Question about Definitive ProCinema 600 Speaker System
220V for Definitive ProCinema 600 - Definitive ProCinema 600 Speaker System
My definitive technology pro cinema 600 sub stopped working
theres a setting is on the subwoofer itself, not the AVR. It usually has 3 positions: On, Auto, Off. Auto allows the sub to "sleep" when it's not being used, and to power back up fully when it senses a signal. Maybe change to On position which would bypass that auto mode
May 07, 2017 | Definitive Audio Players & Recorders
The subwoofer by DT ProCinema 600 doesn't work
I had the same problem when I wanted to swap my PCicon1.png 1000 for the PC 2000. The later interfered with my view on the tv. What I did was raise the tv on a couple of pieces of MDF. I painted the edges of the MDF to match the tv stand. Looks great - is very solid as far as support for the tv - and allowed me to get the PC 2000smile.gif
Nov 04, 2014 | Definitive Technology ProCinema 600 black
How to change 110v to 220v on sonance cinema 260 subwoofer amplifier
I suggest contacting the manufacturer as there may be an internal "reconnect" that would allow 220v operation. Good luck!
May 21, 2014 | Audio Players & Recorders
I recently bought a U.S. version Nakamichi 600 II cassette console (120V), and I accidently burnt its transformer out by a 220V mains supply. Now I need to replace this burnt out transformer better with a...
To match it with an other transformer, you have to know about its secondary voltages. Try to download its service manual by internet. It will have all details. It will be best to contact any expereienced service technician or to the authorized service center for Nakamichi.
Feb 24, 2013 | Televison & Video
Front speaker from my 600 isn't working
I just ran into this in 4 of my 5 DF Procimema 600 speakers. I ended up taking them all apart (be aware - this will probably void any warranty). To do this, you have to take the speaker grill off. Next, using a small phillips head screw driver, take out the top two screws on the front of the speaker. Note - everything you need to do will be from the front.. you don't actually remove anything from the top of the speaker. Next, using a pair of needle-nose plyers (or tweezers or whatever you have) remove the 6 little star-shaped plugs. These are where the spikes on the speaker grill insert to hold it in place. I thought they were some sort of weird screw at first until I removed one, then realized they are actually just a rubber plug. They pull right out - no twisting. Underneath them are 6 more phillips head screws - remove these and the front plate, speakers and all, will (should) pull right off without damage. The problem, well with all of my speakers at least, is that the connections inside come loose or fall off. I just took my needle-nose plyers and squeezed the connectors both where the wires run to the back of the case, and also to where they attach to the speaker. This literally solved all my problems and now my speakers work flawlessly again. Don't forget to put the white insulating material back in place before you put the speaker back together and you should be good to go. I hope this helps!
Jul 20, 2012 | Definitive Technology - Procinema 600 -...
Hooked up the system, subwoofer worked OK for about 3 hours then stopped outputting sound. Tried troubleshooting per manual but no luck. All other speakers appear to be working. I think the subwoofer died...
to make sure its not your reciever unplug sub from pre out side of reciever and with sub on run finger over the tip of the RCA you should get some kind of electral feed back from it through your sub if not then your sub or the amp inside is most likley fried if you know how to open the sub and can access it you may have a mini fuse inside that can be replaced but make sure consult somone about that and not just take my word
Oct 26, 2009 | Definitive ProCinema 600 Speaker System
Difinitive prosub 600 keeps turning its self off??? I have connected the sub every which way, low level RCA to sub out, using the prosub 600 as a bus for the front monitors, even both together. I have...
"Somthing seems to be wrong with the automatic on/off???" That's my guess too. Your sub requires a certain signal level to turn on, probably because of a sub-sonic filter. I just changed to another sub that did not have that "feature". Problem solved.
Jul 19, 2017 | Definitive SubAmp 600 Amplifier
Placement of definitive supercube 2
Make shure your crossover on the amp is set at 80hz. If closer to side walls you will get more response but may be muddy. Make sure it goes low enough to comliment the klipchs.
GOOD LUCK
BIGRED
Apr 10, 2008 | Definitive SubAmp 600 Amplifier
No power
disconnect thesub amp and see if it power up if so
Dec 13, 2007 | Definitive SubAmp 600 Amplifier
Definitive ProCinema 600 Speaker System Logo
44 people viewed this question
Top Definitive Audio Players & Recorders Experts
 Grubhead
Grubhead
Rob
Rob
Are you a Definitive Audio Player and Recorder Expert? Answer questions, earn points and help others
