Question about LG DLGX5171V
LG DLGX5171V open the top - LG DLGX5171V
  • Jeffrey Hess Nov 20, 2013
    OK, I answered my own question. Like many top control dryers, there are two spring clips near the front top corners that need to be pushed in with a "putty knife". In the case of this dryer, the springs are VERY stiff, an there is a screw on one side and a guide pin on the other side of the clip. I used a two inch plastic putty knife (to avoid marring the finish) to open mine, but it took a lot of push. A 1" putty knife would have been better in order to get between the screw (holds the front cover on) and the alignment pin. BTW, the belt on mine is broken after being in service only three months. I can't decide whether to replace it myself (so it gets done sooner), or have it done under warranty.
    Sergeant:
    Champion:
  • 310 Answers
Two back scews removes the top
Posted on Nov 21, 2013
What part need to replace LG DLGX5171V keep getting power Trip or stop working
Check wires going to motor. Must be a short there.
Aug 16, 2017 | LG Dryers
How do i open the top of stove to clean its lrg30855st
Turn off the gas. Lift off the burner cap and the burner head from all remove the torx screws under each of the five burner heads then lift off he top. The picture on these two pages of the manual show where the screws are and what the stove looks like with the top off:
http://www.manualslib.com/manual/705911/Lg-Lrg30855st.html?page=21#manual
http://www.manualslib.com/manual/705911/Lg-Lrg30855st.html?page=22#manual
Oct 05, 2014 | LG LRG30855ST Stainless Steel Gas Range
My two year old LG Top loader washer wt5001cw completed it cycle and shut off. The latch will not open now and it won't turn back on. HELP!
Use a putty knife to lift top. Insert between cabinet and top in front. There is one on the left and the right. Then the top should lift up and be able to at least get your clothes out.
Oct 18, 2013 | LG WT5001CW Washer
How do I take out the igniter on a dlg3788w
It is hard to open an LG dryer. You open the top by unscrewing the 3 screw which located a little bit deeper underneath the top. Then pushing forward the top about two inches and lift it up. There are two hooks holding the top. Once the top lifted up, you have to pop off the console then remove the control board, remember to take picture before doing that. You will see 3 screws on the top and two screws right below the filter. Take them all out and you can pop off the front. From then you can see everything inside the dryer. Igniter is inside the fire compartment, it will be removed easy.
Oct 14, 2013 | LG Dryers
Have a lg blue ray player that makes loud noise and says disc error
This is a hardware issue.
The LG drives motor attaches to the top rotor by help of a magnet, which fixes the disc so it can spin symmetrically. For this to happen, the drive unit has to have a fixed piece of metal. Now, this particular metal ring gets loose quite easily and then permanently sticks on the top of the unit, where the magnet is situated. As it is now loosely attached to the top of the drive unit, the optical disc will spin errandly, that is where the clunking, rattling noise comes from.
To fix it, you must open the LG player and the drive unit, which is really simple to do, and glue the metal ring back in its original position.
Thats how I did it and the drive now purrs along quietly.
PS
LG really produces those units cheaply, that is the reason the metal ring detaches so easily.
Jun 03, 2012 | LG BD670 Bluray 3D Player
Just woke up, and my lg vortex is dead.. its a brand new phone.i week old..
to turn the phone on press and hold the silver button on the top left of the phone until you see the lg logo. to open back (battery compartment) look at top of phone, should see a small notch between headphone jack and power button, slide fingernail in notch and push cover away from phone. any luck?
Dec 22, 2011 | LG Vortex
How to open the top of an LG gas dryer
Check question. what is the trick to getting off the front and top. (LG DLG0452W Gas Dryer)
Dec 30, 2009 | LG DLG0452W Gas Dryer
How to take it apart how does a lg come apart
Generally speaking, the top is held in place with spring clips while the front panel is held with screws and maybe spring clips.
I realize you are asking a very specific question about a very specific model. I must tell you that even though I am rated as a LG expert, I am not intimately familiar with every LG model.
To open the top, being careful to not chip the finish, pry at the seam between the top and the side panels. Be very careful of the wires that connect to the door switch.
When you remove the front, the drum will come free from its front door mount. You will probably need assistance to reassemble it.
Clean all the dust and dirt and $$$ our of the machine while you have it open.
I hope this answers your quesiton
Thanks for your interest in FixYa.com
Please vote
thanks
a
Dec 06, 2009 | LG DLE5977 Electric Dryer
Detergent drawer will not open
Here's a possible solution: Remove the two screws on the bottom side of the plastic clips on the back of the washer (leaving the clips attached to the washer's top), then use the palms of your hands to sharply push the top back about an inch and a half and lift the top off the machine. Now, if you can see enough through the translucent plastic to tell where the hang up is, you can drill a small hole in the top of it to allow you to push that part down so the drawer will open. Then, use foil duct tape to seal the hole.
Jan 12, 2009 | LG WM-2277HW Front Load Washer
How to open lg dle2514 front load to clean blower and vent
Remove the 3 screws holding the top of the dryer.  Push the top towards the rear and remove top.
Remove the front control display board by removing the 2 screws and unsnapping the control panel.
Remove the 4 top screws hold the front panel and the 2 bottom screws in the door frame area.  Remove the light switch wire connector.  Tilt the front panel forward and lift up.
Apr 29, 2008 | LG DLE2514 Electric Dryer
LG DLGX5171V Logo
61 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
