Question about Refrigerators
Refrigiderator door sagging not closing properly
This is a top freezer model. that part is ok bottom refrigerator door is in need of adjustment. it seems to be hitting the inside of the refrigerator and not closing correctly. i have seen videos of other models with a simple screw adjustment by wrench on the bottom of the door but cannot located that on this model it has a screw threads instead of a place to put a wrench thanks!
  • Refrigerators Master
  • 15,682 Answers
Check to see if there is a nylon (white plastic grommet) in the hinge that the post goes into. See if it is worn.
Posted on Nov 21, 2013
Testimonial: "thanks will check"
  • Brian Coughlan Nov 21, 2013
    The top hinge is adjustable, remove cover losen screws or small bolts, have someone lift the door or do it yourself then tighten quickly before door drops again.
Please give us something to start with.
What is the make and model of your freezer?
Have you checked the hinge is securely fastened?
Has someone leaned on the door and bent a hinge?
Testimonial: "Frigidaire FRT21HS6JS0 could have sworn there was a line for that info when i posted hinge is secure there is a curve downward but not sure if that is by intent. would another washer down by the bottom hinge do the trick. do both doors come off when you make the repair?"
  • doug roberts
    doug roberts Nov 21, 2013
4 Suggested Answers
SOURCE: Kenmore Elite bottom freezer refrigerator model 795.77573600
My Kenmore Elite (Model 795.7755 3600), less than two years old, had the same problem. One morning I opened the doors to a hot fridge and burning plastic. The light housing was sizzling hot - much of the unit literally melting away. Another hour or two and it could have been much worse.
Called the 1-800 number listed in the fridge. After about 45 minutes of patient talking, I learned that Sears (or Kenmore) have issued what they refer to as a "flash warranty) on the light fixture kit (Kit # 6871JB1423N) which in effect, for this part only, extends the factory warranty from one year to three years. I may even be able to have a factory tech install the parts. Hope it works out.
Bottom line: if you have this fridge, be very careful and monitor closely. An pursue the part warranty!
Posted on Jan 13, 2009
SOURCE: Amana ARB2117BW - Bottom Freezer Door Won't Stay Sealed
This problem was posted in the wrong section. My model didn't have it's own, so its in ABB1927DE Bottom Freezer Refrigerator - perhaps you could create a section for it.
As it turns out, I looked more closely at the baskets inside. We had noticed that if the top basket was slid all the way forward when we closed the door that it would close better. So I looked to see if they or the slides were out of alignment. They seemed ok, but then I saw that the way the bottom basket was hanging didn't seem right - it was not quite nestled into it's retainer slot. I took the baskets out and turned the bottom one around. It fit perfectly into it's retainer slot. I then replaced the top one (it was already in correctly) and closed the door. It sealed correctly the first time. I tested it several times after that and it sealed tightly. Closing the top door did not make it unseal as it had done before.
Posted on Jan 23, 2009
joboo1
  • 257 Answers
SOURCE: Refrigerator Door not closing properly
Hi, No the door is not adjustable like you might think Since it is smaller than the other door any alignment problem is really visible. First do check the bracket to make sure you didn't lose a screw and that the brackets are solid and don't move. The problem is the level of either the refrigerator or the floor. If you have a 3 ft bubble level put in on the top of the refrigerator along the front, NOT on the door. There are feet on the bottom front corners of the refrigerator, you may have to remove the plastic grill to access them but depending on the model and age of your refrigerator it should be attached with clips. The feet screw in and out but with weight they won't move easily so you may have to jack the front a little, remove some stuff or try a crescent wrench. Once the front is level check the front to back, the refrigerator needs to tilt slightly to the rear so the door when partially open will close by itself. Again you didn't give a model so on some the rear feet are not adjustable and some are. I suspect you may have adjustable and the box is not squared up. If after adjusting the front and the entire refrigerator tilts like an uneven table leg then you have to adjust the feet likewise. Use your level diagonally across the top both directions, it should be exactly the same. If you have non adjustable and they are uneven it is the floor and you have to use shims under the low foot. Good Luck!
Posted on Jan 30, 2009
What is the plastic knob under the door hinge used for on kenmore model 7803 refrigerator?
Most modern fridges have these small plastic knobs [usually both top and bottom]. They are usually only COVERS for threaded mounting holes so that the fridge/freezer doors can be mounted for either left OR right opening ... ok They are generally around 1/2" [13mm] in diameter x 1/8" [3mm] in height.
They also help support the door [when it is closed] and prevent any "sagging" and/or mis-alignment or distortion of the fridge door which [these days] can be quite heavy when fully loaded.
Oct 20, 2014 | Kenmore Refrigerators
The bottom freezer door on my Kenmore refrigerator 795.7900 pops open each time I close the top door. I have tried adjusting the leveling screws and it hasn't helped. Any suggestions?
Glen you keep adjusting but before that try to find this unusual problem. On its own, doesthe freezer door close witha thud? If not it needs adjustment otherwise other problems could surface.
Mar 03, 2014 | Kenmore 72912 / 72914 / 72919 Bottom...
Left side french door seem to have sagged,and now wants to bind when closing.how do you adjust it upward ??
ck the cam ( plastic ) it lifts the door and also causes it to close tight . they ware out and the sometimes just brake and fall out . .. part # 12395501 b -- this is a blk bushing . for your model .. mm
Sep 02, 2010 | Jenn-Air JFC2089H Bottom Freezer French...
Refrigerator door does not stay closed. When the freezer door is closed the refrigerator pops open.
The fridge and freezer share their airspace, so when you close one there is a slight increase in pressure in the other unit. (Much like opening a window can cause a door open/close in your house due to pressure change/air movement) The magnet in your seal of the door is weak and unable to resist the pressure change. The seal should be changed.
Could also be that the door is not shutting properly in the first place due to sagging or skewed hinges that need adjustment/replacement and while shutting just may not be getting a complete seal that it should be.
Sep 02, 2010 | Refrigerators
Do the door hinges ever wear out
I did my own search for the same problem and saw Dougs question and lack of a solution. I have the same sagging door problem and was looking for a fix.
First, when I removed the weight of the items from inside the door, the door closes properly. This means that the door is not very sturdy and cannot hold the weight of items placed on door shelving. There are NO adjustment mechanisms on the door hinges either. Bad on Amana. The GOOD NEWS is that I fixed the problem.
Take out all items from the door shelves. I removed the top hinge with the door closed to keep it from falling. I took the door off and placed it on the floor. The lower hinge has a plastic pivot over a steel pin - remove that for a moment. Place steel washers over the steel pin - about .080" or so thickness. Replace the plastic pivot. Replace the door. Add the normal weight of items back on the door shelves. The door closes perfectly. At least until the door sags again and I'll need to add another shim.
Jun 21, 2010 | Amana ABB2524DE Bottom Freezer...
Freezer door on Kenmore AS-18 is sagging
I have this fridge and the sagging door means that you are missing a plastic washer. you might have accidentally placed this washer on the top rather then on the bottom where it belongs.
Jan 04, 2010 | Kenmore 18.3 cu. ft. Top Freezer...
Top door drags on the side just before it closes
sometimes these dooors tend to sag, the hinges cant take as much as the manufacturer claimes,
you can loosen the top hing screws,,,
JUST LOOSEN DO NOT REMOVE
with the upper hing loose you should be able to left the door slightly on the corner it drags, ther ewont be much room but you should get enough play to allow the door to close properly
once lifted tighten in place
might need a hand
Oct 10, 2009 | KitchenAid KBRC36FMS Bottom Freezer...
Refridgerator door sags
Its a two person job. One person has to looses up the two hidges holding the door just slightly while the other person holds the door in place. Once in place tighten the screw/bolts for the hidges back up and check. If not aligned, redo it again until it is aligned and seals properly..
Good Luck!
Sep 15, 2009 | Amana ATB1832AR Top Freezer Refrigerator
Refrigerator door pops open, frigidaire top
The refrigerator needs to be perfectly leveled side to side dn should pitch back slightly. Also look at the plane of the doors, that is to say that they should be squared to the cabinet. If they are sagging, you may need to adjust the hinges.
Apr 17, 2009 | Frigidaire FRT21H8 Top Freezer...
Freezer door rubbing
take the freezer door off and put a washer or two on the bottom hinge. sometimes there are extra plastic washers on the top hinge that you can move to the bottom to lift it up.
also check if the hinge is bent or loose, as this may cause the problem.
Jun 28, 2008 | KitchenAid Architect KTLA19KRSS Stainless...
Refrigerators Logo
80 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
