Question about PQI 8GB PQi U273 USB 2.0 Drive Metallic Black - lifetime wty (HDR208G273K) Media
Drive not recognized device
Drive not recognized it.under device manager in universal serial bus controller i have seen unknown device and when i open it in the device status''no driver are installed for this device''
    Champion:
  • 221 Answers
  1. Click Start, then type device manager in the Search box, then click Device Manager.
  2. Expand Universal Serial Bus controllers. Right click a device and click Uninstall. Repeat for each device.
  3. Once complete, restart your computer. Your USB controllers will automatically install.
Posted on Dec 19, 2013
No usb ports recognized
W 7
First, please disconnect all USB devices and then perform the following steps: Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
for XP or earlier
Click start right click on computer select properties device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
Check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
if you need more help with this or if i have missed the problem post a reply
Mar 25, 2014 | Systemax Venture C11R PC Desktop
How to solve code 43 in may flask drive
error 43 is a usb universal serial bus controller problem
click start control panel administrive tools ,computer management ,device manager scroll down
universal serial bus controllers you should see a yellow question / exclamation mark? ! or a red X
right click to reinstall drivers or
ports(com&lpt)right click update driver
for windows 7 you might try
First, please disconnect all USB devices. Then, go through the following steps:
1. Press "Ctrl + Esc" to open the "Start" menu.
2. Type "devmgmt.msc" in the Search bar and press "Enter". Click "Continue" if necessary.
3. In Device Manger, press Tab and use "Up" and "Down" to move the highlight to "Universal Serial Bus Controllers".
4. Press "Right" and expand it.
5. Press "Down" to move to the first item and press "Delete" to remove it.
6. Repeat the step 5 and uninstall all items under "Universal Serial Bus Controllers".
Then, restart your computer and Windows 7 will reinstall all controllers automatically.
hope this helps
Oct 16, 2012 | Kingston Electronics - Others
Can't read micro usb drive
hope this helps
Oct 14, 2012 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
TS4GJF300 USB not recognised error 43 occurs
universal serial bus controllers you should see a yellow question mark?
hope this helps
Aug 28, 2012 | Transcend TS4GJF300 4GB JetFlash 300...
My usb port do not work. It did not recognize any devise.
hello
Use Device Manager to disable and re-enable all the USB controllers. This lets the controllers recover the USB port from its unresponsive condition. The USB controllers represent the USB ports in Device Manager. If you are not comfortable with advanced troubleshooting, try the steps in the "Workaround" section.
To disable and re-enable the USB controllers, follow these steps: Click Start, and then click Run.
Note If you are running Windows Vista, click Start, and then use the Start Search box. Type devmgmt.msc, and then click OK. Device Manager opens. Expand Universal Serial Bus controllers.
Note You might have to scroll down the list to find this item. Right-click the first USB controller under Universal Serial Bus controllers, and then click Uninstall to remove it. Repeat step 4 for each USB controller that is listed under Universal Serial Bus controllers. Restart the computer. After the computer starts, Windows will automatically scan for hardware changes and reinstall all the USB controllers that you uninstalled. Check the USB device to see whether it is working.
hope this helps
Jan 27, 2011 | HP Pavilion dv7-1240us Notebook
Usb port not recognized
1. try using usb1 port ( instead of usb2)
2. check the Device-manager for USB controllers normality. (or try to upgrade versions)
Nov 15, 2010 | SanDisk Sansa Clip MP3 Player
I uninstalled the driver from my transcen jf v30 4gb pendrive. Now windows says hardware not recognized.
Hi s8vysakh6 ,
I would suggest you to try the following steps:
Step 1: Run the fixit provided in the link below.
http://windows.microsoft.com/en-US/windows-vista/Tips-for-solving-problems-with-USB-devices
Check if the issue is resolved
Step 2: Connect the device to a different USB port\ and also connect the USB pen drive to another computer to eliminate issues with the pen drive itself.
If the issue persists,
Step 3: Reinstall USB controllers.
1. Click "Start", type in Device Manager the Search bar and press "Enter". Click Continue if necessary.
2. In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the "Host Controller", click "Uninstall" and click "OK".
3. Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows vista will reinstall all USB controllers automatically.
Step 4: Update the motherboard driver to the latest version.
Note: Please check with the motherboard manufacturer before installing the driver.
If the issue persists, you may want to check with USB pen manufacturer for any unknown issues.
Hope this will help !
Anurag
Mar 13, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Will not work in usb 2.0 but will work in usb 1.0
Connect the Player to the USB 2.0 port on the Comptuer then open the Device Manager and expand the "universal serial bus controllers" category.
Under the serial bus controller category, check if there is any exclamation mark visible. If there is any then right click on it and select Uninstall. Restart the Computer after uninstalling the device with exclamation mark. Restarting the Computer with the player connected will make the Computer recognize the connected player.
Furthermore, check whether there is any universal serial host controllers prefixed with "Enhanced".
If there is no Enhanced universal serial host controller listed under the "serial bus controller" category then it's required to install the USB 2.0 driver.
In this case, uninstall all the devices listed under the universal serial controllers category then restart the Computer to reload them automatically.
Sep 17, 2009 | Audio Players & Recorders
My flash drive will not operate when plug into my lap top.
Hello kjh87....
1) If you are using a USB cable with your device, check the cable to make sure it matches the speed of the device. Use USB 2.0 cables with USB 2.0 devices and USB 1.1 cables with USB 1.1 devices. Swap cables and check the device, if this does not work, proceed to Step 2.
2) Next, open Device Manager and look under the heading for USB Serial Bus Controllers. If there is a device with a yellow exclamation mark next to it such as USB Mass Storage Device. Double-click on the entry and check the Device Status. If the status shows something like
"This device cannot start. (Code 10)"
proceed to Step 3.
3) The easiest way to solve a USB error code 10 in Windows XP
is to follow the steps below to remove and reinstall all USB controllers.
A. Click on Start
B. Right Click on My Computer, click on Properties
C.Click on the Hardware tab
D. Click the Device Manager button.
E. Expand Universal Serial Bus controllers section.
F. Right-click every device under the Universal Serial Bus controllers node, and then click Uninstall to remove them one at a time.
G. Restart the computer, and allow the computer to reinstall the USB controllers.
H. Plug in the removable USB storage device, and then test to make sure that the issue is resolved.
For more information on Troubleshooting USB device problems, visit the Microsoft Support Article on this subject.
I hope this helps...
May 28, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
PQI 8GB PQi U273 USB 2.0 Drive Metallic Black - lifetime wty (HDR208G273K) Media Logo
110 people viewed this question
Top PQI Electronics - Others Experts
Lawrence Oravetz
Mithilesh Kumar
Tom Currie
Tom Currie
Level 1 Expert
Are you a PQI Electronics - Other Expert? Answer questions, earn points and help others
