Question about Frigidaire White Gas Washer And Dryer Combo - FFLG2022MW
Frigidaire fflg2022mw washer starts by itself
    Sergeant:
    Champion:
  • 310 Answers
Switch board is wet
Posted on Nov 21, 2013
Frigidaire GLT2940S1 front load washer
Hello Friend, this is Z. Thank you for your inquiry!
I see that your Frigidaire washer, GLTF2940FS1 will not start. First, let's try resetting your appliance. This can be done by either unplugging it or flipping the household circuit breaker off. It is important to wait roughly ten minutes, and then turn on your washer. If the issue persists, you may have a communication error from the main control board or timer itself may not be operating correctly. If you noticed minimum blinking or a buzzing noise before shutting off, it could be a faulty power supply or it could possibly have another issue with the door lock assembly. I would personally contact a professional to accurately diagnose your washer to determine the root cause to reduce the risk of unnecessary parts.
Jun 03, 2014 | Frigidaire Washing Machines
Frigidaire washer won't finish cycle
Hello Ellen Greer - This particular issue can be caused by quite a few reasons. Washer could be experiencing a communication error from the main control board, faulty door lock assembly, faulty pump or the timer itself is not operating correctly. Did you notice a humming noise? If so, either the drainage hose/pump is clogged and needs to be cleaned or could possibly have another issue with the door lock assembly or pressure switch. You can also press and hold the start/pause and cancel button together at the same time for approximately 30 seconds to display an error code on the LED. What error code does it display? However, I would suggest contacting a professional to accurately diagnose the washer.
Nov 14, 2012 | Frigidaire ATF6000ES Front Load Washer
DISH WASHER STARTED BY IT SELF
If the resetting at the household circuit breaker has not proven to be successful, then you would need to contact a professional to have the control board and panel diagnosed for repairs.
Sep 23, 2012 | Frigidaire 24 in. FDB1050REC Stainless...
I have a Frigidaire Front Load washer Model#ATF6000FS2 washer . It will not start and seems to be experiencing a problem with the door. There is 'DOOR LOCK' light that does not turn on and th
Sounds like the door is not latching correctly. Check the door for any sagging problems and then check the door latch itself for any damages, cracks, or issues with the door itself connecting to it.
Jul 21, 2012 | Frigidaire ATF6000ES Front Load Washer
Washing machine makes a horrible noise in spin cycle and turns itself off. When we hold the Start and Cancel button together we get code E23.
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems Washer noise when spinning
heatman101
Sep 04, 2010 | Frigidaire Affinity ATF6000F Front Load...
Frigidaire top-load washer Loud noise during spin
its either the upper spin bearing or lower spin bearing. the upper can be replaced by itself but the lower requires the transmission the be replaced
Nov 20, 2007 | Frigidaire FWS833A Top Load Washer
Frigidaire White Gas Washer And Dryer Combo - FFLG2022MW Logo
60 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
