, this will release the blade (if you are using HSS blades). Be carefull not to melt any plastic in the surrounding areas. If you are using the micro carbide blades you should be able to press the blades out from the side using a scrap piece of wood without removing the screws (just loosen). Use mineral spirits or lacquer thinner or alcohol to clean all surfaces so your new blades will seat properly.
Oct 09, 2009 | Bosch 1594K 3 1/4" X 3/32" Planer Kit with...
1 red light on xbox tv says e74
This happens a lot which is then i followed by the 3 red rings(red rings of death). is what you need to do is open your'e console, their are help video's on U tube for this. Once your console is open and you have the mother board taken out you need to remove the heat sinks which are on top of the chips. just un-snap the x clamps (on the bottom of the motherboard) and take off the heat sinks. unscrew the tabs on the bottom of the heats sinks and take them out. now take one of the heat sinks to a hardware store and find 8 screws about an inch long that screw into the heat sinks, also buy 16 plastic washers and 8 metal washers that fit onto the screws.also try to find a BUTANE Torch this will save you from the expensive heatguns and work just as good. the last thing you need is Arctic Silver 5 which can be found for 5 bucks on ebay. now once you have this you need to lay your motherboard on a flat inflammable area. light the torch and make shure it is on the LOWEST setting and that the flame is about 3/4 inch long and make a sort on hissing sound. make shure the top of the chips are cleaned with a paper towel of the paste. start with the torch about 3 inches over a chip and keep it moving with a sweeping motion after about 30 seconds start to get close but not to close about an inch an a half away and keep making sweeping and circular movements for about 2 min. do not get to close. now move to the next chip and do the same thing. now after ur done with the chips move the torch away about 3inches and keep heat on both chips for another minute and let them cool for a total of 10 to 15 minutes. once they are cool to the touch clean off the metal parts of the chips with alcohol (I prefer acetone too) make shure they have a mirror like finish and put a very little glob of the arctic silver on the metal chips and evenly flaten it out till it covers them evenly, make sure to apply enough! ( i used the side of a allen wrench, its less messy). now on the bottom of both heat sinks, clean them off with acetone or alcohol and scrub them very firmly to get off the grime from the paste. now put one plastic washer on each screw and insert them through the bottom of the holes surrounding the chips flip the mother board over and put the other 8 plastic washers on the screws and on top of these put on the 8 metal washers. then put the heat sinks on and tighten them down. once you put the mother board in the metal casing, plug it in(dont fully assemble it yet) now test out your xbox by pressing the little button on the ring of lights board and let it boot up a usual. If it works then ur done, but if 3 red lights start blinking or two red light start blinking you need to adjust the 8 screws. through the 8 holes in the bottom of the metal casing stick a small screwdriver in there and make sure they are all snug but not to tight and then loosin each one about an 1/8 of a turn till there just a little loose. keep testing and adjusting the screws till it boots up with the green lights.
THIS WILL REPAIR 3RED LIGHTS,FREEZING,NO VIDEO, 2 red LIGHTS. in most cases 1 RED LIGHT will be fixed
GO TO A HARDWARE STORE FIND THE FOLLOWING THINGS IF YOU DONT HAVE THEM
16 plastic washers
8 metal washers(make sure all the washers fit snugly around the screws and are very thin)
8 screws about an inch long that fit heat sinks
Butane blow torch, just a small one will do
small torx wrench kit. big and small flat and phillips head screwdrivers
Mar 15, 2009 | Microsoft Xbox 360 Console
I just bought an xbox 360 and at first it worked fine, but now since i got registered online it locks up when i try to plan games...especially when playing grand theft auto 1v...the screen just locks up...
This happens a lot which is then i followed by the 3 red rings(red rings of death). is what you need to do is open your'e console, their are help video's on U tube for this. Once your is console open and you have the mother board taken out you need to remove the heat sinks which are on top of the chips. just un-snap the x clamps (on the bottom of the motherboard) and take off the heat sinks. unscrew the tabs on the bottom of the heats sinks and take them out. now take one of the heat sinks to a hardware store and find 8 screws about an inch long that screw into the heat sinks, also buy 16 plastic washers and 8 metal washers that fit onto the screws.also trey to find a BUTANE Torch this will save you from the expensive heat guns and work just as good. the last thing you need is Arctic Silver 5 which can be found for 5 bucks on eBay. now once you have this you need to lay your motherboard on a flat inflammable area. light the torch and make sure it is on the LOWEST setting and that the flame is about 3/4 inch long and make a sort on hissing sound. make shure the top of the chips are cleaned with a paper towel of the paste. start with the torch about 3 inches over a chip and keep it moving with a sweeping motion after about 30 seconds start to get close but not to close about an inch an a half away and keep making sweeping and circular movements for about 2 min. do not get to close. now move to the next chip and do the same thing. now after ur done with the chips move the torch away about 3inches and keep heat on both chips for another minute and let them cool for a total of 10 to 15 minutes. once they are cool to the touch clean off the metal parts of the chips with alcohol (I preffer acitone too) make shure they have a mirror like finish and put a very little glob of the artic silver on the metal chips and evenly flaten it out till it covers them evenly, make shure to apply enough! ( i used the side of a allen wrench, its less messy). now on the bottom of both heat sinks, clean them off with acitone or alcohol and scrub them very firmly to get off the grime from the paste. now put one plastic washer on each screw and insert them through the bottom of the holes surrounding the chips flip the mother board over and put the other 8 plastic washers on the screws and on top of these put on the 8 metal washers. then put the heat sinks on and tighten them down. once you put the mother board in the metal casing, plug it in(dont fully essmble it yet) now test out your xbox by pressing the little button on the ring of lights board and let it boot up a usual. If it works then ur done, but if 3 red lights start blinking or two red light start blinking you need to adjust the 8 screws. through the 8 holes in the bottom of the metal casing stick a small screwdriver in there and make shure they are all snug but not to tight and then loosin each one about an 1/8 of a turn till there just a little loose. keep testing and adjusting the screws till it boots up with the green lights.
GO TO A HAREWARE STORE FIND THE FOLLOWING THINGS IF YOU DONT HAVE THEM
16 platic washers
8 metal washers(make shure all the washers fit snuggly around the screws and are very thin)
Feb 21, 2009 | Microsoft Xbox 360 Console
The xbox restarts itself repetadly when it starts
This could be do to a bad ROL (ring of lights board) easy to replace and cheap. about 6 bucks on ebay. they even have one's with blue or red lights to give you a cool look to your system. if not this may have to be done....
16 platic washers
My xbox 360 beeps then freezes to random screens
This happens a lot which is then i followed by the 3 red rings(red rings of death). is what you need to do is open your'e console, their are help video's on U tube for this. Once your is console open and you have the mother board taken out you need to remove the heat sinks which are on top of the chips. just un-snap the x clamps (on the bottom of the motherboard) and take off the heat sinks. unscrew the tabs on the bottom of the heats sinks and take them out. now take one of the heat sinks to a hardware store and find 8 screws about an inch long that screw into the heat sinks, also buy 16 plastic washers and 8 metal washers that fit onto the screws.also trey to find a BUTANE Torch this will save you from the expensive heatguns and work just as good. the last thing you need is Artic Silver 5 which can be found for 5 bucks on ebay. now once you have this you need to lay your motherboard on a flat imflammable area. light the torch and make shure it is on the LOWEST setting and that the flame is about 3/4 inch long and make a sort on hissing sound. make shure the top ofthe chips are cleaned with a paper towl of the paste. start with the torch about 3 inches over a chip and keep it moving with a sweeping motion after about 30 seconds start to get close but not to close about an inch an a half away and keep making sweeping and circular movements for about 2 min. do not get to close. now move to the next chip and do the same thing. now after ur done with the chips move the torch away about 3inches and keep heat on both chips for another minute and let them cool for a total of 10 to 15 minutes. once they are cool to the touch clean off the metal parts of the chips with alcohol (I preffer acitone too) make shure they have a mirror like finish and put a very little glob of the artic silver on the metal chips and evenly flaten it out till it covers them evenly, make shure to apply enough! ( i used the side of a allen wrench, its less messy). now on the bottom of both heat sinks, clean them off with acitone or alcohol and scrub them very firmly to get off the grime from the paste. now put one plastic washer on each screw and insert them through the bottom of the holes surrounding the chips flip the mother board over and put the other 8 plastic washers on the screws and on top of these put on the 8 metal washers. then put the heat sinks on and tighten them down. once you put the mother board in the metal casing, plug it in(dont fully essmble it yet) now test out your xbox by pressing the little button on the ring of lights board and let it boot up a usual. If it works then ur done, but if 3 red lights start blinking or two red light start blinking you need to ajust the 8 screws. through the 8 holes in the bottom of the metal casing stick a small srewdriver in there and make shure they are all snug but not to tight and then loosin each one about an 1/8 of a turn till there just a little loose. keep testing and adjusting the screws till it boots up with the green lights.
16 platic washers
Power on but no red lights. No picture on the monitor, no problem with monitor tried xbox on another monitor same problem just shows that monitor is in gaming mode.
16 platic washers
Keystone Plastic Alcohol Torch Keystone Logo
617 people viewed this question
Top Keystone Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Keystone Health and Beauty Expert? Answer questions, earn points and help others
