Vaillant ecotec plus 824 problems
My heating stopped working and I had a part replaced, since having this problem I have 2 symbols constantly on the screen whenever I use hot water or heating the symbols mean internal pump is running and gas valve is activated. I never noticed them constantly there before I had this problem. When I press the I button it says S.& which means pump overrun. is this normal ? or what is causing this?
    Problem Solver:
  • 5 Answers
The Symbols should be there whenever the boiler is in use, it confirms the pump is running and the gas valve is open...i.e firing.
the pump overrun may come on after a firing to dissipate excess heat and is what it says, i.e the pump continues to run to keep the hot water moving to prevent the boiler from getting noisey. Sometimes you may see a radiator symbol which means the boiler is doing a 'heating' cycle as against hot water.
Posted on Nov 20, 2013
3 Suggested Answers
  • 55 Answers
SOURCE: lost my user manual for the vaillant boiler ecotec plus 824 R1
try to enter here all informations and you can find the manual: http://instructions-manuals.com/search.php?cmarque=VALLIANT%20&modele=ECOTEC%20PLUS%20824
Posted on Oct 27, 2009
SOURCE: have a ecotec 824 plus boiler the bar goes upto 2.7 and stays round 1.5 when not operating,what is causing this?
Sounds to me like the expansion vessel is not working correctly. When the boiler is on the water gets hot and expands into the expansion vessel but if the vessel is not working the pressure will rise and will eventually escape through the pressure relief valve.
Posted on Feb 18, 2012
Hi I have a ecoTEC plus 824 and I have heating but no hot water & pressure is in the red....any suggestions
pressure in red is not good - evacuate building.
it must be heating and output is blocked otherwise pressure would not rise.
OR input pressure is too high and pressure is disabling heat.
Dec 09, 2014 | Water Water Heaters
Boiler vaillant ecotec 824 R1 no power
USE A ELECTRIC METER AND CHECK FOR 120 VOLTS AT CIRCUIT BOARD AT LINE IN AND COMMON , IF YOU DO HAVE 12 0 VOLTS THE LOOK FOR TAPPINGS FOR 24 VOLT OUT PUT MAYBE A BAD TRANSFORMER OR CIRCUIT BOARD
Jan 11, 2014 | Water Heaters
A have a vaillant ecotec boiler and when it fires up the fan is very noisy is this right
most likely no. there might be a obstruction in the blades, dirty filter, the motor might have a bad berring , the fan blades might have bent and now are touching the housing prob should call a trained tech boilers aint no joke
Aug 06, 2011 | Heating & Cooling
My vaillant ecoTec plus shows F49 , new vrt 360
F.49 eBUS undervoltage Short circuit on eBUS, overload on eBUS or two power sources on eBUS with different polarity F.61 Gas-valve control defective Short circuit/earth (ground) leak F.49 eBUS undervoltage Short circuit on eBUS, overload on eBUS or two power sources on eBUS with different polarity F.61 Gas-valve control defective Short circuit/earth (ground) leak i pasted the answer below hope it worked
Aug 02, 2010 | Heating & Cooling
F22 error/ low pressure
F.22 Dry fire Too little water in the appliance, water pressure sensor defective,
cable to pump or water sensor defective, pump blocked or defective,
pump output too low
May 11, 2010 | Heating & Cooling
Lost my user manual for the vaillant boiler ecotec plus 824 R1
Oct 27, 2009 | KDS Valiant 6380iPTD-01 Notebook
Vaillant 831 combi boiler timer help
check to see the time clock is set with the clock symbol. there are three settings on analog clocks I , O and clock the I setting is constant running, the O setting is off and the clock setting is timer.
also try setting the thermostat up higher to see if the boiler fires.
Mar 25, 2009 | Water Heaters
Computers & Internet Logo
151 people viewed this question
David Payne
David Payne
