Question about GE Ovens
GE Profile PT916SM3SS Control Panel gets hot
The control panel on the GE Profile model PT916SM3SS gets very hot.
  • 1 more comment
  • Charles Norman II
    Charles Norman II Nov 20, 2013
    Oven model is: GE Profile PT916SM3SS
  • Charles Norman II
    Charles Norman II Nov 25, 2013
    I replaced the fan unit in the control panel section and all seems to be well.
  • mikadot
    mikadot Nov 25, 2013
    Great job!
    New Friend:
What is the E4 error ?
Posted on Nov 20, 2013
Testimonial: "I don't get an error code, it just gets very hot. This happened after running the self cleaning."
PT916SM3SS
missing insulation or poor connection on a terminal
Nov 20, 2013 | GE Ovens
FO ERROR ON OVEN
Seems F0 is a problem either with the control panel or with the key panel
Here is a test to find out whether its your control panel or control board:
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
You can go to this site to find replacements
Mar 14, 2008 | GE Profile JKP56 Electric Double Oven
Ge profile pt916sr1ss clock is on but panel will not work
Check the fuse for the panel, if it's OK, then the control board or the panel is at fault
Mar 20, 2013 | GE Profile JTP18 Electric Single Oven
How to remove the touchpad on ge profile stove, I have f7 code
On most GE ovens you open the door and across the bottom of the control panel there are 3 1/4 inch screws, one in the center and 2 on either end going straight up into the console. remove the screws and slide the control panel up then out to you. Thats how you do it.
Aug 28, 2011 | GE Profile JTP18 Electric Single Oven
!0 year old GE Profile Double Oven. Control Panel repaired but oven is again not working with a "F7" mal function indicator on panel. Model # JT 950 S0A3SS
Hello & Welcome to FixYa
F7 error code is displayed when the clock assembly/electronic range control (ERC) goes bad and needs replacement. Sorry for the bad news....but hope you understand. Please get back to me if you have any other questions.
Kevin
Jan 03, 2011 | GE Ovens
Control panel continously beeps with message to
Could be a faulty control as you suspect but also may be a bad keypad. If the "start" button has no effect I'm suspecting the keypad first.
Best Regards,
Bruce
www.fixyourboard.com
Jun 19, 2010 | GE Profile JT912 Electric Single Oven
GE profile wall, single, Get a
Hello,The "FO " reading you get is as a result of "Shorted Clear/Off key due to the membrane switch,control or connector".And these mean you have to check the Shorted key panel membrane switch; Check Electronic Range Control(ERC)
Thanks
Jun 02, 2010 | GE Profile JTP18 Electric Single Oven
Control panel doesn't work
F7 indicates either a stuck key or the main control has failed. Try depressing each button one at a time checking for a stuck key. If each one retracts I would replace the main control this is more likely the problem. There easy to replace. If you enter your model # at www.appliancehelponline.com you can get diagrams and illustrations of your specific model.
May 27, 2010 | GE Profile JTP56 Electric Double Oven
Getting F7 code on a ge profile performance oven , oven light will not turn off and control panel will not respone.....beeps when I push CLEAR OFF button.
F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
Try gliding your finger flat across the keypad rapidly and see if you can unstick the key / touch pad. Usually once this code appears it will repeat.
On self cleaning ovens this is the service check:
Thanks for using FixYa!
Kelly
Mar 09, 2010 | GE Profile JTP56 Electric Double Oven
I have a GE Profile Trivection oven JT930. The left side of the control panel no longer works. My husband has tried cleaning the contacts - didn't fix it. Should we just replace the control panel. ...
You simply need a new control panel Call us with your complete model number and we'll ship your parts out to you asap! We look forward to working with you!
Oct 18, 2009 | Ovens
Ovens Logo
102 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
