I can't make changes in my calendar. When I do it makes the change but it comes right back the way it was.
    New Friend:
Sometimes it helps if you restart your computer after you make the changes in your calendar on your computer.
Posted on Nov 20, 2013
How do I change time and date on LG440G Tracfone?
On my model, I go to menu, then calendar, then calendar will show up & you can use arrows at the top to pick month & year, then once you got the right month, tap on correct day. that is for the date.
The time should come up automatically when you turn on your phone. Mine even changes to correct daylight saving time automatically.
Mar 09, 2015 | LG Cell Phones
I have Calandar Creator 10 and have created a family calandar which I use from year to year that includes birthday events, holidays etc. and phases of the moon. This year, when I went from Dec. 2010 to...
Calendar Creator 10 has the four moon phases from Jan 1990 thru Dec 2010. To extend past 2010:
- File Open Collection ' Local Disk(c:)'Program Files'Calendar Creator' Template'Events'Phases of the Moon.bcc
-For each of the four events (First Quarter, Full Moon, Last Quarter, and New Moon) change the Repeat Until date past 12/31/2010 to 12/31 of the year you will add data for
-For each of the four events, click Advanced Repeat Rule you can selete the drop down under Exceptions / Pick exception and there you can see the dates by month and year from Jan 1990 thru Dec 2010 for the event. You need to extend this list. First obtain the moon phases from some web site like www.timeanddate.com/calendar. (note that this site calculates the mone phases base on New York time). The simply select each of the dates for the event you are modifying by clicking that date on the calendar in the upper right hand of the screen. Just advance the calendar thru the months and years you want to enter data for. You can check the list when finished by selection the ExceptionS Pick exception drop down box.
- Save your changes by clicking OK and Ok again. Make changes for all for events.
- Select File and Save Collection
- You need to replace the Phases of the moon events in your calendar by removing the old events and importing the new events. To remove the old Phases of the moon in your calendar, select Events'Categories highlight Phases of the moon and delete. Then add back the changed events by File'Import Events and browse for the Phases of the moon.bcc file you changed.
I hope this gets you what you need.
Nov 19, 2010 | Broderbund Calendar Creator Deluxe 10 Full...
When I sync the outlook calendar to my iphone, one of two things happens. 1. If I put an all day event in outlook, it syncs to the iphone a day earlier (both otlook & iphone are on same date &...
Make sure time-zone is the same for both iPhone and the computer.
On iPhone setting > Mail,Contacts,Calendars setting > Time Zone Support, make sure you are choosing the city where you are in.
Otherwise, make sure you have updated the iTunes to 7.5 or later.
Update to iTunes 7.5 or later to resolve this issue. If you're not able to update, continue reading for other options to resolve the issue.
Each Outlook calendar event has an internal property known as "Message Class." When some Outlook plug-ins are installed (such as Live Search Maps), the setting for the Message Class property can change from its default of "IPM.Appointment" to something else. iPhone and iPod touch are only able sync calendar events with the Message Class set to "IPM.Appointment," therefore any calendar events created after installing certain Outlook plugins may no longer sync.
To verify this, examine the property of the Calendar event items for MS Outlook and see if the Message Class shows something other than "IPM.Appointment" in any of the calendar events. To view the Message Class property for your Outlook Calendar events, add the Message Class field as one of the columns in the Current View using these steps:
  1. Open Outlook Calendar on the computer.
  2. Choose View > Current View > Events.
  3. For Windows Vista, choose View > Current View > Customize Current View.
    For Windows XP, choose View > Arrange By > Current View > Customize Current View.
  4. Click the Fields button and choose All Appointment fields from the pop-up menu in the "Select available fields from" section.
  5. In the "Available Fields" column, select "Message Class" and click the Add button.
  6. Click OK.
  7. Click OK.
Now verify that all your calendar events are showing "IPM.Appointment" for the Message Class column. If you have calendar events showing a different value other than "IPM.Appointment" you will need to perform the following steps to fix the issue.
  1. Uninstall any Outlook plugins such as Live Search Maps or other plugins which change the default Message Class "IPM.Appointment" to some other value. Once the plugins have been removed, verify if those calendar events revert back to the Message Class of "IPM.Appointment" so that you can sync the calendar data to iPhone/iPod touch. If you are able to sync, try adding the plugins back one at a time and verify that you are still able to sync.
  2. If removing the Outlook plugins does not change the Message Class value for the calendar events, manually change the Message Class value of those calendar events to "IPM.Appointment." For more information on Message Class and how to change the Message Class fields/value, refer to Microsoft's KB article 201087 How to update existing items in an Outlook folder to use a new custom form
Apr 06, 2010 | Apple iPhone Smartphone
Calendar freezes...tried rebooting several times..Will not change dates..Frozen on today
Sounds like you need to fully back up your iPhone by syncing it with iTunes. Make sure all your contacts are saved to your sim and anything else important is saved somewhere else.
Once you are sure you have backed everything up plug your iPhone into your computer and load iTunes.
Select your iPhone on the right in iTunes and in the Summary tab there will be a Restore option.
Click that to restore to factory settings and solve your problem.
May 10, 2009 | Apple iPhone 3G
Turning up volume
thank you for choosing Fixya.com
it happen because your unit has been customized that's why even you are choosing the sound insted you will be directly go to Calendar mode.
please try to restore the setting of your mobile.
their all the changes happen will go back to normal.
let me know no changes happen.
please rate our answer properly.
Feb 21, 2009 | Nokia 6610i Cellular Phone
Indiglo WR 30M
i wind the clock hands forward until the calendar date and week day changes and then i re-wind the hands until it comes to the correct time. when i re-wind the hands, the week day goes back to the correct date and the calendar date does not go back by one day. i don't know if this is the "correct" way to do it, but it works.
Sep 12, 2008 | Timex 27191 Wristwatch
Hot sync calendar from outlook to my palm
In my LifeDrive, my VersaMail set-up wasn't quite right. I had my e-mail address in as "name", rather than "name@mail.com". That fixed MY problem. Others (including me) are having trouble keeping the HotSync set to sync Calendar. It keeps going back to "Do Nothing" Go to HotSync in the system tray on your PC, right click, select Custom and see if your Calendar (conduit) is set to 'Do Nothing' as an action. I was able to get it to change and work, but just once (so far!!)
Sep 12, 2005 | Palm Zire 31 Handheld
Delete calendar
Open Active sync on your PC. Double Click on Calendar. Change the settings such that it syncs only 0 past and 0 future appointments. SYNC (this will clear all calendar items on the IPAQ) Don't forget to change these settings back.
Sep 11, 2005 | HP iPAQ HX4700 Pocket PC
Treo 650 from Cingular is not hotsyncing with Outlook Calendar?
Have you setup an EAS account in VersaMail? The VersaMail application on your Treo 650 supports Exchange ActiveSync, which allows synchronization of Email and Calendar wirelessly with Exchange Server 2003. If an EAS account exists on the handheld the Calendar conduit will disable itself to avoid duplicates. Go to VersaMail on your Treo650 Select Menu: Accounts: Account Setup Check to see if any EAS accounts exist on the device by selecting and account, then Edit... One the first screen check Mail Service. Do any of them say "Exchange Activ..." If yes you'll need to delete that account to sync calendar entries.
Sep 07, 2005 | Palm Treo 650 Handheld
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
