Question about Estate Refrigerators
Is it safe to have the back of the fridge flat against the wall?
Is it safe to have the back of the fridge flat up against the wall?
2 Suggested Answers
SOURCE: icing fridge wall and fine crack inside corner of fridge.
i called a repair man who was advertised in the local newspaper.
Posted on Aug 17, 2009
How can I reduce my fridge temerature on my HRF370SS FRIDGE FREEZER, IT KEEP GOING HIGHER 9- 14
If this is tight against the back wall and even side, pull it out some so it can breath... When a fridge is tight against the wall it can't breath with Air and works harder hench a colder temp.... Try pulling it out.. UNplug for 10 mins.. Lower the temp dial.. Plug back in. Also if you have pets make sure not PST hair is clogged underneath the unit..
Sep 03, 2016 | Haier Refrigerators
Hi my freezer is not keeping food frozen it starts to thaw after a few days i have cleaned the back of the fridge it is not up against a wall the door seal seems okay the compressor works as i can hear it...
the defrost heater or thermostat on the evaporator coil is bad,you can tell if the inside rear wall of the freezer is covered with frost,you need to remove this panel after defrosting with a hair dryer and find which part is bad
May 19, 2011 | Refrigerators
LEC L6046W FRIDGE - ICE/FROST INSIDE THE BACK WALL. MOTOR IS RUNNING CONSTANTLY.CLEANED ALL THE ICE OFF BUT WHEN SWITCHING BACK ON, WITHIN 10MINS THE ICE,FROST IS BACK?
1.I think you might have a thermostat problem it is over cooling the system and doesn't shut off when it is suppose to. Replace the thermostat
2.If the door seal is broken or the door is not closed shut with the seal magnet nice and tight against the fridge it will form ice inside the fridge as well. Replace the door seal. (this is very common with old fridges)
Sep 06, 2009 | Refrigerators
Picture remains for few seconds then screen goes blank, sound remains on
I had this problem on my 42" Philips LCD. Just got it yesterday and worked fine on the tv stand. As soon as I mounted the TV to the wall via wall mount system, I had the exact same issue you did. Figured it out today.
The wall mount was putting pressure against the center of the back of the tv (tv set had a slightly rounded back plate, and the mount was a flat plate). As soon as I put spacers (part of the wall mount hardware set) between the wall mount braket and the tv so there was no contact except at the mounting holes, the tv worked fine.
My theory is the pressure pushed the tv back plate against some board components which caused them to overheat (no air flow); or put pressure on internal connectors. I dont know.
Hope this helps, may not apply to your situation.
Sep 01, 2009 | Samsung SM932MW 19 in. LCD TV
Icing fridge wall and fine crack inside corner of fridge.
Aug 14, 2009 | Nostalgia Electrics Helman Group CCP-509...
Screen goes blank after about 10 or 15 minutes. There's still sound coming through. Picture comes back on if you turn the tv off & back on again. Any suggestions? (Sansui HDLCD2200 LCD TV) Thanks.
I had this problem on my 42" Philips. Just got it yesterday and worked fine on the tv stand. As soon as I mounted the TV to the wall via wall mount system, I had the exact same issue you did. Figured it out today.
Aug 03, 2009 | Sansui HDLCD-2200 22 in. LCD TV
Yes,i switch on my tv and the picture and sound are perfect for 2 minutes ,then the screen goes blank.The power light comes on but no sound and no picture.please advise ,thanks
It is totally internal problem. May be chip set issue..i suggest you to go call service technician.Don't take a risk, just give it in safe hands for repairing.
Jul 22, 2009 | Philips 42PFL3603D 42 in. LCD TV
Every thing in our freezer is melting and the fridge is barely
take the back cover off and then clean the condenser coil on the unit. that will lower the head pressure whiuch in turn will lower the suction temperature.
Mar 28, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Top half of side by side fridge not getting cold
Make sure you don't have food or packages jammed all the way against the back wall of the unit. Many of these relay on cold air that circulates down the back wall. If the air's passage is blocked, you can get warmer spots in some places.
Nov 26, 2008 | Refrigerators
Refrigerators Logo
14 people viewed this question
Top Estate Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Audie Bogus
Audie Bogus
Level 1 Expert
Are you an Estate Refrigerator Expert? Answer questions, earn points and help others
