Question about Sharp XE-A106 Cash Register
Instead of printing the transaction normally, the printing is full of lines with #
I am looking for as much information about transactional print as possible. My business is looking for cost-efficiencies and believes this area offers a good ROI
The print industry is well known but not so many realise the large-scale integration with transactional data, which in turn produces transactional mail. Read on to learn more about benefits, applications and a wide range of topics on this subject.
Link: https://www.bakergoodchild.co.uk/infographic/power-transactional-mail-printing/
May 18, 2017 | General Computers & Internet
Casio pcr-t470 electronic cash register has eject full e206 on screen how do i clear this?
EJ stands for Electronic Journal. The ej is a record of all the sales made on the till since the last time the ej was cleared. If you dont clear it then it eventually fills up and stops the till from working until it is cleared. I dont have a manual for this model but there will be a report to print and clear the ej in your manual.
Oct 26, 2012 | Casio PCR-T465 Electronic Cash Register
How to print from memory using a CANON MX 310. Also why fax es to memory instead of prining drectly?
  1. Issue: How do I print a document stored in memory?
    Solution: Print the received fax from memory - MX310
    Memory Reference Print faxes received from memory when ink is low or paper has run out or paper has jammed. It may be necessary to press to clear the error then attempt to print the fax from memory.
    1. Press , then press . [FAX SETTINGS] will appear at the top row.
    2. Use leftright.gifto select [MEMORY REFERENCE].
    3. Press .
    4. Use leftright.gifto select [PRINT DOCUMENT] or [DELETE DOCUMENT].
      If you select [PRINT DOCUMENT]:
      1. Press .
      2. Use leftright.gifto select the transaction number (TX/RX NO.) of the document you want to print, or enter the number using the numeric buttons. If you are unsure of the transaction number, print the MEMORY LIST
        Press .
      3. Use[ left.gif] to select to print the first page only, or use [ right.gif] to select to print all pages of the document. (Received faxes begin at 5001. Faxes waiting to be transmitted start at 0001.)
      4. Press .
      5. To print another document, return to step 4b, or to finish printing, go to step 5.
        If you select [DELETE DOCUMENT]:
      6. Press .
      7. Use to select the transaction number (TX/RX NO.) of the document you want to delete, or enter the number using the numeric buttons.
      8. Press .
      9. Use [left.gif ] to select to delete document, or use [right.gif ] to select not to delete the document.
      10. Press . To delete another document, return to step 4g, or to finish deleting, go to step 5.
    1. Press .
Dec 09, 2010 | Canon PIXMA MX310 All-In-One Printer
Flexion1, Thanks for your reply. When i tried to create the trainee clerk, after a completed transaction, the receipt printed replacing every space with an asterix i.e *. Why is this so? Also unfortunately...
I'm pretty sure that is right for training mode (asterisks). It has been a long time since I used it (I prefer to use standard clerks when training so i can demo the daily reports). It is easy to confirm - just print a Z report and see if the transactions are totalling in there. If not, you are in training mode. For your other problem, try turning to program, 0 CASH SUBTOTAL 3 SUBTOTAL 0 CASH SUBTOTAL
Sep 12, 2010 | Casio Parts Cash Register PC Desktop
I have entered a credit instead of a bill in supplier centre and cannot find out where to delete it
1) Go to "Vendor Center" or "Vendor List".
2) Locate Vendor then "Transactions" should appear on right
3) Select "All Transactions" and credit should appear
Jan 04, 2010 | Intuit QuickBooks Pro Edition 2009 Full...
Eliminate the transaction report
To eliminate the transaction report, perform the following:
  • Press Function button once
  • Press down arrow 3 times
  • Press right arrow > once
  • Press 5 "Never Print"
  • Press "STOP"
This will eliminate ALL transaction reports. There are 5 options for this function.
  1. Always Print
  2. Error/Memory Print (memory errors only)
  3. Send Only (prints only on sent fax)
  4. Error Only (prints only when there's an error encountered)
  5. Never Print (eliminates all transaction report printing)
This should solve your problem. Please post back with any questions and/or to rate this solution. Thank you very much.
Greg
Aug 11, 2009 | Sharp UX B700 Plain Paper Inkjet Fax
Will not show reports below a "blue line" in check register
The blue line in a register indicates transactions that have been entered in the future, past today's date. Check your transaction dates as well as your system clock. It's possible your system clock is off.
Jan 20, 2009 | Microsoft Office Professional 2007 Full...
My register the pcr - t470 had and * it said to run the journel report. Well it has been printing for 10 minutes and won't quit how can I fix it??? now it has stopped. How can I clear it without having...
Hi. Yes, the star means the journal is near full. It can hold thousands of transactions.
I don't have the manual for the 470, but I have info for the 465, so it's probably the same. I assume you turned the key to Z mode, and pressed 58 CASH.
Try using 4058 CASH instead.
Mark
Aug 06, 2008 | Casio Parts Cash Register PC Desktop
Memory full
Memory Reference Print faxes received from memory when ink is low or paper has run out or paper has jammed. It may be necessary to press <Stop/Reset> to clear the error then attempt to print the fax from memory.
  1. Press <FAX>, then press <Menu>. [FAX SETTINGS] will appear at the top row.
  3. Press <OK>.
    1. Press <OK>.
      Press <OK>.
    3. Use[ left.gif] to select <YES> to print the first page only, or use [ right.gif] to select <NO> to print all pages of the document. (Received faxes begin at 5001. Faxes waiting to be transmitted start at 0001.)
    4. Press <OK>.
    6. Press <OK>.
    8. Press <OK>.
    9. Use [left.gif ] to select <YES>to delete document, or use [right.gif ] to select <NO> not to delete the document.
    10. Press <OK>. To delete another document, return to step 4g, or to finish deleting, go to step 5.
  1. Press <Stop/Reset>.
Jan 21, 2008 | Canon PIXMA MP530 All-In-One InkJet...
How to get fax reports
Your only option is to have it print out automatically after every 32 transactions, print out after every transaction, or print out only when there was an error with the transmission.
That parameter is Comm Journal and you can get to it by going to Function 7, option 4. That should give you a fax parameter table. You want options 12 and 13. Set 13 to "1" if you want it to print out every 32 transactions. Set that to "2" if you don't.
Set 12 to 1 for Comm Journals Off, 2 for Always, and 3 for Incomplete Only (errors).
Oct 02, 2007 | Panasonic Panafax UF-490 Plain Paper Laser...
Sharp XE-A106 Cash Register Logo
Top Sharp Retail Supplies Experts
k24674
Electroboy
Electroboy
Are you a Sharp Retail Supply Expert? Answer questions, earn points and help others
