Question about Woods Freezers
Woods chest freezer when top is lift light comes on but the wire hook up broke
Where can i get parts
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 215 Answers
You can put the wires back together by twisting stripped ends together and sealing the repaired spot with "Heat shrink tubing". Most hardware stores carry the tubing (or can help you to find some). Put the tubing on one of the ends, twist them together good and tight, bend the wire flat against either wire, move the tubing down over it and heat with a lighter to shrink it. Get the right size so it shrinks tight for a good seal. Make it long enough to extend an inch or so past the twisted wires on both sides. If the wiring can't be repaired for some reason, an exact replacement would need to come the manufacturer. If regular lamp cord will work, the hardware store should have that too. If you need to pull a new wire through the insulation, let me know. I can give you a tip or two to make it easier. Good luck.
Posted on Dec 29, 2013
Falling Down
  • 67 Answers
SOURCE: door liner on chest freezer broke due to ice build-up
if you can't find a replacement, use a piece of flat vinyl siding that goes on houses. You can heat it and bend it as needed, or cut it and screw the pieces to a balsa wood frame for lightweight support. Glue or epoxy probably won't work as the cold temps make them brittle but external caulking may be ok to hold the pieces together. Be sure to sand all edges and corners as the cut plastic can be sharp. If you can disassemble the unit and place the door face down, you can fill the cavity with insulating foam to help stabilize it.
Posted on Nov 30, 2007
bobotfel
  • 236 Answers
SOURCE: kenmore chest freezer power problem
Try to unplug the the unit power supply to reset the error. But if the error persist you have to call for a qualified technician,
Posted on Dec 28, 2007
SOURCE: Haier freezer chest not cooling. Green light is
Do not put a towel on your freezer or anything that could prevent a good seal from top of freezer.
jim
Posted on May 01, 2009
  • 185 Answers
SOURCE: Both springs on lid broken. Lid won't stay up.
Whatever is on the shelf (parts that have not sold yet) is your best bet. Someone in the USA has to have em cause it hasnt been that long out of business.
here's one place to start ( i couldnt get thru)
AJ Madison
1416 38th Street
Brooklyn, NY 11218-3614
Phone: 800-570-3355
718-532-1800
Phone: 800-570-3355
718-532-1800 Fax: 800-570-7805 E-Mail: sales@ajmadison.com Appliance
Parts Store:
800-378-5177
Appliance parts store:
1800- 378-5177
hope this helps
Posted on Mar 30, 2010
  • 31 Answers
SOURCE: My Woods Energy Star chest
17.77 Cubic feet
Posted on Mar 03, 2011
I just bought a used woods chest freezer and replace the battery but it just beeps and wouldn't start I should I do
More info needed like model number will tell us what it has for parts
compressor relay loose wire or alarm board is bad needing replaced
Feb 14, 2017 | Woods Freezers
How to replace small light in top of chest lid
lever off the plastic cover, unscrew and replace the lamp
Sep 08, 2015 | Woods Chest Freezer C1501W3
Why is there a lot of frost in my woods v15nab freezer?
On a chest freezer, frost always accumulates around the top perimeter first because the warmer moist air comes in contact with that area first once the door is opened. More frequent defrosting may be the answer.
Jun 08, 2014 | GE Freezer  14.8 Cu. Ft. Manual...
Woods Freezer Thermostat
You might try searching on line or perhaps find a local parts supplier who can cross it to something that will work. It may be tough to find one that will work with something that old.
Sep 08, 2012 | Woods Freezers
Order a freezer basket for a chest freezer
wc Woods is out of business however sears.com lista woods parts. Good luck.
Apr 02, 2012 | Woods Chest Freezer C1501W3
Power Light On Woods Chest Freezer
blown globe or neon would not bother dont need it
Jul 18, 2010 | Freezers
Freezer stopped running, think it maybe t-stat ? where to get one ? anyone know anything about it ? it is a mode C05NAA
Here is how to check if the thermosat is bad.
make sure you have 120v to one side of the t'stat. it is just a switch so one side is hot and the other side is not.There are two wires going to the t'stat'. you need to jump them (put them together) if you do this and the compressor kicks on, then replace the t'stat. if it doesn't come on then the t'stat is good. something else is wrong.
check to see if this unit has a timer. check the compressor to see if there is 120v.
i could not find any info on this freezer
Woods parts are not coming up. best bet is call:
partstown.com and appliancezone.com
i tried your model but it didnt come up
but anyways ask them if they at least carry parts
Apr 02, 2010 | Woods 4.3 cu. ft. / 122 liter Chest...
AJ Madison
1416 38th Street
Phone: 800-570-3355
718-532-1800
Phone: 800-570-3355
Parts Store:
800-378-5177
1800- 378-5177
hope this helps
Mar 30, 2010 | Woods Chest Freezer C1501W3
Freezers Logo
59 people viewed this question
Top Woods Freezers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Woods Freezer Expert? Answer questions, earn points and help others
