Question about Refrigerators
My LG air condition will bring out ice block on the pipe out side but it will not get cold inside what is the cause
    Champion:
    Habit-Forming:
  • 275 Answers
Low gas is my guess.
Posted on Nov 21, 2013
Maytag317
  • 1136 Answers
SOURCE: Fridge ice accumulation inside and water dripping outside
Hi, Are you getting ice build up in the freezer side as well? There is a air shuttle between the fresh food side and the freezer side. thwater might be getting in the freshfood side from there. Look at the bottom rear panel in the freezer for ice build up. Ig=f there is ice, you will need to get to the drain from inside the freezer and check for blockage.
Please let me know if I can help you further.
Vic
Posted on May 10, 2009
pride applia
  • 232 Answers
SOURCE: My Kenmore side by side ice dispenser on the door freezes up!
need complete model #
Posted on Jul 02, 2009
woobie dog
  • 1273 Answers
SOURCE: Freezer is too cold, ice crystals. Refriderator
I'm not sure which one you have, but try this: Look for the area where the air passes from the freezer to the refrigerator side, in the wall somewhere between them. Make sure that there isn't something blocking the passage. This is a good place to start.
Regards,--W/D
Posted on Jul 10, 2009
  • 100 Answers
SOURCE: GE Profile Artica side by side - freezer not cold enough
replace control board on back of unit there is a six by 10 inch cover on back your panel is in there cost aprox 169.00 dollers also replace bo0th thermisters bottem left of freezer looks like a white bullet the other is in fridge behind shelf trim located beside and underneath where the cold air blows into the fridge.
Posted on Aug 10, 2009
57 varieties
  • 1653 Answers
SOURCE: The ice maker stopped making ice, dispenser works
This could be the water inlet valve or the logic control board that controls the valve. It may also be a clogged water inlet filer if you have not changed it in the last 12 months. A service engineer vist would sort this out.
Posted on Sep 25, 2009
How we repair LG ac showing C1
try switch the unit off till ice melts and try running the unit again after. if the ice is till coming back check the filters are clean and outside coil clean. sounds like a restriction in piping,possibly a blockage.
c1 err caused by the indoor pipe sensor being out of spec, possibly due to the ice buildup.
Apr 24, 2016 | LG Heating & Cooling
Goldman capf3636b6. Fan outside is running blowing cold air to the outside.Inside is making a humming sound but not running.If I turn it off all of it stopsThere is some ice visible on the pipes
System needs to be thawed out, so turn it off before something else breaks, cause pipes are probably plugged and stopping any movement inside the system, Try using a blow dryer on high heat to help with the thaw out of the pipes with the ice build-up , then leave it off for a couple of hours and then try to turn it on again see if the unit in the house is running or blowing cold air again. Turn it on HIGH...!!!!
Aug 09, 2015 | Heating & Cooling
Freezer side not freezing
Check for ice / frosting inside the freezer .... If present you probably have a defrost problem.... This causes the freezer coil to ice up and block the air flow ... the causes could be a bad defrost heater , defrost timer, defrost sensors, or control board. Also make sure that the condenser coil is clean. remove ALL dust with a vacuum and a coil brush .the coil is located either on the bottom or on the back side of the unit... You didn't give the Make and model #
Apr 04, 2014 | Freezers
Iced over. compressor runs super cold. no control on temperature.
It's requires clean up , it's all covered with dust and that caused it to freezes and iced. It will consume more electricity when gets iced.
May 19, 2012 | LG Window Ac Unit 18000 Btu, Energy Star...
My lg wall unit (LWHD1009R) 10,000 btu the compressor keeps turning off after it gets going. even though I have it on a low temp. the comressor turns off after 5-10 minutes even though the room is not cold
either going off on low charge which would cause it to ice up, which means you need refrigerant. or high head pressure might just have to clean the coils or check condensor fan.
May 05, 2010 | LG Art Cool LA121CNP wall/window Air...
After 4-5 hrs of running it ice particals drop out of AC and fall out.
MAKE SURE THE FILTER IS CLEAN AND COLD COIL IS CLEAN . JUST REMEMBER 70 OUT SIDE AND 70 OR LOWER INSIDE AND YOU HAVE A ICE CONDITION. 75 INSIDE AND 75 OR HIGHER OUTSIDE KEEPS UNIT FROM ICING UP. IF ITS LOW ON FREON IT WILL ALSO ICE UP. MOST OF THE TIME THEY DONT LEAK FREON BECAUSE THEY ARE SEALED SYSTEMS
Apr 23, 2010 | LG Art Cool LA121CNP wall/window Air...
My freezor work good but the fridge does not cool
There is ice blocking the passage which allows cold air from the freezer to pass into the refrigerator compartment. Turn the refrigerator off. Find where the cold air passes into the refrigerator and remove/melt the ice. You may need to remove some panels to access this passage.
Oct 02, 2009 | LG LSC26905TT Side by Side Refrigerator
Samsung RS253BAVQ freezer Keeps defrosting, and wont dump ice
One posibility is that it is not defrosting a all and that the ice is building up on the evaporator coil behind the rear cover inside the freezer. This condition will block the flow of cold air. Remove the back panel to see what your have. Either no ice , light frost, partial icing or heavy icing blocking the fins. Complete light frosting is normal.
Sep 09, 2009 | Samsung 24.8 Cu. Ft. Side-by-Side...
Top freezer develops ice on left bottom side.
it has to be connected other wise its true that ice will get collected.because the compressor will give its coldness in refrigerator so the cold air of freezer will also get collected in refrigerator side, because there is no ice dispenser connected.connect the icedispenser.
to make it proper.
Apr 01, 2009 | LG Refrigerators
Westinghouse Wse6100WA side by side Fridge-icing up/not cooling
This is a bad design flaw, the fridhe is cooled by fan forced air from the freazer. Two ducts vent into and out of the fridge fron the freezer and ice can block them up (which you can find if you take off all the plastic at the top and back of the fridge).
Hence, when they block up, the frindge does not cool, hence the thermostat tells the fridge to keep running which makes the freezer colder and colder, making the blockage worse.
You need to not only fully defrost the freezer (which can be done quicker by removing the plastic panel in the back of the freezer and using a hairdryer) BUT also fully dry the fridge before turning it back on.
To stop it happening again, avoid puting unvovered liquids or hot items in the fridge. Also avoid leaving the fridge and freezer doors open for long especially in humid conditions. As I said, it's a bad design.
Mar 31, 2009 | Westinghouse WRS3R3EW 33" 22.6 Cu. Ft....
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
