Question about Toshiba Computers & Internet
Toshiba a300 power failure - Toshiba Computers & Internet
My laptop toshiba a300 going to sudenly reset& sometimes power off
First, Is the laptop fan, heatsink, vents clean free of dust. If it's overheating it will shut down to save components for overheating. The Graphic Adapter is a big heat producer. As to the processor running at 100%, It's also a big heat producer, shut down some of the running processes that are not needed. At startup their many programs that are not needed. Use this freeware program, it has many useful tools. Download CCLEANER at : http://www.filehippo.com/download_ccleaner/ This freeware program will remove the junk from your machine, in the TOOLS section, STARTUP section, disable ALL unnessary startup programs. Here are some tips on speed : http://www.pcworld.com/article/143538/windows_vista.html
Jan 31, 2013 | Toshiba Satellite Pro A300 Notebook
How to find sound drivers for toshiba setellite a300
Go to this website and choose the download option at the top and find your model (should be on the sticker on the bottom of your laptop.)
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp
Mar 10, 2011 | Computers & Internet
Toshiba satellite a300 laptop display problem screen black, no display at all.
You laptop either needs a new Cable from the Motherboard to the Screen, a new power inverter, or a new screen. Most commonly, I have seen the video cable get smashed between the hinges/plastic case, and this causes the wires to break apart, leading to a black screen.
Here is the power inverter for your laptop: http://www.sparepartswarehouse.com/Toshiba,Satellite,A300,PSAG0U-0CF035,Laptop,Inverters.aspx
Here is the video cable for your laptop: http://www.notebooksolutions.ca/zc/index.php?main_page=product_info&products_id=3392&zenid=7903c7a1a62c4c2cbfef6ea30865373c
Here is the LCD screen for your laptop: http://www.sparepartswarehouse.com/Toshiba,Satellite,A300,PSAG0U-0CF035,Laptop,LCDs-Displays.aspx
If the display comes back, slightly, when you lift the display lid up and down, this would be a sign that your cable is bad. If you get no reaction from opening and closing the lid, you may have a bad inverter or screen. It is most commonly the inverter or the cable.
If you have a spare monitor, you could plug it into the VGA connector on your Laptop as a temporary solution. If after plugging the monitor in, you get no display, try pressing Fn + F5.
Mar 09, 2011 | Toshiba Satellite A300-0CF035 Notebook
Iv got a toshiba satellite A300 and i was wondering how can i speed my my graphics card ( in any way ) whenever i try to install games and play they there is always a fault of some sort one fault that...
When you will increase the ram your laptop will be fast soon.
You can increase 4 GB maximum.
For dissemble follow bellow the link
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A355-A355D/laptop-disassembly-1.htm
Maximize your Toshiba Satellite A300-ST6511 mobile computing power and add more memory. Trust PRO Memory Upgrade to provide dependable expansion options for your laptop or notebook with a Toshiba Satellite Small Outline DIMM RAM upgrade.
  • Your Toshiba Satellite maximum RAM capacity: 4GB
  • The Satellite A300-ST6511 has 2 memory slots or sockets
  • This Satellite module upgrade PIN count is: 200-PIN
  • The memory speed is: DDR2 800MHz, PC2-6400
  • The DIMM type for your Satellite A300-ST6511 is: SODIMM, SO-DIMM, Small Outline DIMM
  • For4 diassamble the
Hope it help you.
Jan 08, 2011 | Toshiba Satellite A300-ST6511 Notebook
Toshiba sattelite a300 logo and media player doesnt light
Hi
From your description it sounds like the LED board underneath may be faulty in the sense that some of the LED's may have blown, this can be repaired but i advis that you take to a qualified engineer to assess and then replace
Please leave feedback/vote if my answer was helpful
Feb 10, 2010 | Toshiba Satellite A300-0CF035 Notebook
Toshiba a300 does not charge new battery and wont boot up now
Power supply cord is faulty. You can get another from newegg.com or amazon.com or ebay.
Sep 16, 2009 | Toshiba Satellite A300-0CF035 Notebook
Internet connection failure
replace the LAN card...or try to move the other connection cable
May 23, 2009 | Toshiba Satellite A300-0CF035 Notebook
Toshiba A300 not booting.
plz take out the battery and try if the problem is not solved then try by resiting the ram. if you are not familiar with the computer terms and parts you plz ask some professional to help you from your area
Feb 22, 2009 | Toshiba Satellite A300-0CF035 Notebook
Computers & Internet Logo
19 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
