Question about Quartet gbc Shredmaster 5550X Confetti-Cut Shredder
Shredmaster 5550x teeth wont shred
When we turn the shredder on it will sense the paper, but the teeth do not turn. The teeth will turn if you use the manual buttons for forward and backwards, but they only move a quarter turn before freezing up.
JayBlair
  • 328 Answers
SOURCE: My shredder stop shredding. has paper caught in itposted
You must have a stripped gear. Should be a number in op manual. Take the top cover off and look for the broken gear. Call them an order gear.
Posted on Aug 31, 2007
Shredder drive gear is probably shredded - hard part to find or replace usually. Could mean a new shredder;-(
Posted on Sep 08, 2007
SOURCE: starts reversing automatically when beginning a new scan
screw it
Posted on Sep 25, 2007
CopierOne
  • 30 Answers
SOURCE: Shredder does not shut off
In my experience, there are three possible reasons for this problem. The first, and cheapest to fix is a scrap of paper lodged on the sensor that turns on the drive. You can take a flashlight and look down the throat of the shredder and see if there is any debris just above the cutting blades. MAKE SURE THAT THE UNIT IS UNPLUGGED! Take a small utinsel like a letter opener and remove the scrap from the throat of the shredder. There is also the possibility that there is dust on the sensor. This takes a bit more finesse. A small brush, like a skinny paint brush, like kids use for painting with water colors, will brush the dust off the sensor and it should work normally again. The other two reasons are going to require the services of a qualified technician, as either the sensor itself is bad or the control board that the sensor connects with are bad. It will cost you unless you are still covered by warranty. Let me know if this helps. Aloha, Bill Monroe
Posted on Sep 29, 2007
  • 3 Answers
SOURCE: How to fix a stuck shredder
get a pair of needle nose pliers and pull the jammed paper out. (you may need to figure out how to pop off the top cover to get better access to the blades)
Posted on May 27, 2009
How do i increase the number of pages that the shredder will shred at one time?
you can only shred what it will take , trying to force more in will only break it faster .
Oct 16, 2015 | Shredder Office Equipment & Supplies
Gbc shredmaster 5550x: this machine has badly worn plastic gears & one has teeth missing. Is a rebuilt drive unit available?
For an answer to this question, you will have to inquire through the manufacturer, or perhaps, there will be a advertiser who does this type of work whose name will come to you along with this answer. Look around on this page right now.
FixYa.com is not a parts or repair depot.
Thanks for your question today at FixYa.com
Jan 27, 2011 | Quartet gbc Shredmaster 5550X Confetti-Cut...
Machine won't shred. Does turn on, and goes in
You dont say make or model so...get some shredder oil into the cutting teeth where you insert the paper...especially if its a x-cut shredder..make sure once in a while you shred a piece of paper with some of the oil poured onto the paper for lubrication of the cutting blades.
Mar 04, 2010 | Office Equipment & Supplies
How do you set it to continually shred. We used
Blow some canned air into the feed slot clean the sensors
Nov 05, 2009 | Quartet gbc Shredmaster 5550X Confetti-Cut...
May 27, 2009 | Quartet gbc ShredMaster 950S Strip-Cut...
Shredder stops in the middle of shredding and won't shred.
Is the paper bin full?....mine always shuts down when the paper bin is a little over half full.
Jan 21, 2008 | Fellowes 220 Powershred Strip-Cut Shredder...
Hello, I have a GBC Shredmaster 6120S
Though I only work with Fellowes shredders this sounds like a paper feed sensor issue. If your unit has a mechanical paper feed sensor you can try to jiggle it in and out to see if any paper may have become jammed behind switch. If the unit has an electronic sensor it may simply need to be cleaned with a Qtip dipped in rubbing alchohol.
If neither of these help your paper feed sensor or your pc board has gone bad and you will have to contact your manufacturer for further parts availability.
Oct 02, 2007 | Office Equipment & Supplies
Sep 28, 2007 | Quartet gbc Shredmaster 5550X Confetti-Cut...
My shredder keeps running and won't stop in on/auto mode
Does the shredder have the electronic eye to sense paper? Sometimes dust will collect on the sensor causing it to keep running.
Apr 07, 2007 | Tech Solution TS-4500 Shredder
Quartet gbc Shredmaster 5550X Confetti-Cut Shredder Logo
32 people viewed this question
Top Quartet gbc Office Equipment & Supplies Experts
Pie-man
Level 1 Expert
pantomac nv
pantomac nv
Level 1 Expert
Bill Boyd
Are you a Quartet gbc Office Equipment and Supply Expert? Answer questions, earn points and help others
